[postgis-tickets] [PostGIS] #5354: ERROR: function "_postgis_join_selectivity" already exists with same argument types
PostGIS trac at osgeo.org
Tue Mar 7 19:38:22 PST 2023
argument types
 Reporter:  robe                   |      Owner:  strk
     Type:  defect                 |     Status:  new
 Priority:  blocker                |  Milestone:  PostGIS 3.4.0
Component:  build/upgrade/install  |    Version:  master
 Keywords:                         |
 On my local dump restore test using:
 make check RUNTESTFLAGS="-v --dumprestore"
 , I am getting error
 argument types
 full output is
 Checking for shp2pgsql ... found
 Checking for pgsql2shp ... found
 Checking for raster2pgsql ... found
 Creating database 'postgis_reg-3.4'
 Loading unpackaged components from /projects/postgis/postgis-
 git/regress/00-regress-install/share/contrib/postgis
 Loading PostGIS into 'postgis_reg-3.4'
 Loading Topology into 'postgis_reg-3.4'
 Loading Raster into 'postgis_reg-3.4'
 Loading SFCGAL into 'postgis_reg-3.4'
 Dumping database 'postgis_reg-3.4'
 Dropping db 'postgis_reg-3.4'
 Creating db 'postgis_reg-3.4'
 Restoring database 'postgis_reg-3.4' using postgis_restore.pl
 Converting
 /projects/postgis/tmp/3.4.0dev_pg16_geos3.12_gdal3.4.3w64/postgis_reg-3.4.dump
 to ASCII on stdout...
   Reading list of functions to ignore...
   Writing manifest of things to read from dump file...
 Setting postgis schema to public, as found in the dump  Writing ASCII to
 stdout...
 Done.
  failed (Could not restore postgis_reg-3.4:
 /projects/postgis/tmp/3.4.0dev_pg16_geos3.12_gdal3.4.3w64/regress_log)
 NOTICE:  schema "public" already exists, skipping
 psql:C:/ming64gcc81/projects/postgis/postgis-git/regress/00-regress-
 install/share/contrib/postgis/topology.sql:377: NOTICE:  constraint
 "type_range" of domain "topology.topoelement" does not exist, skipping
 install/share/contrib/postgis/topology.sql:675: NOTICE:  function
 topology.populate_topology_layer() does not exist, skipping
 install/share/contrib/postgis/topology.sql:2927: NOTICE:  aggregate
 topology.topoelementarray_agg(topology.topoelement) does not exist,
 skipping
                      addtosearchpath
  topology has been added to end of database search_path
 (1 row)
 install/share/contrib/postgis/sfcgal.sql:182: WARNING:  there is no
 transaction in progress
 install/share/contrib/postgis/sfcgal.sql:190: WARNING:  there is no
 install/share/contrib/postgis/sfcgal.sql:198: WARNING:  there is no
 SET
 ALTER TABLE
 ALTER TABLE
 ALTER TABLE
 SELECT 8500
 DELETE 8500
 SET
 SET
 SET
 SET
 SET
  set_config
 (1 row)
 SET
 SET
 SET
 SET
 argument types
 Died at ./regress/run_test.pl line 399.
 make: *** [regress/runtest.mk:24: check-regress] Error 3
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5354>
