[postgis-tickets] [PostGIS] #5352: ST_ClusterRelate(geom, de9impattern)
PostGIS trac at osgeo.org
Wed Mar 1 12:39:14 PST 2023
 Reporter:  pramsey      |      Owner:  pramsey
     Type:  enhancement  |     Status:  assigned
 Priority:  medium       |  Milestone:  PostGIS 3.4.0
Component:  postgis      |    Version:  master
 Keywords:               |
 Much like ST_ClusterIntersecting, but allowing ANY DE9IM pattern to
 determine if a geometry should be added to the cluster. Could be used for
 use cases like "cluster all the houses that share an edge, but not a
 corner", or "cluster all the roads with end-point intersections, but not
 crossing edges".
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5352>
