[postgis-tickets] [PostGIS] #5421: PG17 bot testing broken on JSON
PostGIS trac at osgeo.org
Fri Jun 30 04:51:52 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.3.4
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by Regina Obe <lr@…>):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 In [changeset:"c8dd8b38066a06e08ef9d0408fcb6327ade8fa28/git" c8dd8b3/git]:
 {{{#!CommitTicketReference repository="git"
 revision="c8dd8b38066a06e08ef9d0408fcb6327ade8fa28"
 PG17 is now master and
 still doesn't have the new json api exposed
 Flip the json api to PG18 for now
 May need to flip back later.
 Closes #5421 for PostGIS 3.3.4
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5421#comment:4>
