[SCM] PostGIS branch master updated. 3.4.0rc1-746-g4f47efbd4
Thu Nov 2 13:53:11 PDT 2023
the project "PostGIS".
       via  4f47efbd4dbe144d61150e468d1756d4501ce078 (commit)
      from  f58ef013c354912e2aaa19f73cc594d3df03033a (commit)
revisions in full, below.
commit 4f47efbd4dbe144d61150e468d1756d4501ce078
Author: Regina Obe <lr at pcorp.us>
Date:   Thu Nov 2 16:52:10 2023 -0400
    Remove GEOS 3.6, 3.7 supporting code
    Closes #5602 for PostGIS 3.5.0
diff --git a/NEWS b/NEWS
index f90510fe4..f472eb1d2 100644
--- a/NEWS
+++ b/NEWS
@@ -10,10 +10,14 @@ xxxx/xx/xx
               topology_id(tg1) <> topology_id(tg2) OR
               layer_id(tg1) <> layer_id(tg2) OR
               type(tg1) <> type(tg2)
+           ) (Sandro Santilli)
   - #5536, comments are not anymore included in PostGIS extensions
-  - xmllint is now required to build comments and documentation
+    (Sandro Santilli)
+  - xmllint is now required to build comments and
+    (Sandro Santilli)
   - DocBook5 XSL is now required to build html documentation
+    (Sandro Santilli)
+  - #5602, Drop support for GEOS 3.6 and 3.7 (Regina Obe)
 * New Features *
diff --git a/configure.ac b/configure.ac
index d8f20e956..cd47d79be 100644
--- a/configure.ac
+++ b/configure.ac
@@ -800,10 +800,10 @@ GEOS_NUMERIC_PATCH_VERSION=`printf "%02d" $GEOS_PATCH_VERSION`
 GEOS_NUMERIC_MINOR_VERSION=`printf "%02d" $GEOS_MINOR_VERSION`
 POSTGIS_GEOS_VERSION="$GEOS_MAJOR_VERSION$GEOS_NUMERIC_MINOR_VERSION$GEOS_NUMERIC_PATCH_VERSION"
-dnl Ensure that we are using GEOS >= 3.6.0
+dnl Ensure that we are using GEOS >= 3.8.0
 AC_MSG_RESULT([checking GEOS version... $GEOS_FULL_VERSION])
-if test ! "$POSTGIS_GEOS_VERSION" -ge 30600; then
-	AC_MSG_ERROR([PostGIS requires GEOS >= 3.6.0])
+if test ! "$POSTGIS_GEOS_VERSION" -ge 30800; then
+	AC_MSG_ERROR([PostGIS requires GEOS >= 3.8.0])
 fi
 dnl Extract the linker and include flags
diff --git a/liblwgeom/lwgeom_geos.c b/liblwgeom/lwgeom_geos.c
index 56b38b0be..094078a83 100644
--- a/liblwgeom/lwgeom_geos.c
+++ b/liblwgeom/lwgeom_geos.c
@@ -176,16 +176,11 @@ ptarray_from_GEOSCoordSeq(const GEOSCoordSequence* cs, uint8_t want3d)
 #else
 	for (i = 0; i < size; i++)
-#if POSTGIS_GEOS_VERSION < 30800
-		GEOSCoordSeq_getX(cs, i, &(point.x));
-		GEOSCoordSeq_getY(cs, i, &(point.y));
-		if (dims >= 3) GEOSCoordSeq_getZ(cs, i, &(point.z));
-#else
 		if (dims >= 3)
 			GEOSCoordSeq_getXYZ(cs, i, &(point.x), &(point.y), &(point.z));
 		else
 			GEOSCoordSeq_getXY(cs, i, &(point.x), &(point.y));
-#endif
 		ptarray_set_point4d(pa, i, &point);
@@ -331,16 +326,10 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
 			LWDEBUGF(4, "Point: %g,%g", p2d->x, p2d->y);
-		GEOSCoordSeq_setX(sq, i, p2d->x);
-		GEOSCoordSeq_setY(sq, i, p2d->y);
-		if (dims == 3) GEOSCoordSeq_setZ(sq, i, p3d->z);
-#else
 		if (dims == 3)
 			GEOSCoordSeq_setXYZ(sq, i, p2d->x, p2d->y, p3d->z);
 		else
 			GEOSCoordSeq_setXY(sq, i, p2d->x, p2d->y);
-#endif
@@ -355,12 +344,8 @@ ptarray_to_GEOSCoordSeq(const POINTARRAY* pa, uint8_t fix_ring)
 			p2d = getPoint2d_cp(pa, 0);
 		for (i = pa->npoints; i < pa->npoints + append_points; i++)
-#else
-#endif
@@ -388,28 +373,11 @@ GBOX2GEOS(const GBOX* box)
 	GEOSCoordSequence* seq = GEOSCoordSeq_create(5, 2);
 	if (!seq) return NULL;
-	GEOSCoordSeq_setX(seq, 0, box->xmin);
-	GEOSCoordSeq_setY(seq, 0, box->ymin);
-	GEOSCoordSeq_setX(seq, 1, box->xmax);
-	GEOSCoordSeq_setY(seq, 1, box->ymin);
