[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1077-gd83e8056a
Thu Jun 29 14:01:10 PDT 2023
the project "PostGIS".
       via  d83e8056a6d01dcf65d61a9c9b5f85b3d7b8ce71 (commit)
      from  d22db49d3887e9cab582d1b1a427254ca98bae16 (commit)
revisions in full, below.
commit d83e8056a6d01dcf65d61a9c9b5f85b3d7b8ce71
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 23:00:16 2023 +0200
    Avoid xref to listitem, unsupported by PDF output
    Closes #5418
diff --git a/doc/installation.xml b/doc/installation.xml
index 54f0d0b0b..633e39da5 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -1034,7 +1034,8 @@ ALTER EXTENSION postgis_tiger_geocoder UPDATE;</programlisting>
 	   1 | Devonshire | Pl               | 02109</screen></para>
 			</listitem>
-			<listitem id="tiger_geocoder_loading_data"><para>Create a new record in <varname>tiger.loader_platform</varname> table with the paths of your executables and server. </para>
+			<listitem>
+                <para>Create a new record in <varname>tiger.loader_platform</varname> table with the paths of your executables and server. </para>
 				<para>So for example to create a profile called debbie that follows <code>sh</code> convention. You would do:</para>
 				<programlisting>INSERT INTO tiger.loader_platform(os, declare_sect, pgbin, wget, unzip_command, psql, path_sep,
 		   loader, environ_set_command, county_process_command)
@@ -1153,7 +1154,7 @@ vacuum (analyze, verbose) tiger.zip_state_loc;</programlisting>
 		<programlisting>SELECT loader_generate_nation_script('windows'); </programlisting>
 		<para><emphasis role="bold">For unix/linux</emphasis></para>
 		<programlisting>SELECT loader_generate_nation_script('sh');</programlisting>
-		<para>Refer to <xref linkend="tiger_geocoder_loading_data" /> for instructions on how to run the generate script. This only needs to be done once.</para>
+		<para>Refer to <xref linkend="install_tiger_geocoder_extension" /> for instructions on how to run the generate script. This only needs to be done once.</para>
 		<note><para>You can have a mix of different year state tables and can upgrade each state separately.  Before you upgrade a state you first need to drop the prior year state tables for that state using <xref linkend="Drop_State_Tables_Generate_Script" />.</para></note>
 	</sect2>
Summary of changes:
 doc/installation.xml | 5 +++--
 1 file changed, 3 insertions(+), 2 deletions(-)
hooks/post-receive
