[postgis-tickets] [SCM] postgis.net annotated tag clarity-final created. clarity-final
Fri May 12 16:09:59 PDT 2023
the project "postgis.net".
The annotated tag, clarity-final has been created
        at  837d235ff3536b8ece630c09cd9446c61ec28b1e (tag)
   tagging  5cef5d3b6178b2952d68660870b4a3fc0f351b9a (commit)
 tagged by  Paul Ramsey
        on  Fri May 12 16:09:41 2023 -0700
The last commit on the old clarity theme
Darafei Praliaskouski (7):
      Release 3.1.0alpha1
      fix markup in last post
      Release 3.0.1
      Fix link to pdf docs
      fix indents
      fix bold
      fix NEWS link
Leo Hsu and Regina Obe (1):
      Update windows summary versions of stuff
Nicklas Avén (4):
      add 2 case studies
      minor fixes from author
      rémi cura, user story for the web
      Changed title per author request
Paul Ramsey (131):
      Add a web site area
      Early cut of piecrust web site
      Add instructions
      Make h1 really noticeable
      Maybe a little less color
      Bluish border
      Another try at the headers
      Final answer on headers?
      OK, one more tweak
      Make a sub-directory to see how that goes
      Add another case study to test post paging.
      Add handling for post thumbnails in listings and consolidate post/casestudy template
      Add an infoterra thumbnail
      Add favicon
      Minor edits
      Properly format the blog page and clean up the front page
      Add pgcon, shrink logos
      Update download informations
      Update documentation page
      Add in more installation material and put postgis.version into site config
      Add thumbnails to partial post
      Add images to infoterra case study
      Add piecrust right into repository, index file, htaccess file, ready for deploy
      Add MCA
      Add in historical news items to posts archive
      Update front page graphics
      Make blog links land somewhere
      Make sitemap home link cleaner
      Rename docs to documentation again
      Reord docs and update links to new paths
      Bold to italic
      Remove developer doc link on dev page, there's on on doc page
      Rewording
      Enable site caching
      Bold
      Make home page title = 'PostGIS' and menu bar slightly narrower
      Enhance the description line a little
      Add keywords to html
      Add robots meta line
      Remove synerror in tag
      Avoid error on servers that don't support gzip
      Add google analytics to site
      Remove JDBC stuff that shouldn't be at the top of the install section.
      Don't have optional wierd stuff in what is supposed to the simplest most basic eexample.
      Switch doco URLS to doc-x.y
      add missing geshi end tag
      Bias towards unversions links
      Move docs links out of front-page space
      use sitewide source url
      use sitewide download url
      Refer to osgeo services in old posts
      fix pramsey email
      Fix typo
      Remove past events
      Fix up info on exclusion
      twitter bug
      2.0.4 release announcement
      Bold
      4 not 3
      OpenGeo>Boundless
      Update other links
      Fix sp (#2525)
      Release 2.1.1
      Add homebrew bullet
      update events a bit
      Update cookbook info
      2.0.5 and 2.1.1 announcements
      Push site version forward
      Nicer logos
      2.1.5 release
      Add FDW blog post
      Fix numbered list alignment
      2.1.6 announcement
      Link to new 2.0 release
      Update download links etc for 2.1.7 source
      Add 2.1.7 / 2.0.7 release announce
      typo
      remove amp
      2.1.8 release
      Add RC1 link
      RC1 release notice
      News post on 2.2.0 release
      Slight format fix
      Refresh events list
      Use shorter link text for nicer pages
      Add new piecrust and some changes to support
      Remove base rewrite line
      Add 2.2.2 release page
      err
      Links to tickets
      tickets as links
      Ignore build artifacts
      Update 2.1 source link
      2.1.9 release posting
      En-linkify ticket entries in recent release posts
      Add book to books section
      Short posting on patch releases
      Make all version refs be macro driven for download of current stable
      update dev tarbal links
      Fix link in 2.2.6 news
      2.3.5 and 2.4.2 release
      2.4.5 release
      Update default version number
      Update dev version number
      Change ugly formatting choice
      Add 2.4.5 post
      typo
      Make 2.4.5 the next source download
      Merge branch 'master' of https://git.osgeo.org/gogs/postgis/postgis.net
      Add 2.5 stable branch
      Link to workshop more prominently
      Change to modern analytics script
      More modern and responsive CSS
      Merge branch 'master' of https://git.osgeo.org/gitea/postgis/postgis.net
      More modern CSS
      slightly smaller h1
      Add hover to menu buttons
      Wrap pre blocks
      Blue up the hover a little
      Give back a little more margin space in mobile width
      Add Crunchy to support list
      Better narrow header
      Thin the mobile header a little
      Slightly larger buttons
      Remove link that no longer provides a download
      Clean out old events
      Change pgsv to foss4g
      update links to 2.5.4 and release notes
      fix dev tarball link
      2.5.4 release post
Regina Obe (862):
      fix download link, add 1.5.6 release
      flesh out doc page a bit -- lots more work needed
      Add support page still need to link it somewhere
      put minimialist install instructions, define new balanced 2 column layout
      more fill in of install links
      add link to windows download, add 2.0.1 news item, update download links
      reverted some change messed up 2 column on home page
      content edits -- add links to download, new mailing list
      1.5.7 release notes. someday maybe we can be more organized :)
      oops missed some edits
      start of winodws download specific page
      this was technically 10/30 no matter what pramsey says
      ecape _ for some reason they were going cut off in bash mode
      minor edits, change tag line -- PostGIS isn't just for geographic anymore (it is Post GIS)
      add 1.5.8 release notes
      2.0.2 release notes
      Begin lame attempt at trying to setup versioning for docs/tars/windows builds (pramsey help :) )
      change page name of documentation to docs so doesn't conflict with documentation folder
      revert changes -- accidentally committed my local experimental stuff
      add doxygen link and repoint dev to local
      Get rid of doc rewrite rule didn't work
      add raster and topology sections to development doc
      link to developer doxygen documentation
      link to other lang versions in progress
      fix doc link
      repoint tagged 2.0 docs to local
      link to direct stackexchange postgis tag, fix 2.0 doc link
      more cleanup of paths and add link to pdf for released version
      fix doco path
      more path fixes and add interim pdf builds
      repurpose blog posting system for bot posting (will make winnie live first). 1950 is the year of the ro-bots :)
      Winnie: new build update
      change docs to use post system -- which will eventually be updated by debbie (once I figure out how to sed things), cleanup windows page a bit.  Stable is barren but will change that to use posts as well.
