[postgis-tickets] [SCM] PostGIS branch master updated. 3.3.0rc2-911-gac924b406
Sat May 20 06:30:38 PDT 2023
the project "PostGIS".
       via  ac924b4068bd0de669202fd41181c807056acd65 (commit)
      from  9ffcf35468db241308ae961fbac851a5443f4fec (commit)
revisions in full, below.
commit ac924b4068bd0de669202fd41181c807056acd65
Author: Sandro Santilli <strk at kbt.io>
Date:   Sat May 20 15:30:20 2023 +0200
    Add --legacy switch to run_regress.pl
diff --git a/regress/run_test.pl b/regress/run_test.pl
index 20963c959..cb391df4c 100755
--- a/regress/run_test.pl
+++ b/regress/run_test.pl
@@ -78,6 +78,7 @@ my $OPT_WITH_RASTER = 0;
 my $OPT_WITH_SFCGAL = 0;
 my $OPT_EXPECT = 0;
 my $OPT_EXTENSIONS = 0;
+my $OPT_LEGACY = 0;
 my @OPT_HOOK_AFTER_CREATE;
 my @OPT_HOOK_AFTER_RESTORE;
 my @OPT_HOOK_BEFORE_DUMP;
@@ -107,6 +108,7 @@ GetOptions (
 	'sfcgal' => \$OPT_WITH_SFCGAL,
 	'expect' => \$OPT_EXPECT,
 	'extensions' => \$OPT_EXTENSIONS,
+	'legacy' => \$OPT_LEGACY,
 	'schema=s' => \$OPT_SCHEMA,
 	'build-dir=s' => \$TOP_BUILDDIR,
 	'after-create-script=s' => \@OPT_HOOK_AFTER_CREATE,
@@ -700,12 +702,13 @@ Options:
   --schema        where to install/find PostGIS (relocatable) PostGIS
                   (defaults to "public")
   --raster        load also raster extension
-  --tiger      		load also tiger_geocoder extension
+  --tiger         load also tiger_geocoder extension
   --topology      load also topology extension
   --sfcgal        use also sfcgal backend
   --clean         cleanup test logs on exit
   --expect        save obtained output as expected
   --extension     load using extensions
+  --legacy        load also legacy scripts
   --build-dir <path>
                   specify where to find the top build dir of PostGIS,
                   to find binaries and scripts
@@ -1675,6 +1678,11 @@ sub prepare_spatial
 	return 0 unless load_sql_file("${scriptdir}/postgis.sql", 1);
 	return 0 unless load_sql_file("${scriptdir}/postgis_comments.sql", 0);
 	return 0 unless load_sql_file("${scriptdir}/spatial_ref_sys.sql", 0);
+	if ( $OPT_LEGACY )
+		print "Loading legacy.sql from $scriptdir\n";
+		return 0 unless load_sql_file("${scriptdir}/legacy.sql", 0);
 	if ( $OPT_WITH_TOPO )
@@ -1952,6 +1960,10 @@ sub drop_spatial
 		load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_sfcgal.sql");
+		load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_legacy.sql");
 	load_sql_file("${STAGED_SCRIPTS_DIR}/uninstall_postgis.sql");
   	return 1;
Summary of changes:
 regress/run_test.pl | 14 +++++++++++++-
 1 file changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