-	GEOSCoordSeq_setX(seq, 2, box->xmax);
-	GEOSCoordSeq_setY(seq, 2, box->ymax);
-	GEOSCoordSeq_setX(seq, 3, box->xmin);
-	GEOSCoordSeq_setY(seq, 3, box->ymax);
-	GEOSCoordSeq_setX(seq, 4, box->xmin);
-	GEOSCoordSeq_setY(seq, 4, box->ymin);
-#else
 	GEOSCoordSeq_setXY(seq, 0, box->xmin, box->ymin);
 	GEOSCoordSeq_setXY(seq, 1, box->xmax, box->ymin);
 	GEOSCoordSeq_setXY(seq, 2, box->xmax, box->ymax);
 	GEOSCoordSeq_setXY(seq, 3, box->xmin, box->ymax);
 	GEOSCoordSeq_setXY(seq, 4, box->xmin, box->ymin);
-#endif
 	ring = GEOSGeom_createLinearRing(seq);
 	if (!ring)
@@ -468,10 +436,6 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
 			else
 				LWPOINT* lwp = (LWPOINT*)lwgeom;
-	#if POSTGIS_GEOS_VERSION < 30800
-				sq = ptarray_to_GEOSCoordSeq(lwp->point, 0);
-				g = GEOSGeom_createPoint(sq);
-	#else
 				if (lwgeom_has_z(lwgeom))
@@ -482,7 +446,6 @@ LWGEOM2GEOS(const LWGEOM* lwgeom, uint8_t autofix)
 					const POINT2D* p = getPoint2d_cp(lwp->point, 0);
 					g = GEOSGeom_createPointFromXY(p->x, p->y);
-	#endif
 			if (!g) return NULL;
 			break;
@@ -628,12 +591,7 @@ make_geos_point(double x, double y)
-	GEOSCoordSeq_setX(seq, 0, x);
-	GEOSCoordSeq_setY(seq, 0, y);
-#else
 	GEOSCoordSeq_setXY(seq, 0, x, y);
-#endif
 	geom = GEOSGeom_createPoint(seq);
 	if (!geom) GEOSCoordSeq_destroy(seq);
@@ -648,15 +606,8 @@ make_geos_segment(double x1, double y1, double x2, double y2)
-	GEOSCoordSeq_setX(seq, 0, x1);
-	GEOSCoordSeq_setY(seq, 0, y1);
-	GEOSCoordSeq_setX(seq, 1, x2);
-	GEOSCoordSeq_setY(seq, 1, y2);
-#else
 	GEOSCoordSeq_setXY(seq, 0, x1, y1);
 	GEOSCoordSeq_setXY(seq, 1, x2, y2);
-#endif
 	geom = GEOSGeom_createLineString(seq);
@@ -759,13 +710,7 @@ lwgeom_intersection_prec(const LWGEOM* geom1, const LWGEOM* geom2, double prec)
 	if (!(g2 = LWGEOM2GEOS(geom2, AUTOFIX))) GEOS_FREE_AND_FAIL(g1);
 	if ( prec >= 0) {
-#if POSTGIS_GEOS_VERSION < 30900
-		lwgeom_geos_error_minversion("Fixed-precision intersection", "3.9");
-		GEOS_FREE_AND_FAIL(g1, g2);
-		return NULL;
-#else
 		g3 = GEOSIntersectionPrec(g1, g2, prec);
-#endif
 	else
@@ -1169,254 +1114,6 @@ lwgeom_clip_by_rect(const LWGEOM *geom1, double x1, double y1, double x2, double
 /* ------------ BuildArea stuff ---------------------------------------------------------------------{ */
-typedef struct Face_t
-	const GEOSGeometry* geom;
-	GEOSGeometry* env;
-	double envarea;
-	struct Face_t* parent; /* if this face is an hole of another one, or NULL */
-} Face;
-static Face* newFace(const GEOSGeometry* g);
-static void delFace(Face* f);
-static unsigned int countParens(const Face* f);
-static void findFaceHoles(Face** faces, int nfaces);
-static Face*
-newFace(const GEOSGeometry* g)
-	Face* f = lwalloc(sizeof(Face));
-	f->geom = g;
-	f->env = GEOSEnvelope(f->geom);
-	GEOSArea(f->env, &f->envarea);
-	f->parent = NULL;
-	return f;
-countParens(const Face* f)
-	unsigned int pcount = 0;
-	while (f->parent)
-		++pcount;
-		f = f->parent;
-	return pcount;
-/* Destroy the face and release memory associated with it */
-static void
-delFace(Face* f)
-	GEOSGeom_destroy(f->env);
-	lwfree(f);
-static int
-compare_by_envarea(const void* g1, const void* g2)
-	Face* f1 = *(Face**)g1;
-	Face* f2 = *(Face**)g2;
-	double n1 = f1->envarea;
-	double n2 = f2->envarea;
-	if (n1 < n2) return 1;
-	if (n1 > n2) return -1;
-	return 0;
-/* Find holes of each face */
-static void
-findFaceHoles(Face** faces, int nfaces)
