[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Tue Mar 7 02:06:58 PST 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by strk):
 I've fixed the reference to unexisting variable in all branches from 3.4
 back to 3.0 but I'm not closing this ticket because even without
 referencing the missing variable, given the conditions that seem to have
 been detected by Debbie you should still see error:
 ERROR:  None of the constraints specified could be added.
 It would be nice if you could re-produce the issue.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:15>
