[postgis-tickets] [SCM] PostGIS branch stable-3.1 updated. 3.1.8-15-g61d961d22
Fri May 12 08:35:51 PDT 2023
the project "PostGIS".
The branch, stable-3.1 has been updated
       via  61d961d226fb50beda1620ddcdc55b724b55a9d2 (commit)
       via  eed5b62343d9509c4c96e6e49ab694d289dc8127 (commit)
       via  4d21237a5c340653658d3c0665a795f30b0e60ec (commit)
       via  476f19b458dca25b537e2a6209f7f3b8885785e5 (commit)
      from  16913466438043b5e74570b0e497dd4d72343851 (commit)
revisions in full, below.
commit 61d961d226fb50beda1620ddcdc55b724b55a9d2
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 12 12:28:18 2023 +0200
    Fix 2.5 upgrades with views using geography based ST_Distance
    Include tests
    Closes #5380 in 3.1 branch (3.1.9dev)
diff --git a/NEWS b/NEWS
index d1cb3c3ca..c4b1300c7 100644
--- a/NEWS
+++ b/NEWS
@@ -2,6 +2,8 @@ PostGIS 3.1.9dev
 xxxx/xx/xx
 * Bug Fixes
+  - #5380, Fix 2.5 upgrades with views using geography based ST_Distance
+           (Sandro Santilli)
   - #5338, Dump/Restore of raster table fails on
            enforce_coverage_tile_rast constraint (Regina Obe)
   - #5315, #5318, #5319, #5320, #5342 crashes on infinite coordinates
diff --git a/postgis/geography.sql.in b/postgis/geography.sql.in
index e28ba77bc..12e4035a6 100644
--- a/postgis/geography.sql.in
+++ b/postgis/geography.sql.in
@@ -491,6 +491,7 @@ CREATE OR REPLACE FUNCTION ST_AsGeoJson(text)
 -- Availability: 1.5.0
+-- Replaces ST_Distance(geography, geography) deprecated in 3.0.0
 CREATE OR REPLACE FUNCTION ST_Distance(geog1 geography, geog2 geography, use_spheroid boolean DEFAULT true)
 	RETURNS float8
 	AS 'MODULE_PATHNAME','geography_distance'
diff --git a/postgis/postgis_after_upgrade.sql b/postgis/postgis_after_upgrade.sql
index a2c280216..3c68a0d2c 100644
--- a/postgis/postgis_after_upgrade.sql
+++ b/postgis/postgis_after_upgrade.sql
@@ -191,7 +191,7 @@ DROP FUNCTION IF EXISTS _ST_DistanceRectTree(g1 geometry, g2 geometry);
 DROP FUNCTION IF EXISTS _ST_DistanceRectTreeCached(g1 geometry, g2 geometry);
 -- Deplicative signatures removed
-DROP FUNCTION IF EXISTS ST_Distance(geography, geography);
+DROP FUNCTION IF EXISTS ST_Distance(geography, geography); -- dropped in PostGIS-3.0 (r17300 aka ce70e4906)
 DROP FUNCTION IF EXISTS ST_Distance(geography, geography, float8, boolean);
 DROP FUNCTION IF EXISTS ST_Buffer(geometry, float8, cstring);
 DROP FUNCTION IF EXISTS ST_IsValidDetail(geometry);
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index fb89ce25d..efc4e72c5 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -7,6 +7,7 @@ DROP VIEW IF EXISTS upgrade_view_test_force_dims;
 DROP VIEW IF EXISTS upgrade_view_test_askml;
 DROP VIEW IF EXISTS upgrade_view_test_dwithin;
 DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
+DROP VIEW IF EXISTS upgrade_view_test_distance;
 DROP TABLE upgrade_test;
 -- Drop functions deprecated on upgrade
diff --git a/regress/hooks/hook-before-upgrade.sql b/regress/hooks/hook-before-upgrade.sql
index 913e2728f..279ca368c 100644
--- a/regress/hooks/hook-before-upgrade.sql
+++ b/regress/hooks/hook-before-upgrade.sql
@@ -81,3 +81,12 @@ CREATE VIEW upgrade_view_test_clusterkmeans AS
 SELECT
 	ST_ClusterKMeans(g1, 1) OVER ()
 FROM upgrade_test;
+-- This view uses ST_Distance signatures, available since 1.5.0
+-- NOTE: 3.0.0 changed them to use default arguments
+-- See https://trac.osgeo.org/postgis/ticket/5380
+CREATE VIEW upgrade_view_test_distance AS
+SELECT
+	ST_Distance(g2, g2) geog_dist1,
+	ST_Distance(g2, g2, true) geog_dist2
+FROM upgrade_test;
commit eed5b62343d9509c4c96e6e49ab694d289dc8127
Date:   Fri May 12 17:27:58 2023 +0200
    Test upgrades with views using ST_DWithin and ST_ClusterKMeans