      Add support to site map, tidy up support and documentation page a bit
      oops used non-existent yaml arg to go to changeset change release to revision
      get rid of more link - that was over the top
      windows instructions taking way too much space on installer page and should be on windows page anyway. Moved
      delete versions folder -- will be using blog postgins to keep track of versions
      make it clear install page also has download links -- how are package maintainers supposed to know, needed to make more space on nav bar to fit extra words.  Add 2.1. development release to yaml and link ot install. pramsey probably fuming now
      remove redundant links and move missplaced sentence
      cleanup support
      fix docu path update revision.  Some reason paths were right on my test instance, but not on prod
      fix revision number
      get rid of dupe file and update new file
      manual update until have debbie able to do this on her own
      experiment with device scaling for better smart phone friendliness
      revert last change
      move doxygen link to developer side
      move source to separate page from install.  Sorry this scrolling is driving me nuts. Also change cpomilation instructions from windows page to more generic page where links to bunch of OS specific compilation instructions are
      reword
      Replace blog with support on top nav, move blog link to home page
      oops broke development by accident moving doxygen.  Fix.  Move bug reporting to where it belongs -- IN SUPPORT and balance out remaining columns on development
      add some words to source download
      get rid of trac link and revision number so doco section is less busy looking. More instructions for the adventurous windows user who doesn't want to mess up an existing installation.
      Add irc channel
      don't show the stable branches in development section -- and put a note on released that it contains errata since release. Already switched debbie jobs to output branch docs instead of tagged docs.
      fix typo
      Less is more get rid of reference links for relesed and only keep for dev (per strk suggestion), strip off svn from stable PDF versions
      fix documentation link and replace blog link with Planet PostGIS
      spell out Planet PostGIS
      point at local 1.3 docs
      check php settings
      display errors to check what is wrong
      take out debugging.  not showing anything useful and still getting 500 in access logs
      clarification and content updates
      Add search docs google search feature
      update to include links to released postgis 2.0 docs (both pdf and html) for package managers who really want the released rather than just the stable.
      define variable place holders for release dev docs, revise links to use these and add link download for released 1.5.8, add raster as keyword
      fix typo
      need to add some umph to description - why PostGIS is the best spatial database ever
      now we are on a roll
      minor not on 3d-spatial index
      git-svn-id: https://svn.osgeo.org/postgis/web@11017 b70326c6-7e19-0410-871a-916f4a2858ee
      revise to have page use page description if present
      put descriptions on pages
      more descriptions so all our pages don't lok the same on google
      git-svn-id: https://svn.osgeo.org/postgis/web@11021 b70326c6-7e19-0410-871a-916f4a2858ee
      link to jdbc put in description and keywords for page
      fix typo in path
      change to use page specific keywords if available
      write old location seems to have gotten indexed
      fix typo in redirect
      more 404 crawl fixes
      make book section it's own and add PostGIS 2 recently published spanish book
      standardize caps and name our primary competitors
      microdata
      revise so tags in blog posts are used for keywords
      add some semantic web goodness to PSC
      It is better to have no description (and have google infer a description), than to have all pages have the same description
      semantic tags
      fix dupe tag
      more semantic tags
      more semantic tagging
      put doc links back to the good old-fashioned way
      manually update revision number for now until I have this automated
      remove r version since its not automatically updated yet so misleading
      extra note on bug reporting to output version of PostgreSQL and postgis
      move Faunalia up, they are more active in PostGIS support
      wording changes
      2.0.3 release notes
      minor corrections
      update bot package list
      minor corrections and addition of packaging
      put warning about original -1
      git-svn-id: https://svn.osgeo.org/postgis/web@11169 b70326c6-7e19-0410-871a-916f4a2858ee
      git-svn-id: https://svn.osgeo.org/postgis/web@11172 b70326c6-7e19-0410-871a-916f4a2858ee
      move laundry list of PostGIS features to separate page to keep home page more balanced
      add some meat to features page
      Add ETL section
      fix typo
      fix some spelling and grammar
      more grammar cleanup
      git-svn-id: https://svn.osgeo.org/postgis/web@11265 b70326c6-7e19-0410-871a-916f4a2858ee
      git-svn-id: https://svn.osgeo.org/postgis/web@11266 b70326c6-7e19-0410-871a-916f4a2858ee
      links to more info on OGC web services
      minor edits
      git-svn-id: https://svn.osgeo.org/postgis/web@11270 b70326c6-7e19-0410-871a-916f4a2858ee
      release of pgoruitng 64-bit and 32-bit experimental binaries for windows -- yeh
      fix typo
      add pgrouting as related project
      oops licensing info missing
      Link to FAQ
      fix minor typos
      really got to try MapGuide OpenSource looking pretty cool. Add to list of PostGIS mapserver supporters
