[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-1089-g924567262
Fri Jun 30 07:43:40 PDT 2023
the project "PostGIS".
       via  9245672620f42ee45ce83526a5234771219c073e (commit)
      from  52b6274d323aa43719458537c7972f59591c439c (commit)
revisions in full, below.
commit 9245672620f42ee45ce83526a5234771219c073e
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri Jun 30 16:41:26 2023 +0200
    Fix EPUB build (only in-tree builds)
    Moves all postgis_special entities to top-level file,
    symlink html images dir to make dbtoepub happy.
    Simplify debbie epub generation code
    Closes #5422
diff --git a/.gitignore b/.gitignore
index 196985896..d587553b6 100644
--- a/.gitignore
+++ b/.gitignore
@@ -25,6 +25,7 @@ config.status
 configure
 doc/*.html
+doc/images
 doc/html/images/generator
 doc/html/images/Makefile
 doc/html/images/*.png
@@ -195,6 +196,7 @@ doc/sfcgal_comments.sql
 postgis/sfcgal.sql
 postgis/uninstall_sfcgal.sql
 *.pdf
+*.epub
 .idea/*
 .syntastic_c_config
 .vs/*
diff --git a/ci/debbie/postgis_release_docs.sh b/ci/debbie/postgis_release_docs.sh
index f35539323..40598590c 100644
--- a/ci/debbie/postgis_release_docs.sh
+++ b/ci/debbie/postgis_release_docs.sh
@@ -68,9 +68,6 @@ if [[ "$POSTGIS_MICRO_VERSION" == *"dev"* ]]; then
 fi
 make pdf
-rm -rf images
-mkdir images
-cp html/images/* images
 make epub
 make -e chunked-html-web 2>&1 | tee -a doc-errors.log
diff --git a/doc/Makefile.in b/doc/Makefile.in
index e668f5129..faa417ac1 100644
--- a/doc/Makefile.in
+++ b/doc/Makefile.in
@@ -355,6 +355,7 @@ ifeq ($(DBTOEPUB),)
 	@echo
 	@false
 else
+	ln -fs html/images .; # work around https://trac.osgeo.org/postgis/ticket/5422
 	$(DBTOEPUB) -c "${PWD}/html/style.css" \
 	 -o postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}$(DOCSUFFIX).epub \
@@ -386,6 +387,7 @@ clean:
 	rm -f html/*.html
 	rm -f postgis-${POSTGIS_MAJOR_VERSION}.${POSTGIS_MINOR_VERSION}.${POSTGIS_MICRO_VERSION}.pdf
 	rm -f *.epub
+	rm images # work around https://trac.osgeo.org/postgis/ticket/5422
 	rm -f $(XML_GENERATED_SOURCES)
 	$(MAKE) -C html/images clean
 	rm -f postgis_gardentest_${POSTGIS_MAJOR_VERSION}${POSTGIS_MINOR_VERSION}.sql
diff --git a/doc/postgis.xml b/doc/postgis.xml
index 86325a73d..5ef46561b 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -73,8 +73,20 @@
 <!ENTITY index_aware SYSTEM "tag_index_aware.xml">
 <!ENTITY geography_transform SYSTEM "tag_geography_transform.xml">
-<!ENTITY % postgis_special SYSTEM "postgis_special.ent">
-%postgis_special;
+<!-- entity definitions for the postgis_special section -->
+<!ENTITY postgis_special SYSTEM "postgis_special.xml">
+<!ENTITY list_3d_functions SYSTEM "list_3d_functions.xsl.xml">
+<!ENTITY list_aggregates SYSTEM "list_aggregates.xsl.xml">
+<!ENTITY list_box_functions SYSTEM "list_box_functions.xsl.xml">
+<!ENTITY list_curved_geometry_functions SYSTEM "list_curved_geometry_functions.xsl.xml">
+<!ENTITY list_dump_functions SYSTEM "list_dump_functions.xsl.xml">
+<!ENTITY list_geography_functions SYSTEM "list_geography_functions.xsl.xml">
+<!ENTITY list_new_functions SYSTEM "list_new_functions.xsl.xml">
+<!ENTITY list_polyhedral_geometry_functions SYSTEM "list_curved_geometry_functions.xsl.xml">
+<!ENTITY list_raster_functions SYSTEM "list_raster_functions.xsl.xml">
+<!ENTITY list_sqlmm_functions SYSTEM "list_sqlmm_functions.xsl.xml">
+<!ENTITY list_window_functions SYSTEM "list_window_functions.xsl.xml">
+<!ENTITY table_body_function_support_matrix SYSTEM "table_body_function_support_matrix.xsl.xml">
diff --git a/doc/postgis_special.ent b/doc/postgis_special.ent
deleted file mode 100644
index ae281e661..000000000
--- a/doc/postgis_special.ent
+++ /dev/null
@@ -1,16 +0,0 @@
-<!-- shared entity definitions for the postgis_special section -->
-<!ENTITY postgis_special SYSTEM "postgis_special.xml">
-<!ENTITY list_3d_functions SYSTEM "list_3d_functions.xsl.xml">
-<!ENTITY list_aggregates SYSTEM "list_aggregates.xsl.xml">
-<!ENTITY list_box_functions SYSTEM "list_box_functions.xsl.xml">
-<!ENTITY list_curved_geometry_functions SYSTEM "list_curved_geometry_functions.xsl.xml">
-<!ENTITY list_dump_functions SYSTEM "list_dump_functions.xsl.xml">
-<!ENTITY list_geography_functions SYSTEM "list_geography_functions.xsl.xml">
-<!ENTITY list_new_functions SYSTEM "list_new_functions.xsl.xml">
-<!ENTITY list_polyhedral_geometry_functions SYSTEM "list_curved_geometry_functions.xsl.xml">
-<!ENTITY list_raster_functions SYSTEM "list_raster_functions.xsl.xml">
-<!ENTITY list_sqlmm_functions SYSTEM "list_sqlmm_functions.xsl.xml">
-<!ENTITY list_window_functions SYSTEM "list_window_functions.xsl.xml">
-<!ENTITY table_body_function_support_matrix SYSTEM "table_body_function_support_matrix.xsl.xml">
Summary of changes:
 .gitignore                        |  2 ++
 ci/debbie/postgis_release_docs.sh |  3 ---
 doc/Makefile.in                   |  2 ++
 doc/postgis.xml                   | 16 ++++++++++++++--
 doc/postgis_special.ent           | 16 ----------------
 5 files changed, 18 insertions(+), 21 deletions(-)
 delete mode 100644 doc/postgis_special.ent
hooks/post-receive
