[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-758-gbb57343f1
Fri May 5 06:18:42 PDT 2023
the project "PostGIS".
       via  bb57343f1a316d3d838cacb26c92b495365d3751 (commit)
       via  b6f5c74b6ea6a2fc9ac095ca0993434b9efc945c (commit)
      from  b0d9783f417b3116d5624cc060979decacd978ba (commit)
revisions in full, below.
commit bb57343f1a316d3d838cacb26c92b495365d3751
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 5 15:18:08 2023 +0200
    Run ST_Buffer once before moving on with the interrupt test
    This is an attempt to ensure the library is loaded before
    taking the starting time.
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index effde1ca6..54c958e04 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -10,14 +10,6 @@ BEGIN
 	-- posssible time
   lap := now()-t FROM _time;
-  UPDATE _time SET t = clock_timestamp();
-	-- Increase tolerated value based on some machine-dependent
-	-- timing. This code uses the time it took to update a temporary
-	-- table but we could use something more meaningful, maybe
-	-- finding it in a GUC or something set by a pre-hook
-	tolerated = tolerated + (clock_timestamp()-now());
   IF lap <= tolerated THEN
 		ret := format(
 			'%s interrupted on time',
@@ -30,6 +22,8 @@ BEGIN
   END IF;
+  UPDATE _time SET t = clock_timestamp();
   RETURN ret;
 END;
 $$ LANGUAGE 'plpgsql' VOLATILE;
@@ -44,9 +38,9 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
--- Run ST_Buffer once to ensure libary is loaded before
--- taking the time
---SELECT NULL FROM ST_NPoints(ST_Buffer('POINT(0 0)'::geometry, 3, 1));
+-- Run ST_Buffer once to ensure the libary is loaded
+-- before taking the start time
+SELECT NULL FROM ST_Buffer('POINT(0 0)'::geometry, 3, 1);
 CREATE TEMPORARY TABLE _time AS SELECT now() t;
commit b6f5c74b6ea6a2fc9ac095ca0993434b9efc945c
Date:   Fri May 5 15:13:05 2023 +0200
    Report tolerated values in all interrupt tests
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index 57e1ddea4..209847ef5 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -1,22 +1,37 @@
 -- liblwgeom interruption
-CREATE TEMPORARY TABLE _time AS SELECT now() t;
 CREATE FUNCTION _timecheck(label text, tolerated interval) RETURNS text
 AS $$
 DECLARE
   ret TEXT;
   lap INTERVAL;
 BEGIN
+	-- We use now() here to get the time at the
+	-- start of the transaction, which started when
+	-- this function was called, so the earliest
+	-- posssible time
-  IF lap <= tolerated THEN ret := label || ' interrupted on time';
-  ELSE ret := label || ' interrupted late: ' || lap;
+  IF lap <= tolerated THEN
+		ret := format(
+			'%s interrupted on time',
+			label
+  ELSE
+		ret := format(
+			'%s interrupted late: %s (%s tolerated)',
+			label, lap, tolerated
   END IF;
-  UPDATE _time SET t = now();
   RETURN ret;
 END;
+CREATE TEMPORARY TABLE _time AS SELECT now() t;
 -- ST_Segmentize
index 1a1f6682b..effde1ca6 100644
@@ -44,8 +44,11 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
+-- Run ST_Buffer once to ensure libary is loaded before
+-- taking the time
+--SELECT NULL FROM ST_NPoints(ST_Buffer('POINT(0 0)'::geometry, 3, 1));
 -- ST_Buffer
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index 466baa867..22f06afbc 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -1,7 +1,5 @@
 set client_min_messages to WARNING;
 AS $$
 DECLARE
@@ -9,10 +7,21 @@ DECLARE
   lap INTERVAL;
 BEGIN
+		ret := format(
+			label
+  ELSE
+		ret := format(
   END IF;
   RETURN ret;
 END;
@@ -27,7 +36,7 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
  ) foo
-UPDATE _time SET t = now(); -- reset time as creating tables spends some
 -- IM9 based predicates
Summary of changes:
 regress/core/interrupt.sql        | 25 ++++++++++++++++++++-----
 regress/core/interrupt_buffer.sql | 15 ++++++---------
 regress/core/interrupt_relate.sql | 21 +++++++++++++++------
 3 files changed, 41 insertions(+), 20 deletions(-)
hooks/post-receive
