[postgis-tickets] [PostGIS] #5360: Cirrus CI failing on proj tests
PostGIS trac at osgeo.org
Sun Mar 26 17:21:43 PDT 2023
  Reporter:  robe       |      Owner:  robe
      Type:  defect     |     Status:  new
  Priority:  blocker    |  Milestone:  PostGIS 3.3.3
 Component:  buildbots  |    Version:  3.3.x
Resolution:             |   Keywords:
Comment (by robe):
 I added verbose to the calls.  I think it's the same issue as we were
 having with the GHI images, where adding projsync fixed.
  regress/core/regress_proj_cache_overflow .. failed (diff expected
 obtained: /tmp/pgis_reg/test_60_diff)
 --- ./regress/core/regress_proj_cache_overflow_expected 2023-03-26
 23:07:14.520775000 +0000
 +++ /tmp/pgis_reg/test_60_out   2023-03-26 23:12:05.016264000 +0000
 @@ -1 +1 @@
 -13|147
 +ERROR:  transform: File not found or invalid (1029)
  regress/core/regress_proj_4890 .. failed (diff expected obtained:
 /tmp/pgis_reg/test_61_diff)
 --- ./regress/core/regress_proj_4890_expected   2023-03-26
 23:07:14.520452000 +0000
 +++ /tmp/pgis_reg/test_61_out   2023-03-26 23:12:05.127212000 +0000
 @@ -1 +1 @@
 -4890|POINT(-122.4859 49.4531)
 I'll try to put in a projsync call in there to see if it can be done.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5360#comment:1>
