[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1086-g7e62e02ba
Fri Jun 30 04:33:43 PDT 2023
the project "PostGIS".
       via  7e62e02ba017c560dfd7bff682cdcdc701fef7ef (commit)
      from  bf64bc6886537c999b82bdf7e4be1dd2d390165e (commit)
revisions in full, below.
commit 7e62e02ba017c560dfd7bff682cdcdc701fef7ef
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 30 07:32:16 2023 -0400
    PG17 is now master and
    still doesn't have the new json api exposed
    Flip the json api to PG18 for now
    May need to flip back later.
    References #5421 for PostGIS 3.4.0
diff --git a/postgis/lwgeom_out_geojson.c b/postgis/lwgeom_out_geojson.c
index b545913d4..31b097fd7 100644
--- a/postgis/lwgeom_out_geojson.c
+++ b/postgis/lwgeom_out_geojson.c
@@ -32,7 +32,7 @@
 #include "lwgeom_log.h"
 #include "liblwgeom.h"
-#if POSTGIS_PGSQL_VERSION < 170
+#if POSTGIS_PGSQL_VERSION < 180
 typedef enum					/* type categories for datum_to_json */
 	JSONTYPE_NULL,				/* null, so we didn't bother to identify */
@@ -68,7 +68,7 @@ static void composite_to_json(Datum composite, StringInfo result,
 static void datum_to_json(Datum val, bool is_null, StringInfo result,
 						  JsonTypeCategory tcategory, Oid outfuncoid,
 						  bool key_scalar);
 static void json_categorize_type(Oid typoid,
 								 JsonTypeCategory *tcategory,
 								 Oid *outfuncoid);
@@ -244,7 +244,7 @@ composite_to_geojson(FunctionCallInfo fcinfo,
  * output function OID.  If the returned category is JSONTYPE_CAST, we
  * return the OID of the type->JSON cast function instead.
 static void
Summary of changes:
 postgis/lwgeom_out_geojson.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
hooks/post-receive
