[SCM] PostGIS branch master updated. 3.4.0rc1-744-gd097bbc72
Thu Nov 2 11:54:13 PDT 2023
the project "PostGIS".
       via  d097bbc724ce75c373f0adad09ba098fefb530ca (commit)
      from  5375fbef86e47b478623689b43f5458134a8149a (commit)
revisions in full, below.
commit d097bbc724ce75c373f0adad09ba098fefb530ca
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Nov 2 14:53:41 2023 -0400
    Doc and ci updates for GEOS 3.6, 3.7 removal.
    References #5602 for PostGIS 3.5.0.
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index 877a4185d..4df0f2134 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -30,7 +30,7 @@ jobs:
         # Run tests with different dependency combinations
         - { tag: latest, mode: tests }
         - { tag: pg13-geos38-gdal31-proj71, mode: tests }
-        - { tag: pg12-geos37-gdal30-proj611, mode: tests }
+        - { tag: pg12-geos38-gdal30-proj611, mode: tests }
     runs-on: ubuntu-latest
     steps:
diff --git a/README.postgis b/README.postgis
index 03c81667a..c6e303fa8 100644
--- a/README.postgis
+++ b/README.postgis
@@ -1,8 +1,8 @@
 PostGIS - Geographic Information Systems Extensions to PostgreSQL
-:Version: 3.4.0rc2
-:Date: 2023-08-11
+:Version: 3.5.0dev
+:Date: 2023-11-01
 :Website: https://postgis.net
 This distribution contains a module which implements GIS simple features, ties
@@ -64,7 +64,7 @@ For apt-based systems you can run this command to install the below dependencies
     https://proj.org
-* GEOS (Required, Version 3.6 or higher)
+* GEOS (Required, Version 3.8 or higher)
   - 3.12+ for ST_CoverageSimplify and ST_CoverageInvalidEdges
   - 3.11+ for improved ST_ConcaveHull, ST_lineMerge,
     and new functions ST_SimplifyPolygonHull, ST_TriangulatePolygon
diff --git a/doc/installation.xml b/doc/installation.xml
index fdbda0cef..67901113f 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -184,7 +184,7 @@ sh autogen.sh
 	  <listitem>
 		<para>
-		  GEOS geometry library, version 3.6 or greater, but GEOS 3.12+ is required to take full advantage of all the new functions and features. GEOS is available for download from
+		  GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.12+ is required to take full advantage of all the new functions and features. GEOS is available for download from
 		  <link xlink:href="https://libgeos.org/">
 			https://libgeos.org
 		  </link>.
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 5ddb31ef2..261565368 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2023-10-30 18:01+0000\n"
+"POT-Creation-Date: 2023-11-02 18:50+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -6257,10 +6257,10 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"GEOS geometry library, version 3.6 or greater, but GEOS 3.12+ is required to "
-"take full advantage of all the new functions and features. GEOS is available "
-"for download from <link xlink:href=\"https://libgeos.org/\"> https://libgeos."
-"org </link>."
+"GEOS geometry library, version &min_geos_version; or greater, but GEOS 3.12+ "
+"is required to take full advantage of all the new functions and features. "
+"GEOS is available for download from <link xlink:href=\"https://libgeos.org/"
+"\"> https://libgeos.org </link>."
 msgstr ""
 #. Tag: para
@@ -6328,10 +6328,9 @@ msgid ""
 "or ST_Area, for instance). A PostgreSQL configuration variable <code>postgis."
 "backend</code> allow end user to control which backend he want to use if "
 "SFCGAL is installed (GEOS by default). Nota: SFCGAL 1.2 require at least "
-"CGAL 4.3 and Boost 1.54 (cf: <link xlink:href=\"https://oslandia.gitlab.io/"
-"SFCGAL/dev.html\">https://oslandia.gitlab.io/SFCGAL/dev.html</link>) <link "
-"xlink:href=\"https://gitlab.com/Oslandia/SFCGAL/\">https://gitlab.com/"
-"Oslandia/SFCGAL/</link>."
+"CGAL 4.3 and Boost 1.54 (cf: <link xlink:href=\"https://sfcgal.org\">https://"
+"sfcgal.org</link>) <link xlink:href=\"https://gitlab.com/sfcgal/SFCGAL/"
+"\">https://gitlab.com/sfcgal/SFCGAL/</link>."
 msgstr ""
 #. Tag: para
@@ -11881,13 +11880,15 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Creates a 2D, 3D Z or 4D ZM Point geometry."
+msgid ""
+"Creates a 2D XY, 3D XYZ or 4D XYZM Point geometry. Use <xref "
+"linkend=\"ST_MakePointM\"/> to make points with XYM coordinates."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Use <xref linkend=\"ST_MakePointM\"/> to make points with XYM coordinates."
