[PostGIS] #5602: GEOS 3.6 and GEOS 3.7 drop for PostGIS 3.5.0
PostGIS trac at osgeo.org
Wed Nov 1 09:16:44 PDT 2023
 Reporter:  robe     |      Owner:  robe
     Type:  task     |     Status:  assigned
 Priority:  blocker  |  Milestone:  PostGIS 3.5.0
Component:  build    |    Version:  master
 Keywords:           |
 As noted in PostGIS Dev mailing list
 https://lists.osgeo.org/pipermail/postgis-devel/2023-October/030147.html
 https://lists.osgeo.org/pipermail/postgis-devel/2023-October/030149.html
 The plan is to drop GEOS 3.6 and GEOS 3.7. 3 + votes and no - votes.
 As part of that, the following needs to happen
 * Revise configure to not allow building for GEOS < 3.8
 * Remove all ifdefs in code and tests for GEOS 3.6 and 3.7
 * Stop ci testing on 3.6 and 3.7
    * Woodie/Dronie - I've already upped the GEOS from 3.6 to 3.10 and
 looks like build passed.
    * Remove 3.7 testing from Github Actions
       * The 3.7 matrix is the only one testing proj6 and pg12, so we
 should probably replace with slightly newer that has all but geos38
 instead of 37
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5602>