      git-svn-id: https://svn.osgeo.org/postgis/web@11303 b70326c6-7e19-0410-871a-916f4a2858ee
      winnie is now shipping 1.10.0 GDAL with 2.1
      link to epub doc
      beta2 release notes bump trunk
      cleanup to use yaml variables
      formatting cleanup
      git-svn-id: https://svn.osgeo.org/postgis/web@11446 b70326c6-7e19-0410-871a-916f4a2858ee
      fix formatting
      escape _s
      git-svn-id: https://svn.osgeo.org/postgis/web@11451 b70326c6-7e19-0410-871a-916f4a2858ee
      fix typo
      link to 9.3 windows downloads
      add windows pgRouting 2.0 notes
      Add Bborie to PSC list
      clarify that unreleased versions DO NOT contain PostgreSQL
      link to EnterpriseDb  site zip binaries
      1.07 has been superceded by 2.0 dev
      update package details
      update instructions for pgrouting
      fix some embarrassing typos
      update trunk to 2.2
      beta3 release notes
      git-svn-id: https://svn.osgeo.org/postgis/web@11570 b70326c6-7e19-0410-871a-916f4a2858ee
      update to reflect beta3 is latest version
      announce 2.1.0 rc1
      update windows build details
      git-svn-id: https://svn.osgeo.org/postgis/web@11667 b70326c6-7e19-0410-871a-916f4a2858ee
      release of postgis 2.1.0 rc2
      escape underscores
      escape underscores
      over replaced
      put in code block the alter extension
      git-svn-id: https://svn.osgeo.org/postgis/web@11733 b70326c6-7e19-0410-871a-916f4a2858ee
      add a how to submit a patch section
      release notes and bump stable to 2.1.0
      minor edit
      typo correction
      fix formatting
      escape _
      escape _
      move 2.1 to stable section
      correct links to pdfs and update download
      first attempt at rss feed
      fix filter condition
      limit 10 last 10 entries
      test out tips
      fix link to tip category
      fix duplicate text
      filtering is missing tips, just have list last 10 blog entries
      add an example one for geog and one for geometry
      change to output blog author and put continue reading (can't get the darn thing to hyperlink)
      fix formatting so hopefully page break works
      change to use markdown which doesn't strip _
      fix page breaks
      clean up formatting and page break
      update to include address_standardizer
      git-svn-id: https://svn.osgeo.org/postgis/web@11858 b70326c6-7e19-0410-871a-916f4a2858ee
      mention of address_standardizer
      fix links
      add ST_DWithin tip
      fix underscores
      new line
      make formatting prettier
      fix page break by adding new line. god some day I'll make sense of these random formatting issues
      rephrase continue more link
      update to refelct we compile against 9.3 rc1 now.
      Add another tip to the tip jar and add function tags to existing tips.
      revise title
      Add UbutuGIS to list of install offerings
      fix ubuntugis hyperlink
      add optional tiger_geocoder and postgis_topology  extensions.  Makes page more balanced
      #2475: put doco links on news and source page after crating docs.
      update version information
      more version updates
      #2480 wording changes as suggested by darkblueb
      update windows docs for 2.1
      update on stackbuilder for 9.3 and also minor typos
      update postgresql group apt get status
      faq tip
      fix page break
      bump to 2.1.1dev
      update to reflect 2.1.1 now comes with 2013
      update mail list link to Matthew Baker's latest mailing list post.  He said he'd provide a more thorough in wiki later.
      bump to 2.1.2
      update to windows packages
      this was a typo actually can't build with GDAL 1.10.1
      Link Korean PostGIS 2.0 docs
      fix path typo
      add postgis day link to video
      fix title
      add links to people's blogs
      update book list and cheatsheet list
      add link to irc transcript
      Add link to PostGIS transifex page
      add Polish and Spanish to list
      update stable versions on windows page
      update with Matt Baker's link to latest install notes in wiki for Ubuntu Apt. Also link to all install guides
      update 2.1 to not have root so has latest pdf (changed bot job already to strip the micro)
      update cheat sheets to point to 2.1 versions, add more descript of books
      add link to OpenSUSE 2.1
      notice that winnie is down at the moment
      Get rid of site is down message.  Building postgis is working again on windows.  still need some paths to clear but website download is available again.
      doing faster intersections
      Add TileMill to list of desktop tools
      put in guid see if fixes planetpostgresql issue.
      Add author tag to satify planetpostgresql author filter feature
      failed validation -- author tag only supported in atom feeds (not rss).  Switched to atom format.
      oops link tag wrong for atom -- fix
      convert date to atom format.  get rid of tags not supported in atom
      add back in updated field
      update windows versions.  Update yum instructions with link to more detailed.
      update to 2.1.2 will update again after have 9.2 packaged
      more updates
      update to reflect installers now up on stackbuilder
      Add PostgreSQL 9.4beta1 to menu of windows builds
      update windows to 2.1.3
      put flash note about 32-bit 9.4 and update version on 2.1
      add 2.1.3 for PostgreSQL 9.4beta1 w64
      get rid of notice about pg 9.4beta1 32-bit.  Issues have been resolved :)
      bah pgrouting for 9.4beta1 32-bit compiles but fails to load.  Put a note about that.
      take off note about pgrouting issue with 9.4beta1 32-bit.  Issue fixed.
