[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1087-ga99704884
Fri Jun 30 05:41:24 PDT 2023
the project "PostGIS".
       via  a997048847da8a870414413582d74dfb7d5cf810 (commit)
      from  7e62e02ba017c560dfd7bff682cdcdc701fef7ef (commit)
revisions in full, below.
commit a997048847da8a870414413582d74dfb7d5cf810
Author: Sandro Santilli <strk at kbt.io>
Date:   Thu Jun 29 23:09:48 2023 +0200
    Have woodie build pdf and cheatsheets
    References #5420
diff --git a/.woodpecker/docs.yml b/.woodpecker/docs.yml
index 81e62d4b2..311ed8c3d 100644
--- a/.woodpecker/docs.yml
+++ b/.woodpecker/docs.yml
@@ -1,5 +1,5 @@
 pipeline:
-  build:
+  prepare:
     image: docker.osgeo.org/postgis/build-test:trisquel3
     pull: true
     when:
@@ -7,8 +7,29 @@ pipeline:
     commands:
       - ./autogen.sh
       - mkdir -p build-docs && cd build-docs
-      - ../configure
+      - ../configure --without-pg
+      - make postgis_revision.h
+  build-html:
+    image: docker.osgeo.org/postgis/build-test:trisquel3
+    when:
+      status: [ success ]
+    commands:
+      - cd build-docs
       - make docs
       - make -C doc check
       - make docs-localized
       - make -C doc/ check-localized
+  build-pdf:
+    when:
+    commands:
+      - cd build-docs
+      - make -C doc/ pdf
+  build-cheatsheets:
+    when:
+    commands:
+      - cd build-docs
+      - make -C doc/ cheatsheets
Summary of changes:
 .woodpecker/docs.yml | 25 +++++++++++++++++++++++--
 1 file changed, 23 insertions(+), 2 deletions(-)
hooks/post-receive
