[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-57-gb3d40cb28
Fri May 12 13:14:50 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  b3d40cb28175a37bbb4a51a752930447f045b959 (commit)
      from  faa957cf3926e1f890e6b3d892bfe27bf5493ff9 (commit)
revisions in full, below.
commit b3d40cb28175a37bbb4a51a752930447f045b959
Author: Sandro Santilli <strk at kbt.io>
Date:   Fri May 12 22:13:38 2023 +0200
    Fix upgrade test by dropping deprecated function after upgrade
diff --git a/regress/hooks/hook-after-upgrade.sql b/regress/hooks/hook-after-upgrade.sql
index b639ff77c..51faf3ef5 100644
--- a/regress/hooks/hook-after-upgrade.sql
+++ b/regress/hooks/hook-after-upgrade.sql
@@ -24,3 +24,4 @@ DROP FUNCTION IF EXISTS st_askml_deprecated_by_postgis_200(geography,integer);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(geography,geography,float8);
 DROP FUNCTION IF EXISTS st_dwithin_deprecated_by_postgis_300(text,text,float8);
 DROP FUNCTION IF EXISTS st_clusterkmeans_deprecated_by_postgis_302(geometry,integer);
+DROP FUNCTION IF EXISTS st_distance_deprecated_by_postgis_300(geography,geography);
Summary of changes:
 regress/hooks/hook-after-upgrade.sql | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
