[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1080-g17d1f1518
Thu Jun 29 15:18:46 PDT 2023
the project "PostGIS".
       via  17d1f1518f36e2c772ced3d511766776057bb1cd (commit)
      from  19525b45615a69d64ab6201b42ed7e02003c5d3f (commit)
revisions in full, below.
commit 17d1f1518f36e2c772ced3d511766776057bb1cd
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jun 30 00:15:44 2023 +0200
    Do not assume DBTOEPUB is available
diff --git a/configure.ac b/configure.ac
index ae7a4bb08..4d741b479 100644
--- a/configure.ac
+++ b/configure.ac
@@ -237,6 +237,14 @@ fi
 AC_SUBST(CAN_BUILD_COMMENTS)
 AC_SUBST(CAN_BUILD_PDF)
+CAN_BUILD_EPUB=${CAN_BUILD_COMMENTS}
+AC_PATH_PROG([DBTOEPUB], [dbtoepub], [])
+if test "x$DBTOEPUB" = "x"; then
+  AC_MSG_WARN([dbtoepub is not installed so EPUB documentation cannot be built])
+  CAN_BUILD_EPUB=no
+fi
+AC_SUBST(CAN_BUILD_EPUB)
 AC_PATH_PROG([XMLLINT], [xmllint], [])
 if test "x$XMLLINT" = "x"; then
 	AC_MSG_WARN([xmllint is not installed so documentation cannot be checked])
diff --git a/doc/Makefile.in b/doc/Makefile.in
index 3e2900ba8..aeac77a19 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -52,6 +52,8 @@ CAN_UPDATE_TRANSLATIONS=@CAN_UPDATE_TRANSLATIONS@
 XMLLINT=@XMLLINT@
 CAN_BUILD_COMMENTS=@CAN_BUILD_COMMENTS@
 PERL=@PERL@
+#CAN_BUILD_PDF=@CAN_BUILD_PDF@
+#CAN_BUILD_EPUB=@CAN_BUILD_EPUB@
 # To allow network access use:
@@ -104,7 +106,7 @@ MSGINIT=@MSGINIT@
 XML2POT=@XML2POT@
 # DOCBOOK to EPUB
-DBTOEPUB=dbtoepub
+DBTOEPUB=@DBTOEPUB@
 # Directories for postgresql subdirectories
 PGSQL_DOCDIR=@PGSQL_DOCDIR@
@@ -120,6 +122,10 @@ ifeq ($(CAN_BUILD_PDF),yes)
 BUILD_TARGET += pdf
 endif
+ifeq ($(CAN_BUILD_EPUB),yes)
+BUILD_TARGET += epub
+endif
 # TODO: add "html" to the BUILD_TARGET if it can be built
 all: $(BUILD_TARGET)
@@ -324,7 +330,7 @@ ifeq ($(DBLATEX),)
 	@echo "configure was unable to find the 'dblatex' utility program."
 	@echo "To create pdf files, install dblatex and then re-run configure."
 	@echo
-	false
+	@false
 else
 	$(DBLATEX) -T native -t pdf \
 		 -x "--path $(XSLT_PATH)" \
@@ -342,15 +348,17 @@ else
 endif
 postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub: postgis-out.xml images $(XML_INPUTS)
-	if test x"$(DBTOEPUB)" = x; then \
-	   echo "Error: dbtoepub not found, can't build epub"; \
-	   echo "       try installing dbtoepub"; \
-	   false; \
-	else \
-		$(DBTOEPUB) -c "${PWD}/html/style.css" \
-		 -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub \
-	fi
+ifeq ($(DBTOEPUB),)
+	@echo
+	@echo "configure was unable to find the 'dbtoepub' utility program."
+	@echo "To create pdf files, install dbtoepub and then re-run configure."
+	@echo
+	@false
+else
+	$(DBTOEPUB) -c "${PWD}/html/style.css" \
+	 -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub \
+endif
 epub: postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub
Summary of changes:
 configure.ac    |  8 ++++++++
 doc/Makefile.in | 30 +++++++++++++++++++-----------
 2 files changed, 27 insertions(+), 11 deletions(-)
hooks/post-receive
