[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1079-g19525b456
Thu Jun 29 14:58:14 PDT 2023
the project "PostGIS".
       via  19525b45615a69d64ab6201b42ed7e02003c5d3f (commit)
       via  db1537723b0bc92ec6065677e27a9a374578e9c2 (commit)
      from  d83e8056a6d01dcf65d61a9c9b5f85b3d7b8ce71 (commit)
revisions in full, below.
commit 19525b45615a69d64ab6201b42ed7e02003c5d3f
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 23:54:27 2023 +0200
    Use Makefile conditionals instead of shell conditionals
diff --git a/doc/Makefile.in b/doc/Makefile.in
index c29d1125f..3e2900ba8 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -319,25 +319,27 @@ html/postgis$(DOCSUFFIX).html: postgis-out.xml Makefile images $(XML_INPUTS)
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf: postgis-out.xml images $(XML_INPUTS)
-	if test x"$(DBLATEX)" = x; then \
-	   echo "Error: dblatex not found, can't build pdf"; \
-	   echo "       try installing dblatex and then re-run configure"; \
-	   false; \
-	else \
-		$(DBLATEX) -T native -t pdf \
-		   -x "--path $(XSLT_PATH)" \
-		   -I "${PWD}/html" \
-		   -P doc.collab.show=0 \
-		   -P figure.note="${PWD}/html/images/note" \
-		   -P figure.tip="${PWD}/html/images/tip" \
-		   -P figure.important="${PWD}/html/images/important" \
-		   -P figure.warning="${PWD}/html/images/warning" \
-		   -P figure.caution="${PWD}/html/images/caution" \
-		   -P latex.output.revhistory=0 \
-		   -s "$(abs_srcdir)/texstyle.sty" \
-		   -b xetex \
-		   -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf $<; \
-	fi
+ifeq ($(DBLATEX),)
+	@echo
+	@echo "configure was unable to find the 'dblatex' utility program."
+	@echo "To create pdf files, install dblatex and then re-run configure."
+	@echo
+	false
+else
+	$(DBLATEX) -T native -t pdf \
+		 -x "--path $(XSLT_PATH)" \
+		 -I "${PWD}/html" \
+		 -P doc.collab.show=0 \
+		 -P figure.note="${PWD}/html/images/note" \
+		 -P figure.tip="${PWD}/html/images/tip" \
+		 -P figure.important="${PWD}/html/images/important" \
+		 -P figure.warning="${PWD}/html/images/warning" \
+		 -P figure.caution="${PWD}/html/images/caution" \
+		 -P latex.output.revhistory=0 \
+		 -s "$(abs_srcdir)/texstyle.sty" \
+		 -b xetex \
+		 -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).pdf $<
+endif
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub: postgis-out.xml images $(XML_INPUTS)
 	if test x"$(DBTOEPUB)" = x; then \
commit db1537723b0bc92ec6065677e27a9a374578e9c2
Date:   Thu Jun 29 23:51:53 2023 +0200
    Use xetex backend of dblatex, fixing the PDF build
    Closes #5419
    Note you now need the texlive-xetex to build the pdf
index e3294670a..c29d1125f 100644
@@ -335,6 +335,7 @@ postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSIO
+		   -b xetex \
 	fi
Summary of changes:
 doc/Makefile.in | 39 +++++++++++++++++++++------------------
 1 file changed, 21 insertions(+), 18 deletions(-)
hooks/post-receive
