[postgis-tickets] [PostGIS] #5421: PG17 bot testing broken on JSON
PostGIS trac at osgeo.org
Fri Jun 30 04:27:11 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  Website Management, Bots
 Component:  buildbots  |    Version:  master
Resolution:             |   Keywords:
Comment (by robe):
 Looks like head was stamped as PG17 17 hrs ago by Tom.  I think the issue
 is because the change that was supposed to happen in PG15 for JSON, I had
 kept in, but stamped to not use until PG17 and PG17 is still essentially
 PG16, so I need to set that > 18 for now.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5421#comment:1>