-	int i, j, h;
-	/* We sort by envelope area so that we know holes are only after their shells */
-	qsort(faces, nfaces, sizeof(Face*), compare_by_envarea);
-	for (i = 0; i < nfaces; ++i)
-		Face* f = faces[i];
-		int nholes = GEOSGetNumInteriorRings(f->geom);
-		LWDEBUGF(2, "Scanning face %d with env area %g and %d holes", i, f->envarea, nholes);
-		for (h = 0; h < nholes; ++h)
-			const GEOSGeometry* hole = GEOSGetInteriorRingN(f->geom, h);
-			LWDEBUGF(2,
-				 "Looking for hole %d/%d of face %d among %d other faces",
-				 h + 1,
-				 nholes,
-				 i,
-				 nfaces - i - 1);
-			for (j = i + 1; j < nfaces; ++j)
-				const GEOSGeometry* f2er;
-				Face* f2 = faces[j];
-				if (f2->parent) continue; /* hole already assigned */
-				f2er = GEOSGetExteriorRing(f2->geom);
-				/* TODO: can be optimized as the ring would have the same vertices, possibly in
-				 * different order. Maybe comparing number of points could already be useful. */
-				if (GEOSEquals(f2er, hole))
-					LWDEBUGF(2, "Hole %d/%d of face %d is face %d", h + 1, nholes, i, j);
-					f2->parent = f;
-					break;
-static GEOSGeometry*
-collectFacesWithEvenAncestors(Face** faces, int nfaces)
-	GEOSGeometry** geoms = lwalloc(sizeof(GEOSGeometry*) * nfaces);
-	GEOSGeometry* ret;
-	unsigned int ngeoms = 0;
-	int i;
-		if (countParens(f) % 2) continue; /* we skip odd parents geoms */
-		geoms[ngeoms++] = GEOSGeom_clone(f->geom);
-	ret = GEOSGeom_createCollection(GEOS_MULTIPOLYGON, geoms, ngeoms);
-	lwfree(geoms);
-	return ret;
-GEOSGeometry*
-LWGEOM_GEOS_buildArea(const GEOSGeometry* geom_in)
-	GEOSGeometry* tmp;
-	GEOSGeometry *geos_result, *shp;
-	GEOSGeometry const* vgeoms[1];
-	uint32_t i, ngeoms;
-	int srid = GEOSGetSRID(geom_in);
-	Face** geoms;
-#if POSTGIS_DEBUG_LEVEL >= 3
-	LWGEOM *geos_geom;
-	char *geom_ewkt;
-#endif
-	vgeoms[0] = geom_in;
-	geos_result = GEOSPolygonize(vgeoms, 1);
-	LWDEBUGF(3, "GEOSpolygonize returned @ %p", geos_result);
-	/* Null return from GEOSpolygonize (an exception) */
-	if (!geos_result) return 0;
-		/* We should now have a collection */
-#if PARANOIA_LEVEL > 0
-	if (GEOSGeomTypeId(geos_result) != COLLECTIONTYPE)
-		GEOSGeom_destroy(geos_result);
-		lwerror("%s [%d] Unexpected return from GEOSpolygonize", __FILE__, __LINE__);
-		return 0;
-#endif
-	ngeoms = GEOSGetNumGeometries(geos_result);
-	LWDEBUGF(3, "GEOSpolygonize: ngeoms in polygonize output: %d", ngeoms);
-	geos_geom = GEOS2LWGEOM(geos_result, 0);
-	geom_ewkt = lwgeom_to_ewkt(geos_geom);
-	LWDEBUGF(3, "GEOSpolygonize: polygonized:%s", geom_ewkt);
-	lwgeom_free(geos_geom);
-	lwfree(geom_ewkt);
-#endif
-	/* No geometries in collection, early out */
-	if (ngeoms == 0)
-		GEOSSetSRID(geos_result, srid);
-		return geos_result;
-	/* Return first geometry if we only have one in collection, to avoid the unnecessary Geometry clone below. */
-	if (ngeoms == 1)
-		tmp = (GEOSGeometry*)GEOSGetGeometryN(geos_result, 0);
-		if (!tmp)
-			return 0; /* exception */
-		shp = GEOSGeom_clone(tmp);
-		GEOSGeom_destroy(geos_result); /* only safe after the clone above */
-		GEOSSetSRID(shp, srid);
-		return shp;
-	LWDEBUGF(2, "Polygonize returned %d geoms", ngeoms);
-	 * Polygonizer returns a polygon for each face in the built topology.
-	 * This means that for any face with holes we'll have other faces representing each hole. We can imagine a
-	 * parent-child relationship between these faces.
