[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-681-gd3cf06c2e
Wed Mar 1 12:36:36 PST 2023
the project "PostGIS".
       via  d3cf06c2e0366ec1e5461b0ed50f4106cbdf44c6 (commit)
      from  9f38f0b082189c5b79b66db71947765aa7e0e6de (commit)
revisions in full, below.
commit d3cf06c2e0366ec1e5461b0ed50f4106cbdf44c6
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Wed Mar 1 12:34:44 2023 -0800
    Add ST_ClusterIntersectingWin and ST_ClusterWithinWin, windowing
    function analogues to ST_ClusterIntersecting and ST_ClusterWithin.
    New functions return a cluster id within the current window partition,
    which should be easier to work with than the large collections
    returned by the older functions.
diff --git a/.gitignore b/.gitignore
index b928337a8..99dfaaeed 100644
--- a/.gitignore
+++ b/.gitignore
@@ -17,6 +17,7 @@ aclocal.m4
 autom4te.cache/
 build/
 build-aux/
+config
 config.log
 config.guess
 config.sub
diff --git a/NEWS b/NEWS
index d24bd9315..30bfa9001 100644
--- a/NEWS
+++ b/NEWS
@@ -16,6 +16,7 @@ xxxx/xx/xx
   - GH703, Add min/max resampling as options (Christian Schroeder)
   - #5336, topogeometry cast to topoelement support (Regina Obe)
   - Allow singleton geometry to be inserted into Geometry(Multi*) columns (Paul Ramsey)
+  - GH721, New window-based ST_ClusterWithinWin and ST_ClusterIntersectingWin (Paul Ramsey)
 * Enhancements *
   - #5194, do not update system catalogs from postgis_extensions_upgrade (Sandro Santilli)
diff --git a/doc/reference_cluster.xml b/doc/reference_cluster.xml
index 860a3f8ec..47db8ceaf 100644
--- a/doc/reference_cluster.xml
+++ b/doc/reference_cluster.xml
@@ -70,6 +70,7 @@
 	  </para></note>
       <para>Availability: 2.3.0</para>
+      <para>&curve_support;</para>
     </refsection>
     <refsection>
@@ -145,16 +146,80 @@ GROUP BY cid;
               <xref linkend="ST_ClusterKMeans"/>,
               <xref linkend="ST_ClusterIntersecting"/>,
               <xref linkend="ST_ClusterWithin"/>
+              <xref linkend="ST_ClusterIntersectingWin"/>
           </para>
 	  </refsection>
     </refentry>
+    <refentry id="ST_ClusterIntersectingWin">
+      <refnamediv>
+        <refname>ST_ClusterIntersectingWin</refname>
+        <refpurpose>Window function that returns a cluster id for each input geometry, clustering input geometries into connected sets.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>integer <function>ST_ClusterIntersectingWin</function></funcdef>
+            <paramdef><type>geometry winset </type> <parameter>geom</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <title>Description</title>
+        <para>ST_ClusterIntersectingWin is a windowing function that builds inter-connecting clusters of geometries that intersect. It is possible to traverse all geometries in a cluster without leaving the cluster. The return value is the cluster number that the geometry argument participates in, or null for null inputs.</para>
+        <para>Availability: 3.4.0</para>
+      </refsection>
+      <refsection>
+        <title>Examples</title>
+        <programlisting>
+WITH testdata AS (
+  SELECT id, geom::geometry FROM (
+  VALUES  (1, 'LINESTRING (0 0, 1 1)'),
+          (2, 'LINESTRING (5 5, 4 4)'),
+          (3, 'LINESTRING (6 6, 7 7)'),
+          (4, 'LINESTRING (0 0, -1 -1)'),
+          (5, 'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))')) AS t(id, geom)
+SELECT id,
+  ST_AsText(geom),
+  ST_ClusterIntersectingWin(geom) OVER () AS cluster
+FROM testdata;
+ id |           st_astext            | cluster
+  1 | LINESTRING(0 0,1 1)            |       0
+  2 | LINESTRING(5 5,4 4)            |       0
+  3 | LINESTRING(6 6,7 7)            |       1
+  4 | LINESTRING(0 0,-1 -1)          |       0
+  5 | POLYGON((0 0,4 0,4 4,0 4,0 0)) |       0
+        </programlisting>
+      </refsection>
+      <refsection>
+        <title>See Also</title>
+        <para>