      swap out pgcon which has passed with Postgres Open which is coming in september, update windows downloads that 2.1.3 is available on stackbuilder
      add upgrade instructions, point out some stumbling blocks people run into
      Add PostgreSQL Sessions conference (sept 25th)
      Add that 9.4 beta is built with SFCGAL support
      replace opengeo link with boundlessgeo link
      update sfcgal info for windows
      update book release expected date
      add doxygen 2.1 link
      update to reflect we are now compiling against 9.4beta2
      Add 2.1.4 and 2.0.7 stable snapshots (people really need them)
      PostGIS 2.1.4 release notes
      change stable to 2.1.4
      bah stable branch hard-coded -- flip to 2.1.5dev
      Get rid of hardcoding of postgis version in alter scripts
      update windows package details and also reflect 9.3 x32 is now built with SFCGAL
      add 2014 to tiger list
      update events section
      git-svn-id: https://svn.osgeo.org/postgis/web@13001 b70326c6-7e19-0410-871a-916f4a2858ee
      fix typo
      minor edits and corrections
      update timeline move PostGIS in Action to end since still not officially out.
      add postgis day move down postgresql sessions
      add extra tags to tip posts
      front page unbalanced, increase news count to 4 so balances better with right column
      update GDAL and put note about windows xp lack of support in EDB
      Add links to fr and es translations
      Update link to transifex since Georege renamed it from postgis-1 to postgis
      add es and pl languages (will add ko next after done first building of first version)
      add Avid Geo conference
      gett rid of related postgis day image.  Giving a 404
      move out postgis day events, minor formatting changes
      add mention of osm2pgrouting
      fix some typos more descriptions about osm2pgrouting
      update upcoming events list
      update info on PostGIS 2.1.5
      note about packaging messup on PostgreSQL 9.4 postgis
      update that 9.3 installers available
      minor edits
      update to reflect 9.2 x32 has been added to stackbuilder
      Add link to FOSS4G Europe
      move foss4gna2015 to past events, add pgconf us 2015 to upcoming
      update events list
      git-svn-id: https://svn.osgeo.org/postgis/web@13422 b70326c6-7e19-0410-871a-916f4a2858ee
      update windows status for 2.1.7
      update PostGIS in Action 2nd book state
      FAQ about enabling raster drivers
      change order of contributors to better reflect current weight of PostGIS developers/contributors.
      more verbiage of what companies do
      link to postgis built jdbc related jar files for latestst release
      update branch 2.2 details
      Link to PostGIS java new home
      change 2.1 stable branch to 2.1.9dev
      Take off JDBC links for now, will replace with new one once we have new binaries and perhaps have a dedicated page for PostGIS java
      update to reflect 2.1.8
      add update about pgrouting 2.1 and update postgis 2.2 detail
      put notice about 2.1.8 64-bit binaries available for 9.2 and how need to use this for newer 9.2 micros
      update that 9.4 windows 2.1.8 is available on stackbuilder
      move foss4g europe to past events.
      update pgRouting notice to reflect pgRouting 2.1.0 for windows is available.
      update version for 2.0 (now 2.0.1)
      more updates
      Add osm2pgrouting update
      update to reflect windows binaries for 2.2.0rc1 and SFCGAL 1.2.0 and GEOS 3.5.0 are out
      update to reflect 2015
      update to reflect RC1 rebuilt with gDAL 2.0.1 (that includes curl support)
      update version info in windows experimental
      add sfcgal
      get rid of coming soon translation and replace with link to transifex postgis project
      add family of related PostGIS dependent extensions not packaged with PostGIS
      add in install of additional extensions packaged with PostGIS 2.2.0
      change manual-dev links to manual-2.2 (manual-dev will soon point to 2.3)
      update doc versions
      fix links to raster functions
      add 9.2 notes
      update what's coming in PostGIS 2.2. windows bundle
      forgot to mention SQLite suport that is used by geopackage and many other drivers
      update doxygen links
      add in note that 2.2.0 will be packaged with pgpointcloud and also ogrfdw
      update to reflect that 9.4 64-bit is out.
      it includes (not will include)
      put in links to related extensions
      announce that 64-bit is up too.
      update to reflect 9.5 offerings.  Fix typo
      update to reflect 9.5 is out
      #3334: debian install corrections from Sebastiaan Couwenberg
      instructions about getting help on windows installers / binaries
      update to include 9.4 32-bit 2.2.0 is now on stack builder
      update that 9.3 32-bit 2.2 is now available
      update version onf postgis 2.2, add winnie's badges
      will be changing 2.1 to use GEOS 3.5 instead of 3.4.2
      note about PostGIS sfcgal extension
      fix path slashes should be unix not windows slash
      display author name in meta data of post
      update what is in the 2.1.9dev windows package
      minor updates, add windows 2.3 and windows build badge for 2.3
      change to reflect it's not sfcgal released, but sfcgal master branch
      change to say 1.2.2+ for SFCGAL
      update to reflect winnie's 9.5 builds are now compiled against 9.5beta2
      update postgresql 9.5beta2x64 release
      minor cleanup and add that have binaries for 9.5beta2 32-bit
      add postgresql 9.5beta2 32-bit postgis 2.2.0 bundle to released section
      gett rid of no longer true statements and do other cleanup.
      more missed spots for 32-bit PostgreSQL
      Fix links for iwnnies package badges needed because job names got standardized to mirror svn branch names
      Add PgConf Us NY to upcoming events
      update to reflect now compiled against 9.5rc1
      News releast for PostGIS 2.2.1
      update version numbers
      Put PostGIS in title of blog post.  Looks redundant but looks funny in planet rss feeds without it.
      Add PostGIS 2.2.1 release notice and that PostgreSQL 9.5 upgraded from 9.5beta2 to 9.5.0
      update 2.2.1 release details
      link to downloads
      fix grammar
      fix typo in development snapshot path
      fixed stable branch snapshot links.
      replace stuff, with postgis.dev_download path so more manageable.
