[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-39-g9fabbeaee
Fri Mar 31 13:02:55 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  9fabbeaeed3308f08bb200b7e1bd330cec14e817 (commit)
       via  1f354de62877551621d3f7e0db73108f260052f5 (commit)
      from  887efa9ed30f9d2350b58e3a6c9e0e9464df6498 (commit)
revisions in full, below.
commit 9fabbeaeed3308f08bb200b7e1bd330cec14e817
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Mar 31 13:02:48 2023 -0700
    Add news entry for #5363
diff --git a/NEWS b/NEWS
index edc1543d3..3841fe3c4 100644
--- a/NEWS
+++ b/NEWS
@@ -22,6 +22,7 @@ YYYY/MM/DD
   - #5347, _ST_BestSRID crashes on ARM with infinite geometries (Regina Obe)
   - #5331, [postgis_tiger_geocoder] reverse_geocode, prefer addressable ranges
           (Regina Obe, Locance)
+  - #5363, Make ST_ClusterDBScan interruptable (Paul Ramsey)
 PostGIS 3.3.2
commit 1f354de62877551621d3f7e0db73108f260052f5
Date:   Fri Mar 31 08:53:52 2023 -0700
    Add an interrupt check in dbscan
diff --git a/liblwgeom/lwgeom_geos_cluster.c b/liblwgeom/lwgeom_geos_cluster.c
index 7e1b6f607..13de61625 100644
--- a/liblwgeom/lwgeom_geos_cluster.c
+++ b/liblwgeom/lwgeom_geos_cluster.c
@@ -266,6 +266,9 @@ dbscan_update_context(GEOSSTRtree* tree, struct QueryContext* cxt, LWGEOM** geom
 	cxt->num_items_found = 0;
 	GEOSGeometry* query_envelope;
+	LW_ON_INTERRUPT(return LW_FAILURE);
 	if (geoms[p]->type == POINTTYPE)
 		const POINT2D* pt = getPoint2d_cp(lwgeom_as_lwpoint(geoms[p])->point, 0);
@@ -347,10 +350,16 @@ union_dbscan_minpoints_1(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, doub
 	for (p = 0; p < num_geoms; p++)
+		int rv = LW_SUCCESS;
 		if (lwgeom_is_empty(geoms[p]))
 			continue;
-		dbscan_update_context(tree.tree, &cxt, geoms, p, eps);
+		rv = dbscan_update_context(tree.tree, &cxt, geoms, p, eps);
+		if (rv == LW_FAILURE)
+			destroy_strtree(&tree);
+			return LW_FAILURE;
 		for (i = 0; i < cxt.num_items_found; i++)
 			uint32_t q = *((uint32_t*) cxt.items_found[i]);
@@ -422,11 +431,17 @@ union_dbscan_general(LWGEOM** geoms, uint32_t num_geoms, UNIONFIND* uf, double e
 		uint32_t num_neighbors = 0;
+		int rv;
 			continue;
 		/* We didn't find enough points to do anything, even if they are all within eps. */
 		if (cxt.num_items_found < min_points)
Summary of changes:
 NEWS                            |  1 +
 liblwgeom/lwgeom_geos_cluster.c | 19 +++++++++++++++++--
 2 files changed, 18 insertions(+), 2 deletions(-)
hooks/post-receive
