[postgis-tickets] [PostGIS] #5421: PG17 bot testing broken on JSON
PostGIS trac at osgeo.org
Fri Jun 30 04:33:52 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.3.4
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Regina Obe <lr@…>):
 In [changeset:"7e62e02ba017c560dfd7bff682cdcdc701fef7ef/git" 7e62e02/git]:
 {{{#!CommitTicketReference repository="git"
 revision="7e62e02ba017c560dfd7bff682cdcdc701fef7ef"
 PG17 is now master and
 still doesn't have the new json api exposed
 Flip the json api to PG18 for now
 May need to flip back later.
 References #5421 for PostGIS 3.4.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5421#comment:3>
