[postgis-tickets] [PostGIS] #5356: Make the postgis docker images available from docker.postgis.net
PostGIS trac at osgeo.org
Fri Mar 17 08:00:16 PDT 2023
  Reporter:  strk         |      Owner:  robe
      Type:  enhancement  |     Status:  new
  Priority:  medium       |  Milestone:
 Component:  management   |    Version:
Resolution:               |   Keywords:
Comment (by robe):
 strk I'm not following what you are doing in that pull request.  You are
 changing the push task which we never use.  The push task is at -
 https://github.com/postgis/postgis-build-env
 But at anyrate, I think we don't need vanity urls for push tasks.  We only
 need vanity for pull, the ones the ci bots and users will be using.  Push
 we probably want to control where we push to.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5356#comment:2>