-	 * In order to maximize the number of visible rings in output we only use those faces which have an even number
-	 * of parents.
-	 * Example:
-	 *   |     L0        |  L0 has no parents
-	 *   |  |   L1    |  |  L1 is an hole of L0
-	 *   |  |  |L2 |  |  |  L2 is an hole of L1 (which is an hole of L0)
-	 * See http://trac.osgeo.org/postgis/ticket/1806
-	/* Prepare face structures for later analysis */
-	geoms = lwalloc(sizeof(Face**) * ngeoms);
-	for (i = 0; i < ngeoms; ++i)
-		geoms[i] = newFace(GEOSGetGeometryN(geos_result, i));
-	/* Find faces representing other faces holes */
-	findFaceHoles(geoms, ngeoms);
-	/* Build a MultiPolygon composed only by faces with an even number of ancestors */
-	tmp = collectFacesWithEvenAncestors(geoms, ngeoms);
-	/* Cleanup face structures */
-		delFace(geoms[i]);
-	lwfree(geoms);
-	/* Faces referenced memory owned by geos_result. It is safe to destroy geos_result after deleting them. */
-	/* Run a single overlay operation to dissolve shared edges */
-	shp = GEOSUnionCascaded(tmp);
-	if (!shp)
-		GEOSGeom_destroy(tmp);
-	return shp;
-#endif
 LWGEOM*
 lwgeom_buildarea(const LWGEOM* geom)
@@ -1434,11 +1131,7 @@ lwgeom_buildarea(const LWGEOM* geom)
 	if (!(g1 = LWGEOM2GEOS(geom, AUTOFIX))) GEOS_FAIL();
-	g3 = LWGEOM_GEOS_buildArea(g1);
-#else
 	g3 = GEOSBuildArea(g1);
-#endif
 	if (!g3) GEOS_FREE_AND_FAIL(g1);
 	GEOSSetSRID(g3, srid);
@@ -1832,12 +1525,8 @@ lwpoly_to_points(const LWPOLY* lwpoly, uint32_t npoints, int32_t seed)
 			if (x >= bbox.xmax || y >= bbox.ymax) continue;
 			gseq = GEOSCoordSeq_create(1, 2);
-			GEOSCoordSeq_setX(gseq, 0, x);
-			GEOSCoordSeq_setY(gseq, 0, y);
-#else
 			GEOSCoordSeq_setXY(gseq, 0, x, y);
-#endif
 			gpt = GEOSGeom_createPoint(gseq);
 			contains = GEOSPreparedIntersects(gprep, gpt);
diff --git a/liblwgeom/lwgeom_geos.h b/liblwgeom/lwgeom_geos.h
index bf2f94bf3..e1b278e0c 100644
--- a/liblwgeom/lwgeom_geos.h
+++ b/liblwgeom/lwgeom_geos.h
@@ -34,11 +34,6 @@
 LWGEOM* GEOS2LWGEOM(const GEOSGeometry* geom, uint8_t want3d);
 GEOSGeometry* LWGEOM2GEOS(const LWGEOM* g, uint8_t autofix);
 GEOSGeometry* GBOX2GEOS(const GBOX* g);
-GEOSGeometry* LWGEOM_GEOS_buildArea(const GEOSGeometry* geom_in);
-GEOSGeometry* LWGEOM_GEOS_makeValid(const GEOSGeometry*);
-#endif
 GEOSGeometry* make_geos_point(double x, double y);
 GEOSGeometry* make_geos_segment(double x1, double y1, double x2, double y2);
diff --git a/liblwgeom/lwgeom_geos_clean.c b/liblwgeom/lwgeom_geos_clean.c
index 91430d0b4..7eb1e907e 100644
--- a/liblwgeom/lwgeom_geos_clean.c
+++ b/liblwgeom/lwgeom_geos_clean.c
@@ -38,82 +38,6 @@
 /* #define PARANOIA_LEVEL 2 */
 #undef LWGEOM_PROFILE_MAKEVALID
- * Return Nth vertex in GEOSGeometry as a POINT.
- * May return NULL if the geometry has NO vertex.
