[postgis-tickets] [PostGIS] #5419: pdflatex failed
PostGIS trac at osgeo.org
Thu Jun 29 14:58:23 PDT 2023
  Reporter:  strk           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  blocker        |  Milestone:  PostGIS 3.4.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Changes (by Sandro Santilli <strk@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"db1537723b0bc92ec6065677e27a9a374578e9c2/git"
 db153772/git]:
 {{{#!CommitTicketReference repository="git"
 revision="db1537723b0bc92ec6065677e27a9a374578e9c2"
 Use xetex backend of dblatex, fixing the PDF build
 Closes #5419
 Note you now need the texlive-xetex to build the pdf
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5419#comment:3>
