[postgis-tickets] [PostGIS] #5341: debbie failing on raster upgrade from 3.2, 3.1 to 3.4
PostGIS trac at osgeo.org
Mon Mar 13 05:04:36 PDT 2023
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  closed
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:  fixed                  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => fixed
Comment:
 I'm closing as I believe the problem was fixed. Debbie is trouble in other
 ways at the moment so it's not worth waiting for her to re-produce this
 issue. Eventually it can be re-opened.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5341#comment:16>