index 1b2706c62..fb89ce25d 100644
@@ -5,6 +5,8 @@ DROP VIEW IF EXISTS upgrade_view_test_subdivide;
 DROP VIEW IF EXISTS upgrade_view_test_union;
+DROP VIEW IF EXISTS upgrade_view_test_dwithin;
+DROP VIEW IF EXISTS upgrade_view_test_clusterkmeans;
@@ -17,3 +19,6 @@ DROP FUNCTION IF EXISTS st_difference_deprecated_by_postgis_301(geometry,geometr
 DROP FUNCTION IF EXISTS st_symdifference_deprecated_by_postgis_301(geometry,geometry);
 DROP FUNCTION IF EXISTS st_unaryunion_deprecated_by_postgis_301(geometry);
 DROP FUNCTION IF EXISTS st_subdivide_deprecated_by_postgis_301(geometry,integer);
+DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography,float8);
+DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
+DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
index 274123988..913e2728f 100644
@@ -66,3 +66,18 @@ SELECT
 	ST_AsKML(g1) as geometry_askml,
 	ST_AsKML(g2) as geography_askml
 FROM upgrade_test;
+-- Add view using ST_DWithin function
+-- NOTE: 3.0.0 changed them to add default params
+CREATE VIEW upgrade_view_test_dwithin AS
+SELECT
+	ST_DWithin(g1::text, g1::text, 1) as text_dwithin,
+	ST_DWithin(g2, g2, 1) as geography_dwithin
+FROM upgrade_test;
+-- Add view using ST_ClusterKMeans windowing function
+-- NOTE: 3.2.0 changed it to add max_radius parameter
+CREATE VIEW upgrade_view_test_clusterkmeans AS
+SELECT
+	ST_ClusterKMeans(g1, 1) OVER ()
+FROM upgrade_test;
commit 4d21237a5c340653658d3c0665a795f30b0e60ec
Date:   Sun Dec 19 22:48:45 2021 +0100
    Replace ST_AsKML deprecated signatures drop with Replaces comments
    Includes regression test
index fa6bd1f92..e28ba77bc 100644
@@ -452,6 +452,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(text)
 -- AsKML(geography,precision)
 -- Changed: 2.0.0 to use default args and named args
+-- Replaces ST_AsKML(geography, int4) deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsKML(geog geography, maxdecimaldigits integer DEFAULT 15, nprefix text DEFAULT '')
 	RETURNS text
 	AS 'MODULE_PATHNAME','geography_as_kml'
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index ea8e27ce5..0f7362c28 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -4764,6 +4764,7 @@ CREATE OR REPLACE FUNCTION ST_AsGML(version integer, geom geometry, maxdecimaldi
 -- Availability: 1.2.2
 -- Changed: 2.0.0 to use default args and allow named args
+-- Replaces ST_AsKML(geometry, int4) deprecated in 2.0.0
 CREATE OR REPLACE FUNCTION ST_AsKML(geom geometry, maxdecimaldigits integer DEFAULT 15, nprefix TEXT default '')
 	RETURNS TEXT
 	AS 'MODULE_PATHNAME','LWGEOM_asKML'
index 6807d6e88..a2c280216 100644
@@ -196,7 +196,6 @@ DROP FUNCTION IF EXISTS ST_Distance(geography, geography, float8, boolean);
 DROP FUNCTION IF EXISTS ST_AsKML(int4, geometry, int4, text);
-DROP FUNCTION IF EXISTS ST_AsKML(geometry, int4);
 DROP FUNCTION IF EXISTS ST_AsGeoJson(int4, geometry, int4, int4);
 DROP FUNCTION IF EXISTS _ST_AsGeoJson(int4, geometry, int4, int4);
diff --git a/postgis/postgis_before_upgrade.sql b/postgis/postgis_before_upgrade.sql
index 5192032b4..00f23a5f3 100644
--- a/postgis/postgis_before_upgrade.sql
+++ b/postgis/postgis_before_upgrade.sql
@@ -191,12 +191,6 @@ SELECT _postgis_drop_function_if_needed
--- FUNCTION st_askml changed to add defaults in 3.0 / r17357
--- These signatures were superseeded
-DROP FUNCTION IF EXISTS st_askml(geometry, integer); -- Does not conflict
-DROP FUNCTION IF EXISTS st_askml(geography, integer); -- Does not conflict
 -- FUNCTION st_buffer changed to add defaults in 3.0
 -- This signature was superseeded
 DROP FUNCTION IF EXISTS st_buffer(geometry, double precision); -- Does not conflict
index 459f80249..1b2706c62 100644
@@ -1,2 +1,19 @@
 DROP VIEW IF EXISTS upgrade_view_test;