      Update to include 9.4
      Fix version number
      update to reflect compiled against released PostgreSQL 9.5
      update instructions to point at new PostGIS 2.2 instructions.
      Link to newer Yum instructions.  Also note that sfcgal not always available
      minor verbiage change
      add new pgRouting 2.2 (now in alpha)
      update to reflect have binaries for pgRouting 2.2.0 alpha
      Update to reflect now building with SFCGAL 1.3+
      ST_Reclass tip
      minor formatting fix
      more formatting fixes
      more formatting cleanup
      bump of released version to 2.2.2
      University of Chicago (Pleanario project) - Case study provided by William Engler
      Correction from Will
      Amend had wrong version header
      git-svn-id: https://svn.osgeo.org/postgis/web@14815 b70326c6-7e19-0410-871a-916f4a2858ee
      update version info
      fix some typos
      Nautilytics case studies
      update to reflect pgRouting 2.2.0 is released
      Update that PostGIS 2.2.2 for PostgreSQL 9.5 is up on stackbuilder with fix for incompatibility with lastes PostgreSQL EDB release
      fix bold issue
      add japanese and reodrder others based on order of translation completeness
      add Korean
      move pgconf2016 into past events
      move FOSS4GNA 2016 to past events
      Add 9.6  binaries listing.  Minor corrections to existing.
      fix link to 9.6 folder
      update to reflect pgRouting 2.2 now available for PostgreSQL 9.6
      update GDAL version info
      fix link to support page
      Add Postgres Open 2016
      update to reflect postgis 2.2.2 updates
      Add PgConf SV, remove Foss4G EU
      update 9.6 now compiled against beta2 instead of beta1
      missed a spot
      change to PostgreSQL 9.6 beta3
      winnnie now compiles against PostgreSQL 9.6 beta4
      2.3.0beta1 release notes fix some minor issues with other notes
      fix typo
      more typos
      fix formatting
      Fix news file link closes #3624
      now compiled against PostgreSQL 9.6rc1
      more event updates
      update to GDAL 2.1.1
      PostGIS 2.3.0rc1 release
      PostGIS 2.3.0 release announcement
      break into 2 parts.  fix syntax mangling
      git-svn-id: https://svn.osgeo.org/postgis/web@15151 b70326c6-7e19-0410-871a-916f4a2858ee
      get rid of extra bug fix section and move up
      update trunk docs
      update to reflect now compiled with PostgreSQL 9.6.0
      update to reflect stack builder for 2.3.0 available for 64-bit versions
      update notes to reflect PostgreSQL 9.6 32-bit now on stackbuilder
      32-bts for 2.3.0 now on stackbuilder
      PostGIS 2.2.3 announcement
      missed last commit
      download links for 2.2.3
      links for 2.2.4dev
      Add OpenSCG BigSQL, and EDB PostgreSQL distribution to list of binary installers.
      PostGIS 2.3.1 release
      Escape _
      Fix some typos
      Fix some typos
      Update to reflect windows postgis 2.3.1 bundle installers are coming and binaries available
      Update to reflect windows postgis 2.3.1 bundle installer availability, and GEOS version.
      Update events
      correct pgconfus link
      PostGIS 2.2.5 release
      PostGIS 2.3.2 release
      Add Postgres Vision conference
      Updat windows binary descriptions
      Updat windows binary descriptions to mention now with protobuf support
      Update install instructions
      Update events
      Add PGConf Local US Seattle
      Add PGConf Local US PA and revise link for Seattle
      Update windows page to include offering of PostgreSQL 10beta1 binaries
      Update events
      Update upgrade instructions, they are a bit messed up _ got stripped.
      New tip article on how to recover from postgis.backend in use.
      Add FOSS4G-E 2017 to events list
      Update events list
      Fix formatting
      PostGIS 2.3.3 release
      Make PostGIS 2.3.3 the new latest stable release and 2.3.4dev new stable branch
      Update windows version info
      change EDB to Enterprisedb, no need to mention application stack builder
      update install section
      update windows 2.3 dev
      install stuff
      get rid of hard-coding of path in translation pdf docs
      update events
      PostGIS 2.4.0alpha release notes
      Add PostGIS 2.4.0alpha download to source list
      update events
      add 2.4.0beta1 release notes
      minor typo correction
      minor typo correction and use Carto new name
      update source links
      fix source links
      fix typo
      fix typo
      update events
      update windows build info downgrading to GEOS 3.6.2 from GEOS 3.7.0dev
      postgis 2.4.0rc1 release
      reorder doc translations in order of most complete.  Add de pdf
      PostGIS 2.4.0rc2 release
      fix link typos
      fix typos
      fix up 2.4 stuff
      PostGIS 2.4.0rc3 release
      PostGIS 2.4.0 release
      fix paths
      Update windows downloads notice 9.6 installers are out.
      Update windows downloads notice 10 x64 installers are out.
      Update windows downloads notice 10.
      Update windows downloads and add 2.5 badge
      Update windows downloads installers 2.4.1 for 10 and 9.6 64-bit available
      Add tip about moving PostGIS to a different schema
      Notice that stackbuilder for PostgreSQL 10 now has PostGIS.  Update pgrouting pages.
      Update version info for PostGIS
      Update events. Add .editorconfig to enforce linebreaks and tab
      Update support bio
      Change winnie http links to https.
      Replace with new osgeo logo
      Change images from http sites to be hosted locally so if viewed via https will not raise error
      Make logo same height as previous logo
      Change jquery to be locally hosted and upgrade. Might want to get rid of it entriely as I think only thing that used it was jquery tweet which is not functional because of Twitter API changes.
