[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-697-g130741bfe
Fri Mar 31 13:01:25 PDT 2023
the project "PostGIS".
       via  130741bfe3ac7f80744aa570796cba67b7cd0eb3 (commit)
       via  9be511a0523940796d21e4a3e6e72cd4f91f8c75 (commit)
      from  0dae51d2620920f2a21bcb5feaa59b020db83a38 (commit)
revisions in full, below.
commit 130741bfe3ac7f80744aa570796cba67b7cd0eb3
Merge: 0dae51d26 9be511a05
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Mar 31 13:01:14 2023 -0700
    Merge branch 'master-dbscan-interrupt'
commit 9be511a0523940796d21e4a3e6e72cd4f91f8c75
Date:   Fri Mar 31 08:53:52 2023 -0700
    Add an interrupt check in dbscan
diff --git a/liblwgeom/lwgeom_geos_cluster.c b/liblwgeom/lwgeom_geos_cluster.c
index 091de6bf1..c2378bfe4 100644
--- a/liblwgeom/lwgeom_geos_cluster.c
+++ b/liblwgeom/lwgeom_geos_cluster.c
@@ -265,6 +265,9 @@ dbscan_update_context(GEOSSTRtree* tree, struct QueryContext* cxt, LWGEOM** geom
 	cxt->num_items_found = 0;
 	GEOSGeometry* query_envelope;
+	LW_ON_INTERRUPT(return LW_FAILURE);
 	if (geoms[p]->type == POINTTYPE)
 		const POINT2D* pt = getPoint2d_cp(lwgeom_as_lwpoint(geoms[p])->point, 0);
@@ -346,10 +349,16 @@ union_dbscan_minpoints_1(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, doub
 	for (p = 0; p < num_geoms; p++)
+		int rv = LW_SUCCESS;
 		if (lwgeom_is_empty(geoms[p]))
 			continue;
-		dbscan_update_context(tree.tree, &cxt, geoms, p, eps);
+		rv = dbscan_update_context(tree.tree, &cxt, geoms, p, eps);
+		if (rv == LW_FAILURE)
+			destroy_strtree(&tree);
+			return LW_FAILURE;
 		for (i = 0; i < cxt.num_items_found; i++)
 			uint32_t q = *((uint32_t*) cxt.items_found[i]);
@@ -421,11 +430,17 @@ union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double e
 		uint32_t num_neighbors = 0;
+		int rv;
 			continue;
 		/* We didn't find enough points to do anything, even if they are all within eps. */
 		if (cxt.num_items_found < min_points)
Summary of changes:
 liblwgeom/lwgeom_geos_cluster.c | 19 +++++++++++++++++--
 1 file changed, 17 insertions(+), 2 deletions(-)
hooks/post-receive
