[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-812-gc2b2f2676
Sun May 14 16:59:15 PDT 2023
the project "PostGIS".
       via  c2b2f2676eb528f7d5572ad0e05039203fd45cf8 (commit)
      from  d3248f4c8ca19f8f91ded1185833c327ca03ca11 (commit)
revisions in full, below.
commit c2b2f2676eb528f7d5572ad0e05039203fd45cf8
Author: Regina Obe <regina at arrival3d.com>
Date:   Sun May 14 23:57:27 2023 +0000
    Translated using Weblate (French)
    Currently translated at 39.6% (130 of 328 strings)
    Translation: postgis/reference_output.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_outputxml/fr/
diff --git a/doc/po/fr/reference_output.xml.po b/doc/po/fr/reference_output.xml.po
index 44d7caeb8..5f1966282 100644
--- a/doc/po/fr/reference_output.xml.po
+++ b/doc/po/fr/reference_output.xml.po
@@ -9,8 +9,8 @@ msgstr ""
 "Project-Id-Version: PostGIS\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2022-11-27 05:42+0000\n"
-"PO-Revision-Date: 2023-01-06 15:50+0000\n"
-"Last-Translator: Vincent Bre <vincent.bre at oslandia.com>\n"
+"PO-Revision-Date: 2023-05-14 23:59+0000\n"
+"Last-Translator: Regina Obe <regina at arrival3d.com>\n"
 "Language-Team: French <https://weblate.osgeo.org/projects/postgis/"
 "reference_outputxml/fr/>\n"
 "Language: fr\n"
@@ -18,7 +18,7 @@ msgstr ""
 "Content-Type: text/plain; charset=UTF-8\n"
 "Content-Transfer-Encoding: 8bit\n"
 "Plural-Forms: nplurals=2; plural=n > 1;\n"
-"X-Generator: Weblate 4.14.1\n"
+"X-Generator: Weblate 4.16.4\n"
 #. Tag: para
 #: reference_output.xml:6
@@ -1373,8 +1373,6 @@ msgid ""
 "necessary geometry can be projected into WGS84 using <xref "
 "linkend=\"ST_Transform\"/>: <code>ST_Transform( geom, 4326 )</code>."
 msgstr ""
-"Si nécessaire, la géométrie peut être projetée en WGS84 en utilisant <xref "
-"linkend=\"ST_Transform\"/> : <code>ST_Transform( geom, 4326 )</code>."
 #. Tag: para
 #: reference_output.xml:597
Summary of changes:
 doc/po/fr/reference_output.xml.po | 8 +++-----
 1 file changed, 3 insertions(+), 5 deletions(-)
hooks/post-receive
