[postgis-tickets] [PostGIS] #5419: pdflatex failed
PostGIS trac at osgeo.org
Thu Jun 29 14:33:06 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  new
  Priority:  blocker        |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:                 |   Keywords:
Comment (by strk):
 All errors seem to come from postgis-out.tex starting from:
 postgis-out.tex:5940: Missing \endcsname inserted.
 postgis-out.tex:5940: leading text: ...ementation Specification for SQL
 1.1.} }
 postgis-out.tex:5940: Use of \docomment doesn't match its definition.
 1.1.} }
 And ending with:
 postgis-out.tex:6381: Unbalanced output routine.
 postgis-out.tex:6381: leading text: S
 postgis-out.tex:6381: Undefined control sequence \@mpargs.
 postgis-out.tex:6381: TeX capacity exceeded, sorry [main memory
 size=5000000].
 With --dump we get this info, not sure how useful:
 Unexpected error occured
   File "/usr/lib/python3/dist-packages/dbtexmf/core/dbtex.py", line 758,
 in main
     run.compile()
   File "/usr/lib/python3/dist-packages/dbtexmf/core/dbtex.py", line 366,
 in compile
     donefiles = self._compile()
   File "/usr/lib/python3/dist-packages/dbtexmf/core/dbtex.py", line 440,
 in _compile
     self.make_bin()
   File "/usr/lib/python3/dist-packages/dbtexmf/core/dbtex.py", line 349,
 in make_bin
     self.runtex.compile(d.texfile, d.binfile, self.format,
   File "/usr/lib/python3/dist-packages/dbtexmf/dblatex/runtex.py", line
 122, in compile
     self.texer.compile(texfile)
 packages/dbtexmf/dblatex/grubber/texbuilder.py", line 102, in compile
     raise OSError("%s compilation failed" % self.tex.program)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5419#comment:1>