-GEOSGeometry* LWGEOM_GEOS_getPointN(const GEOSGeometry*, uint32_t);
-GEOSGeometry*
-LWGEOM_GEOS_getPointN(const GEOSGeometry* g_in, uint32_t n)
-	uint32_t dims = 0;
-	const GEOSCoordSequence* seq_in;
-	GEOSCoordSeq seq_out;
-	double val;
-	uint32_t sz = 0;
-	int gn;
-	switch (GEOSGeomTypeId(g_in))
-	case GEOS_MULTIPOINT:
-	case GEOS_MULTILINESTRING:
-	case GEOS_MULTIPOLYGON:
-	case GEOS_GEOMETRYCOLLECTION:
-		for (gn = 0; gn < GEOSGetNumGeometries(g_in); ++gn)
-			const GEOSGeometry* g = GEOSGetGeometryN(g_in, gn);
-			ret = LWGEOM_GEOS_getPointN(g, n);
-			if (ret) return ret;
-		break;
-	case GEOS_POLYGON:
-		ret = LWGEOM_GEOS_getPointN(GEOSGetExteriorRing(g_in), n);
-		for (gn = 0; gn < GEOSGetNumInteriorRings(g_in); ++gn)
-			const GEOSGeometry* g = GEOSGetInteriorRingN(g_in, gn);
-		break;
-	case GEOS_POINT:
-	case GEOS_LINESTRING:
-	case GEOS_LINEARRING:
-		break;
-	seq_in = GEOSGeom_getCoordSeq(g_in);
-	if (!seq_in) return NULL;
-	if (!GEOSCoordSeq_getSize(seq_in, &sz)) return NULL;
-	if (!sz) return NULL;
-	if (!GEOSCoordSeq_getDimensions(seq_in, &dims)) return NULL;
-	seq_out = GEOSCoordSeq_create(1, dims);
-	if (!seq_out) return NULL;
-	if (!GEOSCoordSeq_getX(seq_in, n, &val)) return NULL;
-	if (!GEOSCoordSeq_setX(seq_out, n, val)) return NULL;
-	if (!GEOSCoordSeq_getY(seq_in, n, &val)) return NULL;
-	if (!GEOSCoordSeq_setY(seq_out, n, val)) return NULL;
-	if (dims > 2)
-		if (!GEOSCoordSeq_getZ(seq_in, n, &val)) return NULL;
-		if (!GEOSCoordSeq_setZ(seq_out, n, val)) return NULL;
-	return GEOSGeom_createPoint(seq_out);
-#endif
 LWGEOM* lwcollection_make_geos_friendly(LWCOLLECTION* g);
 LWGEOM* lwline_make_geos_friendly(LWLINE* line);
 LWGEOM* lwpoly_make_geos_friendly(LWPOLY* poly);
@@ -361,539 +285,6 @@ lwcollection_make_geos_friendly(LWCOLLECTION* g)
 	return (LWGEOM*)ret;
- * Fully node given linework
-LWGEOM_GEOS_nodeLines(const GEOSGeometry* lines)
-	/* GEOS3.7 GEOSNode fails on regression tests */
-	/* GEOS3.7 GEOSUnaryUnion fails on regression tests */
-	/* union of first point with geometry */
-	GEOSGeometry *unioned, *point;
-	point = LWGEOM_GEOS_getPointN(lines, 0);
-	if (!point) return NULL;
-	unioned = GEOSUnion(lines, point);
-	GEOSGeom_destroy(point);
-	return unioned;
- * We expect initGEOS being called already.
- * Will return NULL on error (expect error handler being called by then)
-LWGEOM_GEOS_makeValidPolygon(const GEOSGeometry* gin)
-	GEOSGeom gout;
-	GEOSGeom geos_bound;
-	GEOSGeom geos_cut_edges, geos_area, collapse_points;
-	GEOSGeometry* vgeoms[3]; /* One for area, one for cut-edges */
-	unsigned int nvgeoms = 0;
-	assert(GEOSGeomTypeId(gin) == GEOS_POLYGON || GEOSGeomTypeId(gin) == GEOS_MULTIPOLYGON);
-	geos_bound = GEOSBoundary(gin);
-	if (!geos_bound) return NULL;
-	/* Use noded boundaries as initial "cut" edges */
-	geos_cut_edges = LWGEOM_GEOS_nodeLines(geos_bound);
-	if (!geos_cut_edges)
-		GEOSGeom_destroy(geos_bound);
-		lwnotice("LWGEOM_GEOS_nodeLines(): %s", lwgeom_geos_errmsg);
-		return NULL;
-	/* NOTE: the noding process may drop lines collapsing to points.
-	 *       We want to retrieve any of those */
-		GEOSGeometry* pi;
-		GEOSGeometry* po;
-		pi = GEOSGeom_extractUniquePoints(geos_bound);
-		if (!pi)
-			lwnotice("GEOSGeom_extractUniquePoints(): %s", lwgeom_geos_errmsg);
-			return NULL;
-		po = GEOSGeom_extractUniquePoints(geos_cut_edges);
-		if (!po)
-			GEOSGeom_destroy(pi);
-			return NULL;
-		collapse_points = GEOSDifference(pi, po);
-		if (!collapse_points)
-			GEOSGeom_destroy(po);
-			lwnotice("GEOSDifference(): %s", lwgeom_geos_errmsg);
-			return NULL;
-	/* And use an empty geometry as initial "area" */
-	geos_area = GEOSGeom_createEmptyPolygon();
-	if (!geos_area)
-		lwnotice("GEOSGeom_createEmptyPolygon(): %s", lwgeom_geos_errmsg);
-		GEOSGeom_destroy(geos_cut_edges);
-		return NULL;
-	 * See if an area can be build with the remaining edges
-	 * and if it can, symdifference with the original area.
-	 * Iterate this until no more polygons can be created
-	 * with left-over edges.