      Use svg version of logo instead
      Use svg version of logo instead, force teh dimensions fixed otherwise does not show.
      Update windows packages info
      Update windows packages info. More https images and remove old events.
      Get rid of old piecrust.  Causes confusion. Also change index.php to point at new piecrust for dynamic runs Closes #1
      Release 2.4.3 and 2.3.6.  Fix links to gitea.
      Add closed tickets link to news
      Add note about legacy scripts
      Add PostgresConf US remove some old past events
      update windows postgis 2.4.3 release notes
      update windows postgis 2.4.3 release notes to include notice about 9.6 installer release
      change to use https://download.osgeo.org instead of http://download.osgeo.org
      Add section about EOL and compatibility
      Dedicate a page to EOL policy and reference it from home and source download so it is short and sweet.  Remove tar ball links of versions we no longer support.
      Put in a title on eol_policy page
      Minor cleanup
      Be less cruel and at least provide link to source folder on downloads for EOL versions
      Fix link text for PostgreSQL EOL policy
      Remove Eold versions from documentation page and put a note about EOL and where to get EOL docs
      Fix doco path
      Tag releases for 2.2.7, 2.3.7, 2.4.4
      Update windows experimental build info
      fix typo
      Update source download looks to latest revisions
      Update notice on windows downloads page that 2.4.4 installers are out
      Update notice on windows downloads about issue with stackbuilder if running too low a version
      Update notice on windows downloads about PostGIS 2.3.7 availability
      Update events section, add in Foss4g FR, Postgres Vision, and move PostgresConf to past
      FOSS4G NA is over
      Update ubuntu link to the PostgreSQL 10 2.4 version
      Move FOSS4G FR to past events
      PostGIS 2.5.0alpha release
      Fix typo in pdf link
      Update events
      Update events
      add pgopen 2018, remove foss4g eu 2017, minor cleanup
      add PostGIS 2.5.0beta1 release notes.  Add 2.5 tag to alpha release
      Move past event down
      add PostGIS 2.5.0beta2 release notes.
      update trunk version to 2.5.0rc1dev
      update trunk version to 3.0.0dev and post release for 2.5.0rc1
      Fix documentation links
      More prep for 3.0
      Update events
      2.5.0rc2 release notes
      2.5.0rc2 release notes fix path
      2.5.0 release
      Add note about pgRouting and links to both pgRouting and PostgreSQL release
      try to fix formatting of release items
      Update books section, seems a lot of books are now at their 2nd edition
      Remove Mark from PSC list
      Add 2.5 doxygen
      Add release notes about windows PostGIS 2.5.0 bundle
      Add release notes about windows PostGIS 2.5.0 bundle 9.5, delete notes from 2.3.7 to make page shorter
      Update windows experimental branch info for PostGIS and pgRouting
      Fix link to 3.0.0 docs and tar ball
      Add note that win32 installers are on stackbuilder for PostGIS 2.5.0 bundle
      Add note about PostgreSQL 11 and section to download PostgreSQL 11 experimental
      Update events
      reduce with of foss4g 2019 logo
      add FOSS4G Oceania 2018 to events.  Remove some old small events.
      add FOSS4G Oceania 2018 add location
      add updated case study for Vanguard Appraisals
      add new case study Howard Hughes Medical Institute
      Release PostGIS 2.5.1
      Remove de pdf link, do not have that one
      Release PostGIS 2.2.8
      Release PostGIS 2.3.8 and PostGIS 2.4.6
      Update source links for PostGIS 2.3.8 and PostGIS 2.4.6
      Update events list
      Add link to OCeania conference videos
      Update to reflect windows 2.5.1 package bundle available on stackbuilder, and update experimental build version info
      Add pgconf new york, new york event in March 2019
      PostGIS 2.5.2, 2.4.7, and 2.3.9 releases
      Minor correction
      Minor correction
      update events
      fix dev source tarball links
      update windows binaries section
      Upgrade libraries and minor tweaks to get to work in PHP 7.3
      Simplify windows page.  Add in PostgresVision event which we'll be presenting at
      oops broke the build, try again
      Revert back to earlier version of window download page
      Take out some verbiage slowly
      Release 3.0.0alpha1
      get rid of link to de - we don't have translations ready yet
      minor word smithing
      Fix typo in version number and add 3.0.0alpha1 to tip
      fix bad link in release source, remove BigSQL from installer list (those are being decommissioned)
      PostGIS 3.0.0alpha2 release
      Fix link to ST_ConstrainedDelaunayTriangles
      Update events list
      rid of obsolete build articles - update existing
      Get rid of obsolete windows instructions and mention the 3.0 raster change
      move instructions above the build info
      Add postgres sv 2019, move vision to past events
      PostGIS 3.0.0alpha3 release
      Update to 2.3.10
      2.4.8 release
      Patch release news and add in 2.5 and 3.0 downloads
      Add 3.0 to tags
      Notice that 2.5.3 64 installers available
      Fix obsolete links, move bigsql notice below now that they stopped releasing them
      Update version info
      Move Foss4G 2019 to past events and also add link to the great videos already available from event
      Add a space
      Update events and 2.5 windows detail
      PostGIS 3.0.0beta1 announcement
      Change foss4g 2020 to http from https.  Looks like they don't have an https cert yet
      Release 3.0.0rc1
      Release 3.0.0rc2 and flip development to 3.1.0dev
      Put in page break
      Update events pgconfeu is over
      PostGIS 3.0.0 release
      PostGIS 3.0.0 release - change date
      Add link to german pdf
      Get rid of the 4 in Proj and replace with new proj.org link
      Missed some spots for 3.0.0 and annouce stackbuilder installers for windows
      Update install instructions now that raster is a separate extension
      Fix formatting on doco page
      Fix formatting of windows page
      Add in sql comment about what each extension is for
      Change note to reflect change from svn to git
      Add Raul and Darafei to PSC list
      Add postgis day St. Louis
      Amend windows PostGIS 3.0.0 to detail republished
      Add link to latest stable release docs
      Update upcoming events
      Change foss4g2020 logo image to point to local copy so we don't get 'some content is insecure' if people use https://postgis.net
      Add links to irc web interfaces
      Fix formatting
      Update cartodb.com to carto.com