+            <xref linkend="ST_ClusterDBSCAN" />,
+            <xref linkend="ST_ClusterKMeans" />,
+            <xref linkend="ST_ClusterWithinWin" />
+            <xref linkend="ST_ClusterWithin" />
+            <xref linkend="ST_ClusterIntersecting" />
+        </para>
+      </refsection>
+    </refentry>
     <refentry id="ST_ClusterIntersecting">
       <refnamediv>
         <refname>ST_ClusterIntersecting</refname>
-        <refpurpose>Aggregate function that clusters the input geometries into connected sets.</refpurpose>
+        <refpurpose>Aggregate function that clusters input geometries into connected sets.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -179,10 +244,10 @@ GROUP BY cid;
         <programlisting>
 WITH testdata AS
   (SELECT unnest(ARRAY['LINESTRING (0 0, 1 1)'::geometry,
-		       'LINESTRING (5 5, 4 4)'::geometry,
-		       'LINESTRING (6 6, 7 7)'::geometry,
-		       'LINESTRING (0 0, -1 -1)'::geometry,
-		       'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
+           'LINESTRING (5 5, 4 4)'::geometry,
+           'LINESTRING (6 6, 7 7)'::geometry,
+           'LINESTRING (0 0, -1 -1)'::geometry,
+           'POLYGON ((0 0, 4 0, 4 4, 0 4, 0 0))'::geometry]) AS geom)
 SELECT ST_AsText(unnest(ST_ClusterIntersecting(geom))) FROM testdata;
@@ -199,6 +264,7 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         <para>
         </para>
       </refsection>
@@ -206,6 +272,11 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
     </refentry>
 	<refentry id="ST_ClusterKMeans">
 	  <refnamediv>
 		<refname>ST_ClusterKMeans</refname>
@@ -334,6 +405,8 @@ from
           <para>
               <xref linkend="ST_ClusterDBSCAN"/>,
+              <xref linkend="ST_ClusterIntersectingWin"/>,
+              <xref linkend="ST_ClusterWithinWin" />,
               <xref linkend="ST_ClusterIntersecting" />,
               <xref linkend="ST_ClusterWithin" />,
               <xref linkend="ST_Subdivide" />,
@@ -347,7 +420,7 @@ from
       <refnamediv>
         <refname>ST_ClusterWithin</refname>
-        <refpurpose>Aggregate function that clusters the input geometries by separation distance.</refpurpose>
+        <refpurpose>Aggregate function that clusters input geometries by separation distance.</refpurpose>
       </refnamediv>
       <refsynopsisdiv>
@@ -366,6 +439,7 @@ from
         <para>ST_ClusterWithin is an aggregate function that returns an array of GeometryCollections, where each GeometryCollection represents a set of geometries separated by no more than the specified distance.  (Distances are Cartesian distances in the units of the SRID.)</para>
         <para>Availability: 2.2.0</para>
       </refsection>
       <refsection>
@@ -393,7 +467,77 @@ GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
         <para>
-          <xref linkend="ST_ClusterIntersecting" />
+          <xref linkend="ST_ClusterWithinWin"/>,
+          <xref linkend="ST_ClusterIntersecting"/>
+        </para>
+      </refsection>
+    </refentry>
+  <refentry id="ST_ClusterWithinWin">
+      <refnamediv>
+        <refname>ST_ClusterWithinWin</refname>
+        <refpurpose>Window function that returns a cluster id for each input geometry, clustering using separation distance.</refpurpose>
+      </refnamediv>
+      <refsynopsisdiv>
+        <funcsynopsis>
+          <funcprototype>
+            <funcdef>integer <function>ST_ClusterWithinWin</function></funcdef>
+            <paramdef><type>float8 </type> <parameter>distance</parameter></paramdef>
+          </funcprototype>
+        </funcsynopsis>
+      </refsynopsisdiv>
+      <refsection>
+        <para>ST_ClusterWithinWin is a window function that returns an integer for each input geometry, where the integer the cluster number the geometry is a member of. Clusters represent a set of input geometries separated by no more than the specified distance. (Distances are Cartesian distances in the units of the SRID.)
