[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-756-gb0d9783f4
Fri May 5 05:53:49 PDT 2023
the project "PostGIS".
       via  b0d9783f417b3116d5624cc060979decacd978ba (commit)
      from  92b7574189989702147ee663a7c33f03008f2d8a (commit)
revisions in full, below.
commit b0d9783f417b3116d5624cc060979decacd978ba
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 5 14:38:22 2023 +0200
    Tweak buffer interrupt test tolerance based on time needed to update temp table
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index c0d6a4fb5..1a1f6682b 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -1,16 +1,35 @@
-CREATE TEMPORARY TABLE _time AS SELECT now() t;
 CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
 AS $$
 DECLARE
   ret TEXT;
   lap INTERVAL;
 BEGIN
+	-- We use now() here to get the time at the
+	-- start of the transaction, which started when
+	-- this function was called, so the earliest
+	-- posssible time
   lap := now()-t FROM _time;
-  IF lap <= tolerated THEN ret := label || ' interrupted on time';
-  ELSE ret := label || ' interrupted late: ' || lap;
+  UPDATE _time SET t = clock_timestamp();
+	-- Increase tolerated value based on some machine-dependent
+	-- timing. This code uses the time it took to update a temporary
+	-- table but we could use something more meaningful, maybe
+	-- finding it in a GUC or something set by a pre-hook
+	tolerated = tolerated + (clock_timestamp()-now());
+  IF lap <= tolerated THEN
+		ret := format(
+			'%s interrupted on time',
+			label
+  ELSE
+		ret := format(
+			'%s interrupted late: %s (%s tolerated)',
+			label, lap, tolerated
   END IF;
-  UPDATE _time SET t = now();
   RETURN ret;
 END;
 $$ LANGUAGE 'plpgsql' VOLATILE;
@@ -25,13 +44,15 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
-UPDATE _time SET t = now(); -- reset time as creating tables spends some
+CREATE TEMPORARY TABLE _time AS SELECT now() t;
 -- ST_Buffer
 SET statement_timeout TO 100;
 select ST_Buffer(g,100) from _inputs WHERE id = 1;
 --( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
 -- it may take some more to interrupt st_buffer, see
Summary of changes:
 regress/core/interrupt_buffer.sql | 33 +++++++++++++++++++++++++++------
 1 file changed, 27 insertions(+), 6 deletions(-)
hooks/post-receive