-	while (GEOSGetNumGeometries(geos_cut_edges))
-		GEOSGeometry* new_area = 0;
-		GEOSGeometry* new_area_bound = 0;
-		GEOSGeometry* symdif = 0;
-		GEOSGeometry* new_cut_edges = 0;
-#ifdef LWGEOM_PROFILE_MAKEVALID
-		lwnotice("ST_MakeValid: building area from %d edges", GEOSGetNumGeometries(geos_cut_edges));
-#endif
-		 * ASSUMPTION: cut_edges should already be fully noded
-		new_area = LWGEOM_GEOS_buildArea(geos_cut_edges);
-		if (!new_area) /* must be an exception */
-			GEOSGeom_destroy(geos_area);
-			lwnotice("LWGEOM_GEOS_buildArea() threw an error: %s", lwgeom_geos_errmsg);
-			return NULL;
-		if (GEOSisEmpty(new_area))
-			/* no more rings can be build with thes edges */
-			GEOSGeom_destroy(new_area);
-			break;
-		 * We succeeded in building a ring!
-		 * Save the new ring boundaries first (to compute
-		 * further cut edges later)
-		new_area_bound = GEOSBoundary(new_area);
-		if (!new_area_bound)
-			/* We did check for empty area already so this must be some other error */
-			lwnotice("GEOSBoundary('%s') threw an error: %s",
-				 lwgeom_to_ewkt(GEOS2LWGEOM(new_area, 0)),
-				 lwgeom_geos_errmsg);
-			return NULL;
-		 * Now symdif new and old area
-		symdif = GEOSSymDifference(geos_area, new_area);
-		if (!symdif) /* must be an exception */
-			GEOSGeom_destroy(new_area_bound);
-			lwnotice("GEOSSymDifference() threw an error: %s", lwgeom_geos_errmsg);
-			return NULL;
-		geos_area = symdif;
-		symdif = 0;
-		 * Now let's re-set geos_cut_edges with what's left
-		 * from the original boundary.
-		 * ASSUMPTION: only the previous cut-edges can be
-		 *             left, so we don't need to reconsider
-		 *             the whole original boundaries
-		 * NOTE: this is an expensive operation.
-		new_cut_edges = GEOSDifference(geos_cut_edges, new_area_bound);
-		if (!new_cut_edges) /* an exception ? */
-			/* cleanup and throw */
-			lwerror("GEOSDifference() threw an error: %s", lwgeom_geos_errmsg);
-			return NULL;
-		geos_cut_edges = new_cut_edges;
-	if (!GEOSisEmpty(geos_area))
-		vgeoms[nvgeoms++] = geos_area;
-	else
-	if (!GEOSisEmpty(geos_cut_edges))
-		vgeoms[nvgeoms++] = geos_cut_edges;
-	else
-	if (!GEOSisEmpty(collapse_points))
-		vgeoms[nvgeoms++] = collapse_points;
-	else
-		GEOSGeom_destroy(collapse_points);
-	if (1 == nvgeoms)
-		/* Return cut edges */
-		gout = vgeoms[0];
-	else
-		/* Collect areas and lines (if any line) */
-		gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, vgeoms, nvgeoms);
-		if (!gout) /* an exception again */
-			lwerror("GEOSGeom_createCollection() threw an error: %s", lwgeom_geos_errmsg);
-			/* TODO: cleanup! */
-			return NULL;
-	return gout;
-LWGEOM_GEOS_makeValidLine(const GEOSGeometry* gin)
-	GEOSGeometry* noded;
-	noded = LWGEOM_GEOS_nodeLines(gin);
-	return noded;
-LWGEOM_GEOS_makeValidMultiLine(const GEOSGeometry* gin)
-	GEOSGeometry** lines;
-	GEOSGeometry** points;
-	GEOSGeometry* mline_out = 0;
-	GEOSGeometry* mpoint_out = 0;
-	GEOSGeometry* gout = 0;
-	uint32_t nlines = 0, nlines_alloc;
-	uint32_t npoints = 0;
-	uint32_t ngeoms = 0, nsubgeoms;
-	uint32_t i, j;
-	ngeoms = GEOSGetNumGeometries(gin);
-	nlines_alloc = ngeoms;
-	lines = lwalloc(sizeof(GEOSGeometry*) * nlines_alloc);
-	points = lwalloc(sizeof(GEOSGeometry*) * ngeoms);
-		const GEOSGeometry* g = GEOSGetGeometryN(gin, i);
-		GEOSGeometry* vg;
-		vg = LWGEOM_GEOS_makeValidLine(g);
-		/* Drop any invalid or empty geometry */
-		if (!vg)
-			continue;
-		if (GEOSisEmpty(vg))
-			GEOSGeom_destroy(vg);
-			continue;
-		if (GEOSGeomTypeId(vg) == GEOS_POINT)
-			points[npoints++] = vg;
-		else if (GEOSGeomTypeId(vg) == GEOS_LINESTRING)
-			lines[nlines++] = vg;
-		else if (GEOSGeomTypeId(vg) == GEOS_MULTILINESTRING)