+        </para>
+        <para>ST_ClusterWithinWin is equivalent to running <xref linkend="ST_ClusterDBSCAN" /> with a `minpoints` of zero.</para>
+      </refsection>
+      <refsection>
+        <programlisting>
+WITH testdata AS (
+SELECT id,
+  ST_AsText(geom),
+  ST_ClusterWithinWin(geom, 1.4) OVER () AS cluster
+FROM testdata;
+        </programlisting>
+      </refsection>
+      <refsection>
+        <para>
+          <xref linkend="ST_ClusterWithin"/>,
         </para>
       </refsection>
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index 71ec5fe47..bf2f94bf3 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -43,6 +43,7 @@ GEOSGeometry* make_geos_point(double x, double y);
 GEOSGeometry* make_geos_segment(double x1, double y1, double x2, double y2);
 int cluster_intersecting(GEOSGeometry **geoms, uint32_t num_geoms, GEOSGeometry ***clusterGeoms, uint32_t *num_clusters);
+int union_intersecting_pairs(GEOSGeometry** geoms, uint32_t num_geoms, UNIONFIND* uf);
 int cluster_within_distance(LWGEOM **geoms, uint32_t num_geoms, double tolerance, LWGEOM ***clusterGeoms, uint32_t *num_clusters);
 int union_dbscan(LWGEOM **geoms, uint32_t num_geoms, UNIONFIND *uf, double eps, uint32_t min_points, char **is_in_cluster_ret);
diff --git a/liblwgeom/lwgeom_geos_cluster.c b/liblwgeom/lwgeom_geos_cluster.c
index 7e1b6f607..091de6bf1 100644
--- a/liblwgeom/lwgeom_geos_cluster.c
+++ b/liblwgeom/lwgeom_geos_cluster.c
@@ -50,7 +50,6 @@ struct STRTree
 static struct STRTree make_strtree(void** geoms, uint32_t num_geoms, char is_lwgeom);
 static void destroy_strtree(struct STRTree * tree);
-static int union_intersecting_pairs(GEOSGeometry** geoms, uint32_t num_geoms, UNIONFIND* uf);
 static int combine_geometries(UNIONFIND* uf, void** geoms, uint32_t num_geoms, void*** clustersGeoms, uint32_t* num_clusters, char is_lwgeom);
 /* Make a minimal GEOSGeometry* whose Envelope covers the same 2D extent as
@@ -155,7 +154,7 @@ query_accumulate(void* item, void* userdata)
 /* Identify intersecting geometries and mark them as being in the same set */
-static int
+int
 	uint32_t p, i;
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index 7a715914e..4fd14199d 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -39,6 +39,8 @@
 extern Datum ST_ClusterDBSCAN(PG_FUNCTION_ARGS);
 extern Datum ST_ClusterKMeans(PG_FUNCTION_ARGS);
+extern Datum ST_ClusterWithinWin(PG_FUNCTION_ARGS);
+extern Datum ST_ClusterIntersectingWin(PG_FUNCTION_ARGS);
 typedef struct {
 	bool	isdone;
@@ -53,13 +55,21 @@ typedef struct
 	char is_null;        /* NULL may result from a NULL geometry input, or it may be used by
 							algorithms such as DBSCAN that do not assign all inputs to a
 							cluster. */
-} dbscan_cluster_result;
+} cluster_entry;
 typedef struct
 	char is_error;
-	dbscan_cluster_result cluster_assignments[1];
-} dbscan_context;
+	cluster_entry clusters[1];
+} cluster_context;
+static cluster_context*
+fetch_cluster_context(WindowObject win_obj, uint32_t ngeoms)
+	size_t context_sz = sizeof(cluster_context) + (ngeoms * sizeof(cluster_entry));
+	cluster_context* context = WinGetPartitionLocalMemory(win_obj, context_sz);
+	return context;
 static LWGEOM*
 read_lwgeom_from_partition(WindowObject win_obj, uint32_t i, bool* is_null)
@@ -79,13 +89,41 @@ read_lwgeom_from_partition(WindowObject win_obj, uint32_t i, bool* is_null)
 	return lwgeom_from_gserialized(g);
+static GEOSGeometry*
+read_geos_from_partition(WindowObject win_obj, uint32_t i, bool* is_null)
+	GSERIALIZED* g;
+	LWGEOM* lwg;
+	GEOSGeometry* gg;
+	Datum arg = WinGetFuncArgInPartition(win_obj, 0, i, WINDOW_SEEK_HEAD, false, is_null, NULL);
+	if (*is_null) {
+		/* So that the indexes in our clustering input array can match our partition positions,
+		 * toss an empty point into the clustering inputs, as a pass-through.
+		 * NOTE: this will cause gaps in the output cluster id sequence.
