[postgis-tickets] [SCM] PostGIS branch stable-3.3 updated. 3.3.2-64-g4910a7ba6
Sun May 28 23:35:05 PDT 2023
the project "PostGIS".
The branch, stable-3.3 has been updated
       via  4910a7ba66b30ef02f863b159933b96db910ec4d (commit)
      from  c5f2076043b795b83b9f3500d0874085d4d96061 (commit)
revisions in full, below.
commit 4910a7ba66b30ef02f863b159933b96db910ec4d
Author: Regina Obe <lr at pcorp.us>
Date:   Mon May 29 02:34:58 2023 -0400
    Prep for PostGIS 3.3.3 release
diff --git a/NEWS b/NEWS
index 74193bff4..12dbad1a5 100644
--- a/NEWS
+++ b/NEWS
@@ -1,7 +1,7 @@
-PostGIS 3.3.3dev
-YYYY/MM/DD
+PostGIS 3.3.3
+2023/05/29
-* Bug Fixes *
+* Bug Fixes and Enhancements *
   - #5384, Fix crash in ST_AsGML when given id is longer than given prefix
            (Sandro Santilli)
   - #5380, Fix 2.5 upgrades with views using geography based ST_Distance
diff --git a/README.postgis b/README.postgis
index b2dd44136..4130c070b 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.3.2
-:Date: 2022-11-12
+:Version: 3.3.3
+:Date: 2023-05-29
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
diff --git a/Version.config b/Version.config
index 5900aed81..21d6b459b 100644
--- a/Version.config
+++ b/Version.config
@@ -5,7 +5,7 @@
 POSTGIS_MAJOR_VERSION=3
 POSTGIS_MINOR_VERSION=3
-POSTGIS_MICRO_VERSION=3dev
+POSTGIS_MICRO_VERSION=3
 # Liblwgeom interface versioning, reset to 0:0:0 (cur:age:rev)
 # when changing POSTGIS_MINOR_VERSION
diff --git a/doc/release_notes.xml b/doc/release_notes.xml
index 0ae546abe..143899d92 100644
--- a/doc/release_notes.xml
+++ b/doc/release_notes.xml
@@ -2,6 +2,46 @@
 <appendix id="release_notes">
   <title>Appendix</title>
     <subtitle>Release Notes</subtitle>
+        <sect1>
+            <title>PostGIS 3.3.3</title>
+            <para>This version requires PostgreSQL 11-16beta1, GEOS 3.6 or higher, and Proj 4.9+
+Additional features are enabled if you are running GEOS 3.9+
+ (and ST_MakeValid enhancements with 3.10+),
+Proj 6.1+, and PostgreSQL 15+.</para>
+            <simplesect><title>Bug Fixes and Enhancements</title>
+              <para><ulink url="https://trac.osgeo.org/postgis/ticket/5384">5384</ulink>, Fix crash in ST_AsGML when given id is longer than given prefix
+           (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5380">5380</ulink>, Fix 2.5 upgrades with views using geography based ST_Distance
+           (Sandro Santilli</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5303">5303</ulink>, Don't try removing closed edges endpoint from
+           RemoveUnusedPrimitives (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5289">5289</ulink>, Fix misleading message in RemoveUnusedPrimitives about
+           doubly connected edges healing (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5298">5298</ulink>, Fix CopyTopology exception with hierarchical layers (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5299">5299</ulink>, Corrections to address_standardizer_data_us lex (Regina Obe)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5106">5106</ulink>, Fix segfault in ST_RemEdgeNewFace/ST_RemEdgeModFace
+           when no edge side-faces are found (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5329">5329</ulink>, Fix downgrade protection introduced in 3.3.0 (Sandro Santilli)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5332">5332</ulink>, Keep proj errors from percolating into PgSQL log (Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5313">5313</ulink>, Fix memory access issue in ST_InterpolateRaster (Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5338">5338</ulink>, Dump/Restore of raster table fails on
+           enforce_coverage_tile_rast constraint (Regina Obe)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5315">5315</ulink>, #5318, #5319, #5320, #5342 crashes on infinite coordinates
+          (Regina Obe, Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5344">5344</ulink>, Include topology id sequence state in dumps (Sandro Santilli</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5288">5288</ulink>, ST_LineCrossingDirection multi-cross error (Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5347">5347</ulink>, _ST_BestSRID crashes on ARM with infinite geometries (Regina Obe)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5331">5331</ulink>, [postgis_tiger_geocoder] reverse_geocode, prefer addressable ranges
+          (Regina Obe, Locance)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5363">5363</ulink>, Make ST_ClusterDBScan interruptable (Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5257">5257</ulink>, #5261, #5277, #5304, #5308, #5374, Support for PG16
+          (Paul Ramsey, Regina Obe, Sandro , Laurenz Albe)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5371">5371</ulink>, ST_Union segfaults (PG 11-12) (Regina Obe)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5378">5378</ulink>, ST_Buffer(geography) drops SRID (Paul Ramsey)</para>
+  <para><ulink url="https://trac.osgeo.org/postgis/ticket/5388">5388</ulink>, [postgis_tiger_geocoder] Fix faces table tiger_gload,
+           caused census rerelease of faces data (Regina Obe)</para>
+            </simplesect>
+        </sect1>
         <sect1>
             <title>PostGIS 3.3.2</title>
             <para>This version requires PostgreSQL 11-15, GEOS 3.6 or higher, and Proj 4.9+
diff --git a/extensions/upgradeable_versions.mk b/extensions/upgradeable_versions.mk
index 3736b0444..e9630aa3f 100644
--- a/extensions/upgradeable_versions.mk
+++ b/extensions/upgradeable_versions.mk
@@ -68,6 +68,7 @@ UPGRADEABLE_VERSIONS = \
 	3.0.6 \
 	3.0.7 \
 	3.0.8 \
+	3.0.9 \
 	3.1.0 \
 	3.1.1 \
 	3.1.2	\
@@ -77,11 +78,13 @@ UPGRADEABLE_VERSIONS = \
 	3.1.6 \
 	3.1.7 \
 	3.1.8 \
+	3.1.9 \
 	3.2.0 \
 	3.2.1 \
 	3.2.2 \
 	3.2.3 \
 	3.2.4 \
+	3.2.5 \
 	3.3.0 \
 	3.3.1 \
 	3.3.2
Summary of changes:
 NEWS                               |  6 +++---
 README.postgis                     |  4 ++--
 Version.config                     |  2 +-
 doc/release_notes.xml              | 40 ++++++++++++++++++++++++++++++++++++++
 extensions/upgradeable_versions.mk |  3 +++
 5 files changed, 49 insertions(+), 6 deletions(-)
hooks/post-receive