-			nsubgeoms = GEOSGetNumGeometries(vg);
-			nlines_alloc += nsubgeoms;
-			lines = lwrealloc(lines, sizeof(GEOSGeometry*) * nlines_alloc);
-			for (j = 0; j < nsubgeoms; ++j)
-				const GEOSGeometry* gc = GEOSGetGeometryN(vg, j);
-				/* NOTE: ownership of the cloned geoms will be
-				 *       taken by final collection */
-				lines[nlines++] = GEOSGeom_clone(gc);
-		else
-			/* NOTE: return from GEOSGeomType will leak
-			 * but we really don't expect this to happen */
-			lwerror("unexpected geom type returned by LWGEOM_GEOS_makeValid: %s", GEOSGeomType(vg));
-	if (npoints)
-		if (npoints > 1)
-			mpoint_out = GEOSGeom_createCollection(GEOS_MULTIPOINT, points, npoints);
-		else
-			mpoint_out = points[0];
-	if (nlines)
-		if (nlines > 1)
-			mline_out = GEOSGeom_createCollection(GEOS_MULTILINESTRING, lines, nlines);
-		else
-			mline_out = lines[0];
-	lwfree(lines);
-	if (mline_out && mpoint_out)
-		points[0] = mline_out;
-		points[1] = mpoint_out;
-		gout = GEOSGeom_createCollection(GEOS_GEOMETRYCOLLECTION, points, 2);
-	else if (mline_out)
-		gout = mline_out;
-	else if (mpoint_out)
-		gout = mpoint_out;
-	lwfree(points);
-	return gout;
-LWGEOM_GEOS_makeValidCollection(const GEOSGeometry* gin)
-	int nvgeoms;
-	GEOSGeometry** vgeoms;
-	GEOSGeom gout;
-	int i;
-	nvgeoms = GEOSGetNumGeometries(gin);
-	if (nvgeoms == -1)
-		lwerror("GEOSGetNumGeometries: %s", lwgeom_geos_errmsg);
-		return 0;
-	vgeoms = lwalloc(sizeof(GEOSGeometry*) * nvgeoms);
-	if (!vgeoms)
-		lwerror("LWGEOM_GEOS_makeValidCollection: out of memory");
-		return 0;
-	for (i = 0; i < nvgeoms; ++i)
-		vgeoms[i] = LWGEOM_GEOS_makeValid(GEOSGetGeometryN(gin, i));
-		if (!vgeoms[i])
-			int j;
-			for (j = 0; j < i - 1; j++)
-				GEOSGeom_destroy(vgeoms[j]);
-			lwfree(vgeoms);
-			/* we expect lwerror being called already by makeValid */
-			return NULL;
-			GEOSGeom_destroy(vgeoms[i]);
-		lwfree(vgeoms);
-		return NULL;
-	lwfree(vgeoms);
-	return gout;
-GEOSGeometry*
-LWGEOM_GEOS_makeValid(const GEOSGeometry* gin)
-	GEOSGeometry* gout;
-	char ret_char;
-	char *geom_ewkt;
-#endif
-	 * Step 2: return what we got so far if already valid
-	ret_char = GEOSisValid(gin);
-	if (ret_char == 2)
-		/* I don't think should ever happen */
-		lwerror("GEOSisValid(): %s", lwgeom_geos_errmsg);
-		return NULL;
-	else if (ret_char)
-		geos_geom = GEOS2LWGEOM(gin, 0);
-		LWDEBUGF(3, "Geometry [%s] is valid. ", geom_ewkt);
-#endif
-		/* It's valid at this step, return what we have */
-		return GEOSGeom_clone(gin);
-	LWDEBUGF(3,
-		 "Geometry [%s] is still not valid: %s. Will try to clean up further.",
-		 geom_ewkt,
-#endif
-	 * Step 3 : make what we got valid
-	switch (GEOSGeomTypeId(gin))
-	case GEOS_POINT:
-		/* points are always valid, but we might have invalid ordinate values */
-		lwnotice("PUNTUAL geometry resulted invalid to GEOS -- dunno how to clean that up");
-		return NULL;
-		break;
-		gout = LWGEOM_GEOS_makeValidLine(gin);
-		if (!gout) /* an exception or something */
-			lwerror("%s", lwgeom_geos_errmsg);
-			return NULL;
-		break; /* we've done */
-		gout = LWGEOM_GEOS_makeValidMultiLine(gin);
-			return NULL;
-		gout = LWGEOM_GEOS_makeValidPolygon(gin);
-			return NULL;
-		gout = LWGEOM_GEOS_makeValidCollection(gin);
-			return NULL;
-	default:
-		char* typname = GEOSGeomType(gin);
-		lwnotice("ST_MakeValid: doesn't support geometry type: %s", typname);
-		GEOSFree(typname);
-		return NULL;
-		break;
-#if PARANOIA_LEVEL > 1
-	 * Now check if every point of input is also found in output, or abort by returning NULL
-	 * Input geometry was lwgeom_in
-		int loss;
-		GEOSGeometry *pi, *po, *pd;
-		/* TODO: handle some errors here...
