[postgis-tickets] [PostGIS] #5422: EPUB Makefile target requires manually copying files around
PostGIS trac at osgeo.org
Fri Jun 30 04:41:18 PDT 2023
 Reporter:  strk                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  medium                 |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 The dbtoepub tool doesn't seem to have a way to pass XSLT path so it
 doesn't work when images referenced via images/xxx are instead found in
 html/images/xxx
 The debbie's script "solves" this by creating an images/ directory and
 copying all files there, but we need a more general fix
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5422>
