[postgis-tickets] [SCM] PostGIS branch stable-3.2 updated. 3.2.4-31-gbc9de9099
Sun May 28 22:26:40 PDT 2023
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  bc9de90993ae69e6f45f39fbbbb45dc237deb310 (commit)
      from  4a97397ea5d0b9a77b13f58f69c7b2d3b3961ba4 (commit)
revisions in full, below.
commit bc9de90993ae69e6f45f39fbbbb45dc237deb310
Author: Regina Obe <lr at pcorp.us>
Date:   Mon May 29 01:26:32 2023 -0400
    Prep for 3.2.5 release
diff --git a/NEWS b/NEWS
index d9dad1a66..a7f00d108 100644
--- a/NEWS
+++ b/NEWS
@@ -1,5 +1,5 @@
-PostGIS 3.2.5dev
-2023/MM/DD
+PostGIS 3.2.5
+2023/05/28
 This version requires PostgreSQL 9.6-15, GEOS 3.6 or higher, and Proj 4.9+
 Additional features are enabled if you are running GEOS 3.9+
diff --git a/README.postgis b/README.postgis
index a97a5cddd..8b499642f 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.2.4
-:Date: 2022-11-12
+:Version: 3.2.5
+:Date: 2023-05-29
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index bb3fd2dfb..893dd170a 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=2
-POSTGIS_MICRO_VERSION=5dev
+POSTGIS_MICRO_VERSION=5
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index e27769746..b18ac2300 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,34 @@
 <appendix id="release_notes">
   <title>Appendix</title>
    <subtitle>Release Notes</subtitle>
+    <sect1>
+        <title>PostGIS 3.2.5</title>
+        <para>2023/05/29</para>
+        <para>This version requires PostgreSQL 9.6-15, GEOS 3.6 or higher, and Proj 4.9+
+        Additional features are enabled if you are running GEOS 3.9+
+        (and ST_MakeValid enhancements with 3.10+),
+        Proj 6.1+, and PostgreSQL 14+.</para>
+        <simplesect>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5384">5384</ulink>, Fix crash in ST_AsGML when given id is longer than given prefix
+                    (Sandro Santilli</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5380">5380</ulink>, Fix 2.5 upgrades with views using geography based ST_Distance
+                    (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5106">5106</ulink>, Fix segfault in ST_RemEdgeNewFace/ST_RemEdgeModFace
+                    when no edge side-faces are found (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5313">5313</ulink>, Fix memory access issue in ST_InterpolateRaster (Paul Ramsey)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5338">5338</ulink>, Dump/Restore of raster table fails on
+                    enforce_coverage_tile_rast constraint (Regina Obe)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5315">5315</ulink>, #5318, #5319, #5320, #5342 crashes on infinite coordinates
+                    (Regina Obe, Paul Ramsey)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5344">5344</ulink>, Include topology id sequence state in dumps (Sandro Santilli)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5288">5288</ulink>, ST_LineCrossingDirection multi-cross error (Paul Ramsey)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5347">5347</ulink>, _ST_BestSRID crashes on ARM with infinite geometries (Regina Obe)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5363">5363</ulink>, Make ST_ClusterDBScan interruptable (Paul Ramsey)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5378">5378</ulink>, ST_Buffer(geography) drops SRID (Paul Ramsey)</para>
+            <para><ulink url="https://trac.osgeo.org/postgis/ticket/5331">5331</ulink>, [postgis_tiger_geocoder] reverse_geocode, prefer addressable ranges
+                    (Regina Obe, Locance)</para>
+        </simplesect>
+    </sect1>
     <sect1>
         <title>PostGIS 3.2.4</title>
         <para>2022/11/12</para>
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 66fb0e50b..5033b4ba4 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -68,6 +68,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.6 \
 	3.0.7 \
 	3.0.8 \
+	3.0.9 \
 	3.1.0 \
 	3.1.1 \
 	3.1.2	\
@@ -77,6 +78,7 @@ UPGRADEABLE_VERSIONS = \
 	3.1.6 \
 	3.1.7 \
 	3.1.8 \
+	3.1.9 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
Summary of changes:
 NEWS                               |  4 ++--
 README.postgis                     |  4 ++--
 Version.config                     |  2 +-
 doc/release_notes.xml              | 28 ++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  2 ++
 5 files changed, 35 insertions(+), 5 deletions(-)
hooks/post-receive
