[postgis-tickets] [PostGIS] #5356: Make the postgis docker images available from docker.postgis.net
PostGIS trac at osgeo.org
Fri Mar 17 01:26:42 PDT 2023
  Reporter:  strk         |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:
 Component:  management   |    Version:
Resolution:               |   Keywords:
Comment (by strk):
 I've done some experiments with HTTP redirects under Apache but are
 currently failing and I run out of time.
 CI showing the failure is here:
 https://github.com/postgis/postgis/pull/722
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5356#comment:1>
