[postgis-tickets] [PostGIS] #5418: Don't know what gentext to create for xref to: "listitem" (linkend=tiger_geocoder_loading_data)
PostGIS trac at osgeo.org
Thu Jun 29 15:04:16 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Comment (by strk):
 Now that PDF generation works (#5419) I confirm the listitem target
 warning does not prevent building the PDF, but if would result in this
 text:
 Refer to [?listitem] for instructions on how to run the generate script.
 Instead of this:
 Refer to Section 2.4.1 for instructions on how to run the generate script.
 And the [?listitem] word would not even be clickable, so I'd keep
 [d83e805/git]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5418#comment:5>