      Get rid of unneeded slashes in code example
      CartoDb -> Carto.  Add link to Crunchy Data Interactive PostGIS portal
      Cap Learning Portal instead of learning portal, per Martin Davis
      Add security email link
      Link to Security.md Raul just added to repo
      Update to reflect PostGIS In Action 3rd is in development
      Add link to PostGIS Day STL videos
      Amend development page to include mention that we accept patches as pull requests
      Add logos and fix malformed href
      Add link to 3.1.0alpha1
      Make headers headers
      Announce that PostGIS 3.0.1 Windows bundle is available
      Minor correction of version info and other stuff
      more cleanup
      more cleanup
      Remove pgconf NY since got canceled because of Coronavirus
      Remove broken link. Closes #4653
      Purge posts, we'll add back later
      Replace README with a hugo one, get rid of htaccess
      Work in progress - cutting over changes
      First pass apply hugo-clarity
      Reformatting pages
      More refactoring
      Fix more stuff
      Delete old stuff not needed, and add note about theme being used
      Add in gitea icon
      Several changes 1. Fix source page - was old chat stuff 2. attempt at making a column short-code - uses tables - TODO change later to use grids 3. Put 1950 into a ci folder.  Really all ci stuff
      Override the variables so we can change colors.  Make nav white
      add postgis variables and reformat for 2 column some docs
      More updates
      CHANGES
      Put in our own logos
      Add link back to hugo and clarity
      Rename posts back to original post.  There is something that relies on the name to show related
      Set to staging.postgis.net so we can start testing
      Fiddling with layout
      Disable robots for now
      Delete old css files
      Revert syntax back to way it was, causing the mode not to change
      Get rid of title on page single-page, preliminary work on release source
      Fix crunch data logo
      Numerous changes: 1. Fix dates on posts 2. Remove tips partial and put directly on homepage layout 3. Rename posts to md so formatted right 4. Add news to home page 5. color fussing
      1. Put author name on posts 2. Test out gist short-code
      Get rid of news partial, now part of index layout
      more messing with colors.  Underline hyperlinks.  Fix obsolete info oninstall page
      More cosmetic changes.  Fix development doxygen links
      Fix numbering
      Make mobile navigation icon show
      Add osgeo link
      Get rid of bio on posts, more content fixing
      Format events as separate
      Change to use custom for events
      Complete converting events
      Change columns to use css grids instead of tables.  Other changes to layout
      Fix event
      Fix events formatting
      Fix sorting of docs and source tar balls and clean up source page
      Fix doc path
      Fix post alignment on home page. Numerous other small changes
      CHANGES 1. First pass pull of 2020 posts 2. Define a loc shortcode to return paths of artifacts 3. Replace all old chef variable path syntax with new loc shortcode
      Get rid of all social links except rss and add an Edit this page link
      Fix edit page url so works both on Linux and Windows
      Get rid of use of Path.Clean, debbie's hugo version doesn't support it
      Missed a spot
      Fix read more post links style.  Add twitter feed
      More article conversions
      Partial conversion of tips and case studies
      Fix links
      Get rid of blank lines in smartcodes, they add white space. Change .editorconfig to not force a new line
      Revert accidental changes.  Also change Transifex to weblate
      Update transifex to weblate.  Fix some formatting
      Change colors a bit so not so washed out
      Change to markdown code syntax instead of hugo specific.  Shows correctly in gitea that way
      Fix links and dates
      More cleanup
      Fix source path
      Change to markdown code format.  Add header for source code repositories
      Fix postgis.version variable path
      Pull over rest of the posts, fix case studies, get rid of facebook share
      Move ci posts out of postgs and change tags of them to buildbot so they don't get listed as tags
      Get rid of category on all buildbot posts so they don't get listed in category
      Change events from series to category.  Fix more formatting of articles
      Fix formatting of events pages
      CHANGES 1. Move 2013 postgis day hangout to events section 2. Work in progress on windows download page
      Add link to pgrouting on hangout since it was discussed
      Make video links https so they work
      Change transcript link to http
      Add section for rfcs, copy over first 2, mind changes to event
      Reorg windows bot content
      Make 2-column responsive
      Make edit this page have consisent color across pages
      Convert over and stamp date on 2001 posts
      Remove google analytics and twitter js
      Take out share links
      Remove test gist post
      Add date and rename 2002 to md
      Add dates to 2003, mark as md.  Fix geos and postgis_release links
      Fix geos and proj links
      date and format 2004
      Format and date 2017. Get rid of micro tags, too many tags
      Convert 2016 to md extension, get rid of micro tag, add date
      Convert 2014 to md extension, get rid of micro tag, add date. Minor fix to 2003 post
      Convert 2013 to md extension, get rid of micro tag in 2013/2022, add date. Fix release_docs tags
      More cleanup of posts and pages
      Reformat and date 2012
      2011 content and cleanup of tags
      2009 and 2010 content and cleanup of tags
      Get rid of more micro tags
      CHANGES Add postgis.source_dev_branch as reference to postgis git master branch
      2006 add date. More cleanup of tags
      Flag EOL and more tag cleanup
      Show event tags on event full page
      CHANGES 1. Get rid of postgis.logo thumbnail on all posts 2. Show only last 2 past events 3. Fix date on PostGIS Day and PostgresVision events so they sort right
      Move hello world down
      Fix link to postgresql
      CHANGES 1. Change feed file from index.xml to feed.xml so same as current site 2. Change feed to only include type = post 3. Change url name of posts to not have post, to match current site
      Change post to use title instead of file-name.  Filename includes month day which the old site did not have in path
      CHANGES 1. Change post permlink format to slug from title, with that it uses title slug if no slug specified, but can define a slug to override default behavior.  Intention is to keep old links the same as before.
