[postgis-tickets] [PostGIS] #5421: PG17 bot testing broken on JSON
PostGIS trac at osgeo.org
Fri Jun 30 04:23:24 PDT 2023
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  Website Management, Bots
Component:  buildbots  |    Version:  master
 Keywords:             |
 Getting the below errors on debbie's PG16 run and berrie64 which are both
 running fairl recent PG16 builds
 07:06:09 lwgeom_out_geojson.c:54:7: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09    54 |       JsonTypeCategory tcategory, Oid outfuncoid,
 07:06:09       |       ^~~~~~~~~~~~~~~~
 07:06:09 lwgeom_out_geojson.c:69:9: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09    69 |         JsonTypeCategory tcategory, Oid outfuncoid,
 07:06:09 lwgeom_out_geojson.c: In function ‘composite_to_geojson’:
 07:06:09 lwgeom_out_geojson.c:160:3: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09   160 |   JsonTypeCategory tcategory;
 07:06:09 lwgeom_out_geojson.c:210:17: error: ‘JSONTYPE_NULL’ undeclared
 (first use in this function); did you mean ‘JSON_TOKEN_NULL’?
 07:06:09   210 |     tcategory = JSONTYPE_NULL;
 07:06:09       |                 JSON_TOKEN_NULL
 07:06:09 lwgeom_out_geojson.c:210:17: note: each undeclared identifier is
 reported only once for each function it appears in
 07:06:09 lwgeom_out_geojson.c:214:5: warning: implicit declaration of
 function ‘json_categorize_type’ [-Wimplicit-function-declaration]
 07:06:09   214 |     json_categorize_type(att->atttypid, &tcategory,
 &outfuncoid);
 07:06:09       |     ^~~~~~~~~~~~~~~~~~~~
 07:06:09 lwgeom_out_geojson.c:216:4: warning: implicit declaration of
 function ‘datum_to_json’; did you mean ‘row_to_json’? [-Wimplicit-
 07:06:09   216 |    datum_to_json(val, isnull, props, tcategory,
 outfuncoid, false);
 07:06:09       |    row_to_json
 07:06:09 lwgeom_out_geojson.c: At top level:
 07:06:09 lwgeom_out_geojson.c:352:6: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09   352 |      JsonTypeCategory tcategory, Oid outfuncoid,
 07:06:09 lwgeom_out_geojson.c: In function ‘array_to_json_internal’:
 07:06:09 lwgeom_out_geojson.c:469:2: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09   469 |  JsonTypeCategory tcategory;
 07:06:09 lwgeom_out_geojson.c:492:2: warning: implicit declaration of
 function ‘array_dim_to_json’; did you mean ‘array_to_json’? [-Wimplicit-
 07:06:09   492 |  array_dim_to_json(result, 0, ndim, dim, elements, nulls,
 &count, tcategory,
 07:06:09       |  array_to_json
 07:06:09 lwgeom_out_geojson.c: In function ‘composite_to_json’:
 07:06:09 lwgeom_out_geojson.c:536:3: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09   536 |   JsonTypeCategory tcategory;
 07:06:09 lwgeom_out_geojson.c:555:16: error: ‘JSONTYPE_NULL’ undeclared
 07:06:09   555 |    tcategory = JSONTYPE_NULL;
 07:06:09 lwgeom_out_geojson.c:575:35: error: unknown type name
 ‘JsonTypeCategory’
 07:06:09   575 |       bool *nulls, int *valcount, JsonTypeCategory
 tcategory,
 07:06:09 lwgeom_out_geojson.c:644:1: warning: ‘postgis_JsonEncodeDateTime’
 defined but not used [-Wunused-function]
 07:06:09   644 | postgis_JsonEncodeDateTime(char *buf, Datum value, Oid
 typid)
 07:06:09       | ^~~~~~~~~~~~~~~~~~~~~~~~~~
 07:06:09 lwgeom_out_geojson.c:503:1: warning: ‘composite_to_json’ defined
 07:06:09   503 | composite_to_json(Datum composite, StringInfo result,
 bool use_line_feeds)
 07:06:09 lwgeom_out_geojson.c:456:1: warning: ‘array_to_json_internal’
 07:06:09   456 | array_to_json_internal(Datum array, StringInfo result,
 07:06:09 make[1]: *** [<builtin>: lwgeom_out_geojson.o] Error 1
 They are reading PG17 so I think it's because they flipped the switch on
 master and I didn't notice.
 need to branch out a PG16
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5421>