+		lwg = lwpoint_as_lwgeom(lwpoint_construct_empty(0, 0, 0));
+		gg = LWGEOM2GEOS(lwg, LW_FALSE);
+		lwgeom_free(lwg);
+		return gg;
+	g = (GSERIALIZED*) PG_DETOAST_DATUM_COPY(arg);
+	lwg = lwgeom_from_gserialized(g);
+	gg = LWGEOM2GEOS(lwg, LW_TRUE);
+	lwgeom_free(lwg);
+	if (!gg) {
+		*is_null = LW_TRUE;
+	return gg;
 PG_FUNCTION_INFO_V1(ST_ClusterDBSCAN);
 	WindowObject win_obj = PG_WINDOW_OBJECT();
 	uint32_t row = WinGetCurrentPosition(win_obj);
 	uint32_t ngeoms = WinGetPartitionRowCount(win_obj);
-	dbscan_context* context = WinGetPartitionLocalMemory(win_obj, sizeof(dbscan_context) + ngeoms * sizeof(dbscan_cluster_result));
+	cluster_context* context = fetch_cluster_context(win_obj, ngeoms);
 	if (row == 0) /* beginning of the partition; do all of the work now */
@@ -119,7 +157,9 @@ Datum ST_ClusterDBSCAN(PG_FUNCTION_ARGS)
 		uf = UF_create(ngeoms);
 		for (i = 0; i < ngeoms; i++)
-			geoms[i] = read_lwgeom_from_partition(win_obj, i, (bool*)&(context->cluster_assignments[i].is_null));
+			bool geom_is_null;
+			geoms[i] = read_lwgeom_from_partition(win_obj, i, &geom_is_null);
+			context->clusters[i].is_null = geom_is_null;
 			if (!geoms[i]) {
 				/* TODO release memory ? */
@@ -151,24 +191,165 @@ Datum ST_ClusterDBSCAN(PG_FUNCTION_ARGS)
 			if (minpoints > 1 && !is_in_cluster[i])
-				context->cluster_assignments[i].is_null = LW_TRUE;
+				context->clusters[i].is_null = LW_TRUE;
 			else
-				context->cluster_assignments[i].cluster_id = result_ids[i];
+				context->clusters[i].cluster_id = result_ids[i];
+		lwfree(result_ids);
+		UF_destroy(uf);
+	if (context->clusters[row].is_null)
+		PG_RETURN_NULL();
+	PG_RETURN_INT32(context->clusters[row].cluster_id);
+PG_FUNCTION_INFO_V1(ST_ClusterWithinWin);
+Datum ST_ClusterWithinWin(PG_FUNCTION_ARGS)
+	WindowObject win_obj = PG_WINDOW_OBJECT();
+	uint32_t row = WinGetCurrentPosition(win_obj);
+	uint32_t ngeoms = WinGetPartitionRowCount(win_obj);
+	if (row == 0) /* beginning of the partition; do all of the work now */
+		uint32_t i;
+		uint32_t* result_ids;
+		LWGEOM** geoms;
+		UNIONFIND* uf;
+		bool tolerance_is_null;
+		double tolerance = DatumGetFloat8(WinGetFuncArgCurrent(win_obj, 1, &tolerance_is_null));
+		/* Validate input parameters */
+		if (tolerance_is_null || tolerance < 0)
+			lwpgerror("Tolerance must be a positive number", tolerance);
+			PG_RETURN_NULL();
+		context->is_error = LW_TRUE; /* until proven otherwise */
+		geoms = lwalloc(ngeoms * sizeof(LWGEOM*));
+		uf = UF_create(ngeoms);
+		for (i = 0; i < ngeoms; i++)
+			if (!geoms[i])
+				lwpgerror("Error reading geometry.");
+				PG_RETURN_NULL();
+		initGEOS(lwpgnotice, lwgeom_geos_error);
+		if (union_dbscan(geoms, ngeoms, uf, tolerance, 1, NULL) == LW_SUCCESS)
+			context->is_error = LW_FALSE;
+			lwgeom_free(geoms[i]);
+		lwfree(geoms);
+		if (context->is_error)
+			UF_destroy(uf);
+			lwpgerror("Error during clustering");
+			PG_RETURN_NULL();
+		result_ids = UF_get_collapsed_cluster_ids(uf, NULL);
+		UF_destroy(uf);
+		PG_RETURN_NULL();
+PG_FUNCTION_INFO_V1(ST_ClusterIntersectingWin);
+Datum ST_ClusterIntersectingWin(PG_FUNCTION_ARGS)
+		uint32_t i;
+		GEOSGeometry** geoms = lwalloc(ngeoms * sizeof(GEOSGeometry*));
+		UNIONFIND* uf = UF_create(ngeoms);
