[postgis-tickets] [PostGIS] #5422: EPUB Makefile target requires manually copying files around
PostGIS trac at osgeo.org
Fri Jun 30 05:39:39 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 On further analisys, it's not XSLT path that we are in need of, but rather
 images path, required at epub packaging time. Something to fix in here:
 https://github.com/docbook/xslt10-stylesheets/blob/fe16c90013b64e316c3e21ef92d1e8813c10f88c/xsl/epub/bin/lib/docbook.rb#L167
 The code above just assumes image paths are relative to the path of the
 docbook input file (it'd be build dir)
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5422#comment:1>
