[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-684-ga3894467c
Tue Mar 7 21:30:24 PST 2023
the project "PostGIS".
       via  a3894467c6c6ca856a51cf993a4dc19730f42cec (commit)
      from  d048d7448e2735a34b1c813d2f04fd9c0ec5f0e0 (commit)
revisions in full, below.
commit a3894467c6c6ca856a51cf993a4dc19730f42cec
Author: Regina Obe <lr at pcorp.us>
Date:   Wed Mar 8 00:28:40 2023 -0500
    Crash on ST_AsSVG with empties
    References #5350 for PostGIS 3.4.0
diff --git a/doc/xsl/postgis_gardentest.sql.xsl b/doc/xsl/postgis_gardentest.sql.xsl
index 0f14d1dbe..070a2b845 100644
--- a/doc/xsl/postgis_gardentest.sql.xsl
+++ b/doc/xsl/postgis_gardentest.sql.xsl
@@ -10,7 +10,7 @@
 	<xsl:output method="text" />
 	<xsl:variable name='testversion'>3.4.0</xsl:variable>
 	<xsl:variable name='fnexclude14'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
-	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable ST_AsSVG</xsl:variable>
+	<xsl:variable name='fnexclude'>AddGeometryColumn DropGeometryColumn DropGeometryTable</xsl:variable>
 	<!--This is just a place holder to state functions not supported or tested separately -->
 	<xsl:variable name='var_srid'>3395</xsl:variable>
diff --git a/liblwgeom/lwout_svg.c b/liblwgeom/lwout_svg.c
index 5b2ecbde6..fc96c1634 100644
--- a/liblwgeom/lwout_svg.c
+++ b/liblwgeom/lwout_svg.c
@@ -128,14 +128,15 @@ assvg_point(stringbuffer_t* sb, const LWPOINT *point, int circle, int precision)
 	char sx[OUT_DOUBLE_BUFFER_SIZE];
 	char sy[OUT_DOUBLE_BUFFER_SIZE];
+	if ( !lwgeom_is_empty((LWGEOM*)point) ){
+		const POINT2D* pt = getPoint2d_cp(point->point, 0);
+		lwprint_double(pt->x, precision, sx);
+		lwprint_double(-(pt->y), precision, sy);
-	const POINT2D* pt = getPoint2d_cp(point->point, 0);
-	lwprint_double(pt->x, precision, sx);
-	lwprint_double(-(pt->y), precision, sy);
-	stringbuffer_aprintf(sb,
-		circle ? "x=\"%s\" y=\"%s\"" : "cx=\"%s\" cy=\"%s\"",
-		sx, sy);
+		stringbuffer_aprintf(sb,
+			circle ? "x=\"%s\" y=\"%s\"" : "cx=\"%s\" cy=\"%s\"",
+			sx, sy);
@@ -224,7 +225,7 @@ assvg_multipolygon(stringbuffer_t* sb, const LWMPOLY *mpoly, int relative, int p
 static void
 assvg_collection(stringbuffer_t* sb, const LWCOLLECTION *col, int relative, int precision)
-	uint32_t i;
+	uint32_t i; uint32_t j = 0;
 	const LWGEOM *subgeom;
 	/* EMPTY GEOMETRYCOLLECTION */
@@ -232,9 +233,15 @@ assvg_collection(stringbuffer_t* sb, const LWCOLLECTION *col, int relative, int
 	for (i = 0; i<col->ngeoms; i++)
-		if (i) stringbuffer_append(sb, ";");
 		subgeom = col->geoms[i];
-		assvg_geom(sb, subgeom, relative, precision);
+		if (!lwgeom_is_empty(subgeom) ){
+			/** Note the j is to prevent adding a ;
+			 * if the first geometry is empty, but subsequent aren't
+			if (j) stringbuffer_append(sb, ";");
+			j++;
+			assvg_geom(sb, subgeom, relative, precision);
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index fd607f838..55d705187 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1454,6 +1454,9 @@ SELECT
 -- https://trac.osgeo.org/postgis/ticket/5151
 SELECT '#5151', ST_SetPoint(ST_GeomFromText('LINESTRING EMPTY',4326), 1, ST_GeomFromText('POINT(40 50)',4326)) As result;
+-- https://trac.osgeo.org/postgis/ticket/5350
+SELECT '#5350',  ST_AsSVG(ST_GeomFromText('GEOMETRYCOLLECTION (POINT EMPTY, LINESTRING (0 0, 1 1))',4326), 3, 5 );
 -- https://trac.osgeo.org/postgis/ticket/5139
 SET client_min_messages TO ERROR;
 DROP TABLE IF EXISTS a;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 527f84d69..7c2bfbb34 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -462,6 +462,7 @@ ERROR:  LWGEOM_addpoint: Invalid offset
 #4799|{"type": "Feature", "geometry": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:25832"}},"coordinates":[359667,5651729]}, "properties": {"id": 1, "geom1": {"type":"Point","crs":{"type":"name","properties":{"name":"EPSG:3035"}},"coordinates":[4110471,3103061]}}}
 #5008|f|f
 ERROR:  Line has no points
+#5350|M 0 0 l 1 -1
 #5139|100000
 #5139|1000000
 ERROR:  Geometry contains invalid coordinates
Summary of changes:
 doc/xsl/postgis_gardentest.sql.xsl |  2 +-
 liblwgeom/lwout_svg.c              | 27 +++++++++++++++++----------
 regress/core/tickets.sql           |  3 +++
 regress/core/tickets_expected      |  1 +
 4 files changed, 22 insertions(+), 11 deletions(-)
hooks/post-receive
