[postgis-tickets] [PostGIS] #5419: pdflatex failed
PostGIS trac at osgeo.org
Thu Jun 29 14:28:53 PDT 2023
 Reporter:  strk           |      Owner:  robe
     Type:  defect         |     Status:  new
 Priority:  blocker        |  Milestone:  PostGIS 3.4.0
Component:  documentation  |    Version:  master
 Keywords:                 |
 pdf cannot be built either on my machine or on woodie (and I think on
 debbie too).
 The last successful build I have locally is from the 3.3 branch as of
 [82421b9c769e2b36690bbb6659e47995276385d7/git]
 Comparing the logs all the messages before the {{{ Build postgis-out.pdf
 }}} step are present also in the successful build, so
 [d83e8056a6d01dcf65d61a9c9b5f85b3d7b8ce71/git] was probably also not
 required (ref #5418).
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5419>
