[postgis-tickets] [PostGIS] #5422: EPUB Makefile target requires manually copying files around
PostGIS trac at osgeo.org
Fri Jun 30 07:15:12 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 It's actually also XSLT path that we need, for postgis_special.ent
 I guess I could merge those entities back to postgis.xml to simplify life
 and be happy again with epub generation.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5422#comment:2>