      Fix more permalinks
      Remove boundless, no longer exists.  Add https to some links
      Change title to PostGIS from About PostGIS.  Get rid of negative padding on h2
      Keep title as About PostGIS.  Fix features page
      Change links prepping for promotion
      Rename ci html to .md.  Get rid of HELLO
      Try to fix http:// seems to not load css
      Announce PostGIS 3.2.1 installers available complete with new GDAL, pgRouting, and GEOS
      PostGIS 2.5.6 release
      Fix md5 links
      Change all page-break to more tags, so huguo correctly creates the summary
      PostGIS 2.4.10 release (EOL)
      Add pgcon 2022.  Clean up formatting of events
      Remove, will change to use submodule instead
      Change to use submodules, upgrade to have search box
      Remove submodule
      Remove submodule
      Put back old files
      Turn on robotstxt Turn off search - until issue https://github.com/chipzoller/hugo-clarity/issues/290 is resolved
      Put back all sections
      Fix pdf links
      Ignore visual code file.  Add postgres vision 2022 event
      Move to upcoming events section
      PostGIS 3.3.0alpha1 release
      Fix milestone link
      Corrections to pgcon and also mark as over
      Fix title of postgres vision
      Postgresvision 2022 is over
      Release notes for 3.3.0beta1
      Fix file name
      postgis 3.3.0beta2 release
      Fix file name and grammar
      Release 2.5.7
      Update release versions for 3.3 and 2.5
      PostGIS 3.0.6 release announcement
      PostGIS 3.1.6 release
      PostGIS 3.2.2 release
      Update that windows installers for PostGIS 3.2.2 are avaialable now
      Release 3.3.0rc1
      Update instructions and latst stable version
      Patch releases for PostGIS 3.2.3, 3.1.7, 3.0.7, 2.5.8
      Minor edit
      Windows installers and binaries for PostGIS 3.2.3 available
      Release postgis 3.3.0rc2, and add dev for 3.4
      Should be PostgreSQL 15 beta3
      First pass at a sponsorship page
      Tip about how to upgrade postgis-sfcgal from < PostGIS 3.1
      Add sponsor logos
      Add missing link
      Update PostGIS: Análisis Espacial Avanzado 2nd Revision 4 to list latest version
      PostGIS 3.3.0 release
      Add links to development manual
      Fix release version supported
      Take out Amazon for now until we hear back on guidance
      Try to fix logo issue
      Replace rfc link with sponsor link and minor adjustments to sponsor page
      FOSS4G 2022 passed, OSGeo UK PostGIS day coming, minor cleanup of events
      Should be 8 locations
      Add virtual postgis day
      Release PostGIS 3.3.1
      Fix link by specifying original slug
      PostGIS 3.3.1 Windows Bundle
      Add that PG15 installers are out now too
      PostgreSQL 15 windows PostGIS 3.3.1 released with ogr_fdw fix
      Add link to autogenerated cheat sheets
      Add link to sfcgal cheatsheet
      Release 2.5.9
      Patch releases for 3.0, 3.1, 3.2, and 3.3
      Correct that 3.3.2 is for PostgreSQL 11-15 not 11 or higher
      PostGIS Day is over. Take off featured mark.  Add video link for FOSS4GUK
      Add FOSS4G 2023
      Add Ryan Lambert's new book
      Minor corrections to windows installers/builds and also update for PostGIS 3.3.2 Windows bundle
      additional instructions how to install other postgis related extensions
      Add video link to postgis day 2022
      Rerelease of PostGIS Windows Bundle 3.3.2
      Fix date info on PostGIS Day 2019
      Add link to workshop on home page along side other doc list
      Detail how to fix a broken raster install
      Add newly released book in French
      Missed the 13-15 part
Sandro Santilli (26):
      Add source code repository links
      Fix Vizzuality link and CartoDB spelling
      Set version to 2.0.3
      Announce security releases 2.0.6 and 2.1.3
      Fix typo in 2.1.8 announcement page
      Reduce size of search input box in documentation page
      Add GitLab mirror link, do not confuse GIT with GitHub
      Quote words with underscores in them
      Fix typo
      Fix link to IRC channel
      Update my website url
      Add link to the GIT repositories on OSGeo
      Specify that PostGIS is distributed as GPLv2 _or_later_
      Add myself in the commercial support section
      Fix install link
      Avoid forcing http links, to make https possible
      Limit the size of the search widget to 15 characters
      Further reduce the search input size (worked!)
      Add link to Mastering PostGIS book
      Add matrix link for IRC channel access
      Advertise #postgis:osgeo.org as matrix room
      Initialize a Hugo layout and copy (not convert) content over
      Remove generated files from repo
      Ignore resources/
      80 cols wrap
      Fix typo and my company name
leoregina (2):
      PostGIS 2.2.4 new announcement
      Uplad source links
robe2 (3):
      add 2.4 windows branch
      update windows branch details
      update events
hooks/post-receive
postgis.net
