[postgis-tickets] [PostGIS] #5360: Cirrus CI failing on proj tests
PostGIS trac at osgeo.org
Tue Mar 21 17:51:06 PDT 2023
 Reporter:  robe       |      Owner:  robe
     Type:  defect     |     Status:  new
 Priority:  blocker    |  Milestone:  PostGIS 3.3.3
Component:  buildbots  |    Version:  3.3.x
 Keywords:             |
 Cirrhus is failing on proj tests on both master and 3.3 branch
   Postgis 3.3.3dev - (0) - 2023-03-22 00:38:04
   scripts 3.3.3dev 0
   GEOS: 3.11.1-CAPI-1.17.1
   PROJ: 9.2.0
   SFCGAL: 1.4.1
  ./regress/core/regress_proj_cache_overflow .. failed (diff expected
 obtained: /tmp/pgis_reg/test_60_diff)
  ./regress/core/regress_proj_4890 .. failed (diff expected obtained:
 /tmp/pgis_reg/test_61_diff)
 Could be an issue with Proj 9.2.0.  I don't think we have any other bots
 running 9.2.0
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5360>
