[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-808-g6080076af
Fri May 12 13:13:55 PDT 2023
the project "PostGIS".
       via  6080076af801c1b13f1a6bafa88d5ef41b1cf0a3 (commit)
      from  08ede3e3f105c4e0116125d47a4d34c83487a5ff (commit)
revisions in full, below.
commit 6080076af801c1b13f1a6bafa88d5ef41b1cf0a3
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 12 22:13:38 2023 +0200
    Fix upgrade test by dropping deprecated function after upgrade
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index b639ff77c..51faf3ef5 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -24,3 +24,4 @@ DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geography,integer);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography,float8);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
 DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
+DROP FUNCTION IF EXISTS st_distance_deprecated_by_postgis_300(geography,geography);
Summary of changes:
 regress/hooks/hook-after-upgrade.sql | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
