[PostGIS] #5602: GEOS 3.6 and GEOS 3.7 drop for PostGIS 3.5.0
PostGIS trac at osgeo.org
Wed Nov 1 10:04:45 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  build    |    Version:  master
Resolution:           |   Keywords:
Comment (by robe):
 Okay I found a GHA image - pg12-geos38-gdal30-proj611 so swapping out the
 gha pg12-geos37-gdal30-proj611 with that
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5602#comment:2>
