[PostGIS] #5602: GEOS 3.6 and GEOS 3.7 drop for PostGIS 3.5.0
PostGIS trac at osgeo.org
Wed Nov 1 09:20:22 PDT 2023
  Reporter:  robe     |      Owner:  robe
      Type:  task     |     Status:  assigned
  Priority:  blocker  |  Milestone:  PostGIS 3.5.0
 Component:  build    |    Version:  master
Resolution:           |   Keywords:
Description changed by robe:
Old description:
> As noted in PostGIS Dev mailing list
> https://lists.osgeo.org/pipermail/postgis-devel/2023-October/030147.html
> https://lists.osgeo.org/pipermail/postgis-devel/2023-October/030149.html
> The plan is to drop GEOS 3.6 and GEOS 3.7. 3 + votes and no - votes.
> As part of that, the following needs to happen
> * Revise configure to not allow building for GEOS < 3.8
> * Remove all ifdefs in code and tests for GEOS 3.6 and 3.7
> * Stop ci testing on 3.6 and 3.7
>    * Woodie/Dronie - I've already upped the GEOS from 3.6 to 3.10 and
> looks like build passed.
>    * Remove 3.7 testing from Github Actions
>       * The 3.7 matrix is the only one testing proj6 and pg12, so we
> should probably replace with slightly newer that has all but geos38
> instead of 37
New description:
 * Update doc references in postgis.xml (and any hard-coded in docs)
 instead of 37
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5602#comment:1>