+"Use <xref linkend=\"ST_SetSRID\"/> to specify a SRID for the created point."
 msgstr ""
 #. Tag: para
@@ -11906,11 +11907,21 @@ msgid ""
 "varname> is latitude"
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The functions <xref linkend=\"ST_Point\"/>, <xref linkend=\"ST_PointZ\"/>, "
+"<xref linkend=\"ST_PointM\"/>, and <xref linkend=\"ST_PointZM\"/> can be "
+"used to create points with a given SRID."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
 ", <xref linkend=\"ST_PointFromText\"/>, <xref linkend=\"ST_SetSRID\"/>, "
-"<xref linkend=\"ST_MakePointM\"/>"
+"<xref linkend=\"ST_MakePointM\"/>, <xref linkend=\"ST_Point\"/>, <xref "
+"linkend=\"ST_PointZ\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
+"linkend=\"ST_PointZM\"/>"
 msgstr ""
 #. Tag: refpurpose
@@ -11920,14 +11931,17 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "Creates a point with X, Y and M (measure) coordinates."
+msgid ""
+"Creates a point with X, Y and M (measure) ordinates. Use <xref "
+"linkend=\"ST_MakePoint\"/> to make points with XY, XYZ, or XYZM coordinates."
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Use <xref linkend=\"ST_MakePoint\"/> to make points with XY, XYZ, or XYZM "
-"coordinates."
+"The functions <xref linkend=\"ST_PointM\"/>, and <xref "
+"linkend=\"ST_PointZM\"/> can be used to create points with an M value and a "
+"given SRID."
 msgstr ""
 #. Tag: para
@@ -11954,7 +11968,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>"
+msgid ""
+", <xref linkend=\"ST_SetSRID\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
 msgstr ""
 #. Tag: refpurpose
@@ -12087,7 +12103,12 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "New in 3.2.0: With SRID specified"
+msgid "Creating a point with SRID specified:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Alternative way of specifying SRID:"
 msgstr ""
 #. Tag: title
@@ -12095,20 +12116,16 @@ msgstr ""
 msgid "Examples: Geography"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Pre-PostGIS 3.2 syntax"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "3.2 and on you can include the srid"
-msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"PostgreSQL also provides the <varname>::</varname> short-hand for casting"
+"Create <link linkend=\"PostGIS_Geography\">geography</link> points using the "
+"<varname>::</varname> cast syntax:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Pre-PostGIS 3.2 code, using <varname>CAST</varname>:"
 msgstr ""
 #. Tag: para
@@ -12123,9 +12140,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-", <xref linkend=\"ST_MakePoint\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
-"linkend=\"ST_Transform\"/>, <xref linkend=\"ST_PointZ\"/>, <xref "
-"linkend=\"ST_PointM\"/>, <xref linkend=\"ST_PointZM\"/>"
+", <xref linkend=\"ST_PointZ\"/>, <xref linkend=\"ST_PointM\"/>, <xref "
+"linkend=\"ST_PointZM\"/>, <xref linkend=\"ST_SetSRID\"/>, <xref "
+"linkend=\"ST_Transform\"/>"
 msgstr ""
 #. Tag: refpurpose
diff --git a/doc/postgis.xml b/doc/postgis.xml
index a281b0d5e..475c8921a 100644
--- a/doc/postgis.xml
+++ b/doc/postgis.xml
@@ -5,7 +5,7 @@
 <!-- This value is automatically generated by the Makefile -->
 <!ENTITY last_release_version "@@LAST_RELEASE_VERSION@@">
-<!ENTITY last_minor_version "3.3">
+<!ENTITY last_minor_version "3.4">
 <!-- ONCE Tagged, this need to change to http://download.osgeo.org/postgis/source/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
 <!-- In dev should be, this need to change to http://postgis.net/stuff/postgis-@@LAST_RELEASE_VERSION@@.tar.gz -->
@@ -14,8 +14,9 @@
 <!-- Change these values to update the version numbers referenced within the documentation -->
 <!ENTITY last_proj_release_version "9.2.1">
 <!ENTITY last_geos_release_version "3.12.0">
+<!ENTITY min_geos_version "3.8.0">
 <!ENTITY min_postgres_version "12">
-<!ENTITY max_postgres_version "16">
+<!ENTITY max_postgres_version "17">
 <!ENTITY introduction SYSTEM "introduction.xml">
 <!ENTITY installation SYSTEM "installation.xml">
Summary of changes:
 .github/workflows/ci.yml            |  2 +-
 README.postgis                      |  6 ++--
 doc/installation.xml                |  2 +-
 doc/po/templates/postgis-manual.pot | 71 +++++++++++++++++++++++--------------
 doc/postgis.xml                     |  5 +--
 5 files changed, 52 insertions(+), 34 deletions(-)
hooks/post-receive
