[postgis-tickets] [PostGIS] #5354: ERROR: function "_postgis_join_selectivity" already exists with same argument types
PostGIS trac at osgeo.org
Sat Mar 18 19:28:42 PDT 2023
argument types
  Reporter:  robe                   |      Owner:  strk
      Type:  defect                 |     Status:  new
  Priority:  blocker                |  Milestone:  PostGIS 3.4.0
 Component:  build/upgrade/install  |    Version:  master
Resolution:                         |   Keywords:
Comment (by robe):
 Gitlab is failing on this test too
 https://gitlab.com/postgis/postgis/-/jobs/3926050433
 psql:/tmp/build/regress/00-regress-
 install/share/contrib/postgis/topology.sql:2938: NOTICE:  aggregate
 topology.topoelementarray_agg(topology.topoelement) does not exist,
 skipping
                      addtosearchpath
  topology has been added to end of database search_path
 (1 row)
 NOTICE:  schema "public" already exists, skipping
 SET
 ALTER TABLE
 ALTER TABLE
 ALTER TABLE
 SELECT 8500
 DELETE 8500
 SET
 SET
 SET
 SET
 SET
  set_config
 (1 row)
 SET
 SET
 SET
 SET
 argument types
 make: *** [/builds/postgis/postgis/regress/runtest.mk:24: check-regress]
 Error 3
 Cleaning up project directory and file based variables 00:01
 ERROR: Job failed: exit code 1
 1mERROR: Job failed: exit code 1
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5354#comment:1>
