[postgis-tickets] [PostGIS] #5422: EPUB Makefile target requires manually copying files around
PostGIS trac at osgeo.org
Fri Jun 30 07:27:39 PDT 2023
  Reporter:  strk                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  medium                 |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by Sandro Santilli <strk@…>):
 In [changeset:"52b6274d323aa43719458537c7972f59591c439c/git"
 52b6274d/git]:
 {{{#!CommitTicketReference repository="git"
 revision="52b6274d323aa43719458537c7972f59591c439c"
 Make all images available via a single images/ directory in build dir
 Symlinks static images into the same directory where generated
 images are written.
 Fixes the docs-install rule
 Simplifies EPUB generation (  References #5422 )
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5422#comment:3>