+DROP VIEW IF EXISTS upgrade_view_test_overlay;
+DROP VIEW IF EXISTS upgrade_view_test_unaryunion;
+DROP VIEW IF EXISTS upgrade_view_test_subdivide;
+DROP VIEW IF EXISTS upgrade_view_test_union;
+DROP VIEW IF EXISTS upgrade_view_test_force_dims;
+DROP VIEW IF EXISTS upgrade_view_test_askml;
+-- Drop functions deprecated on upgrade
+DROP FUNCTION IF EXISTS st_force3dz_deprecated_by_postgis_301(geometry);
+DROP FUNCTION IF EXISTS st_force3d_deprecated_by_postgis_301(geometry);
+DROP FUNCTION IF EXISTS st_force3dm_deprecated_by_postgis_301(geometry);
+DROP FUNCTION IF EXISTS st_force4d_deprecated_by_postgis_301(geometry);
+DROP FUNCTION IF EXISTS st_intersection_deprecated_by_postgis_301(geometry,geometry);
+DROP FUNCTION IF EXISTS st_difference_deprecated_by_postgis_301(geometry,geometry);
+DROP FUNCTION IF EXISTS st_symdifference_deprecated_by_postgis_301(geometry,geometry);
+DROP FUNCTION IF EXISTS st_unaryunion_deprecated_by_postgis_301(geometry);
+DROP FUNCTION IF EXISTS st_subdivide_deprecated_by_postgis_301(geometry,integer);
index d4bcb8cd6..274123988 100644
@@ -24,3 +24,45 @@ BEGIN
 	END IF;
 END;
 $BODY$ LANGUAGE 'plpgsql';
+-- Add view using overlay functions
+CREATE VIEW upgrade_view_test_overlay AS
+SELECT
+	ST_Intersection(g1, g1) as geometry_intersection,
+	ST_Intersection(g2, g2) as geography_intersection,
+	ST_Difference(g1, g1) as geometry_difference,
+	ST_SymDifference(g1, g1) as geometry_symdifference
+FROM upgrade_test;
+-- Add view using unaryunion function
+-- NOTE: 2.0.0 introduced ST_UnaryUnion
+CREATE VIEW upgrade_view_test_unaryunion AS
+SELECT
+	ST_UnaryUnion(g1) as geometry_unaryunion
+FROM upgrade_test;
+-- NOTE: 2.2.0 introduced ST_Subdivide
+CREATE VIEW upgrade_view_test_subdivide AS
+SELECT
+	ST_Subdivide(g1, 256) as geometry_subdivide
+FROM upgrade_test;
+-- Add view using ST_ForceX function
+-- NOTE: 3.1.0 changed them from taking only geometry
+--       to also take optional zvalue/mvalue params
+CREATE VIEW upgrade_view_test_force_dims AS
+SELECT
+	ST_Force3D(g1) as geometry_force3d,
+	ST_Force3DZ(g1) as geometry_force3dz,
+	ST_Force3DM(g1) as geometry_force3dm,
+	ST_Force4D(g1) as geometry_force4d
+FROM upgrade_test;
+-- Add view using ST_AsKML function
+-- NOTE: 2.0.0 changed them to add default params
+CREATE VIEW upgrade_view_test_askml AS
+SELECT
+	ST_AsKML(g1) as geometry_askml,
+	ST_AsKML(g2) as geography_askml
+FROM upgrade_test;
commit 476f19b458dca25b537e2a6209f7f3b8885785e5
Date:   Fri May 12 15:19:46 2023 +0200
    Encode dependency of postgis.sql on its effective sources
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index 59eb918ad..c34803379 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -240,7 +240,7 @@ postgis_upgrade.sql: postgis_before_upgrade.sql postgis_upgrade.sql.in postgis_a
 # SQL objects are also dependent on postgis_config.h for PostgreSQL version
 $(SQL_OBJS): ../postgis_config.h ../postgis_revision.h
-#postgis.sql.in: sqldefines.h long_xact.sql.in.c geography.sql.in.c
+postgis.sql: sqldefines.h long_xact.sql.in geography.sql.in postgis_brin.sql.in postgis_spgist.sql.in
 uninstall_postgis.sql: postgis.sql ../utils/create_undef.pl
 	$(PERL) ../utils/create_undef.pl $< $(POSTGIS_PGSQL_VERSION) > $@
Summary of changes:
 NEWS                                  |  2 ++
 postgis/Makefile.in                   |  2 +-
 postgis/geography.sql.in              |  2 ++
 postgis/postgis.sql.in                |  1 +
 postgis/postgis_after_upgrade.sql     |  3 +-
 postgis/postgis_before_upgrade.sql    |  6 ----
 regress/hooks/hook-after-upgrade.sql  | 23 ++++++++++++
 regress/hooks/hook-before-upgrade.sql | 66 +++++++++++++++++++++++++++++++++++
 8 files changed, 96 insertions(+), 9 deletions(-)
hooks/post-receive