+			geoms[i] = read_geos_from_partition(win_obj, i, &geom_is_null);
+			if (!geoms[i])
+				PG_RETURN_NULL();
+		if (union_intersecting_pairs(geoms, ngeoms, uf) == LW_SUCCESS)
+			GEOSGeom_destroy(geoms[i]);
+		lwfree(geoms);
+			UF_destroy(uf);
+			PG_RETURN_NULL();
 		lwfree(result_ids);
 		UF_destroy(uf);
-	if (context->cluster_assignments[row].is_null)
 		PG_RETURN_NULL();
-	PG_RETURN_INT32(context->cluster_assignments[row].cluster_id);
 PG_FUNCTION_INFO_V1(ST_ClusterKMeans);
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ad4477760..082201cf9 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -1883,6 +1883,20 @@ CREATE OR REPLACE FUNCTION ST_ClusterDBSCAN (geometry, eps float8, minpoints int
 	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
 	_COST_HIGH;
+-- Availability: 3.4.0
+CREATE OR REPLACE FUNCTION ST_ClusterWithinWin(geometry, distance float8)
+	RETURNS int
+	AS 'MODULE_PATHNAME', 'ST_ClusterWithinWin'
+	LANGUAGE 'c' IMMUTABLE STRICT WINDOW PARALLEL SAFE
+	_COST_HIGH;
+CREATE OR REPLACE FUNCTION ST_ClusterIntersectingWin(geometry)
+	RETURNS int
+	AS 'MODULE_PATHNAME', 'ST_ClusterIntersectingWin'
+	_COST_HIGH;
 -- Availability: 1.2.2
 CREATE OR REPLACE FUNCTION ST_LineMerge(geometry)
 	RETURNS geometry
diff --git a/regress/core/cluster.sql b/regress/core/cluster.sql
index 7d2c61861..55a548440 100644
--- a/regress/core/cluster.sql
+++ b/regress/core/cluster.sql
@@ -15,6 +15,14 @@ SELECT 't2', ST_AsText(unnest(ST_ClusterIntersecting(array_agg(geom ORDER BY id)
 SELECT 't3', ST_AsText(unnest(ST_ClusterWithin(geom, 1.4 ORDER BY id))) FROM cluster_inputs;
 SELECT 't4', ST_AsText(unnest(ST_ClusterWithin(array_agg(geom ORDER BY id), 1.5))) FROM cluster_inputs;
+SELECT 't5', id, ST_AsText(geom),
+  FROM cluster_inputs;
+SELECT 't6', id, ST_AsText(geom),
 -- tests for ST_DBSCAN
 CREATE TEMPORARY TABLE dbscan_inputs (id int, geom geometry);
diff --git a/regress/core/cluster_expected b/regress/core/cluster_expected
index 46390c9ec..72501347c 100644
--- a/regress/core/cluster_expected
+++ b/regress/core/cluster_expected
@@ -9,6 +9,20 @@ t3|GEOMETRYCOLLECTION(LINESTRING(6 6,7 7))
 t3|GEOMETRYCOLLECTION(POLYGON EMPTY)
 t4|GEOMETRYCOLLECTION(LINESTRING(0 0,1 1),LINESTRING(5 5,4 4),LINESTRING(0 0,-1 -1),LINESTRING(6 6,7 7),POLYGON((0 0,4 0,4 4,0 4,0 0)))
 t4|GEOMETRYCOLLECTION(POLYGON EMPTY)
+t5|1|LINESTRING(0 0,1 1)|0
+t5|2|LINESTRING(5 5,4 4)|0
+t5|3||
+t5|4|LINESTRING(0 0,-1 -1)|0
+t5|5|LINESTRING(6 6,7 7)|2
+t5|6|POLYGON EMPTY|3
+t5|7|POLYGON((0 0,4 0,4 4,0 4,0 0))|0
+t6|1|LINESTRING(0 0,1 1)|0
+t6|2|LINESTRING(5 5,4 4)|0
+t6|3||
+t6|4|LINESTRING(0 0,-1 -1)|0
+t6|5|LINESTRING(6 6,7 7)|2
+t6|6|POLYGON EMPTY|3
+t6|7|POLYGON((0 0,4 0,4 4,0 4,0 0))|0
 t101|1|0
 t101|2|0
 t101|3|0
Summary of changes:
 .gitignore                      |   1 +
 NEWS                            |   1 +
 doc/reference_cluster.xml       | 158 +++++++++++++++++++++++++++++--
 liblwgeom/lwgeom_geos.h         |   1 +
 liblwgeom/lwgeom_geos_cluster.c |   3 +-
 postgis/lwgeom_window.c         | 199 ++++++++++++++++++++++++++++++++++++++--
 postgis/postgis.sql.in          |  14 +++
 regress/core/cluster.sql        |   8 ++
 regress/core/cluster_expected   |  14 +++
 9 files changed, 381 insertions(+), 18 deletions(-)
hooks/post-receive