-		 * Lack of exceptions is annoying indeed,
-		 * I'm getting old --strk;
-		pi = GEOSGeom_extractUniquePoints(gin);
-		po = GEOSGeom_extractUniquePoints(gout);
-		pd = GEOSDifference(pi, po); /* input points - output points */
-		loss = pd && !GEOSisEmpty(pd);
-		GEOSGeom_destroy(pd);
-		if (loss)
-			lwnotice("%s [%d] Vertices lost in LWGEOM_GEOS_makeValid", __FILE__, __LINE__);
-			/* return NULL */
-#endif /* PARANOIA_LEVEL > 1 */
-	return gout;
-#endif
 /* Exported. Uses GEOS internally */
 LWGEOM*
 lwgeom_make_valid(LWGEOM* lwgeom_in)
@@ -940,9 +331,7 @@ lwgeom_make_valid_params(LWGEOM* lwgeom_in, char* make_valid_params)
 		LWDEBUG(4, "geom converted to GEOS");
-	geosout = LWGEOM_GEOS_makeValid(geosgeom);
-#elif POSTGIS_GEOS_VERSION < 31000
+#if POSTGIS_GEOS_VERSION < 31000
 	geosout = GEOSMakeValid(geosgeom);
 #else
 	if (!make_valid_params) {
diff --git a/postgis/lwgeom_geos.c b/postgis/lwgeom_geos.c
index 900c561e7..43d5cfd63 100644
--- a/postgis/lwgeom_geos.c
+++ b/postgis/lwgeom_geos.c
@@ -271,15 +271,6 @@ Datum hausdorffdistancedensify(PG_FUNCTION_ARGS)
 PG_FUNCTION_INFO_V1(ST_FrechetDistance);
 Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
-#if POSTGIS_GEOS_VERSION < 30700
-	lwpgerror("The GEOS version this PostGIS binary "
-					"was compiled against (%d) doesn't support "
-					"'GEOSFechetDistance' function (3.7.0+ required)",
-					POSTGIS_GEOS_VERSION);
-	PG_RETURN_NULL();
-#else /* POSTGIS_GEOS_VERSION >= 30700 */
 	GSERIALIZED *geom1;
 	GSERIALIZED *geom2;
 	GEOSGeometry *g1;
@@ -326,8 +317,6 @@ Datum ST_FrechetDistance(PG_FUNCTION_ARGS)
 	PG_FREE_IF_COPY(geom2, 1);
 	PG_RETURN_FLOAT8(result);
-#endif /* POSTGIS_GEOS_VERSION >= 30700 */
diff --git a/postgis/lwgeom_window.c b/postgis/lwgeom_window.c
index 1132daa84..16411a65b 100644
--- a/postgis/lwgeom_window.c
+++ b/postgis/lwgeom_window.c
@@ -465,7 +465,6 @@ Datum ST_ClusterKMeans(PG_FUNCTION_ARGS)
-#if POSTGIS_GEOS_VERSION >= 30800
  * For CoverageUnion and CoverageSimplify, clean up
  * the start of a collection if things fail in mid-stream.
@@ -481,7 +480,6 @@ coverage_destroy_geoms(GEOSGeometry **geoms, uint32 ngeoms)
 			GEOSGeom_destroy(geoms[i]);
-#endif
 #if POSTGIS_GEOS_VERSION >= 31200
@@ -795,15 +793,6 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS);
 PG_FUNCTION_INFO_V1(ST_CoverageUnion);
-		"'GEOSCoverageUnion' function (3.8.0+ required)",
-	PG_RETURN_NULL();
-#else /* POSTGIS_GEOS_VERSION >= 30800 */
 	GSERIALIZED *result = NULL;
 	Datum value;
@@ -867,7 +856,6 @@ Datum ST_CoverageUnion(PG_FUNCTION_ARGS)
 	PG_RETURN_POINTER(result);
-#endif
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index 3cd590e98..2e872af78 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -43,9 +43,11 @@ TESTS += \
 	$(top_srcdir)/regress/core/estimatedextent \
 	$(top_srcdir)/regress/core/forcecurve \
 	$(top_srcdir)/regress/core/flatgeobuf \
+	$(top_srcdir)/regress/core/frechet \
 	$(top_srcdir)/regress/core/geography \
 	$(top_srcdir)/regress/core/geometric_median \
   $(top_srcdir)/regress/core/geos_noop \
+	$(top_srcdir)/regress/core/geos38 \
 	$(top_srcdir)/regress/core/hausdorff \
 	$(top_srcdir)/regress/core/in_flatgeobuf \
 	$(top_srcdir)/regress/core/in_geohash \
@@ -146,19 +148,6 @@ TESTS_SLOW = \
 	$(top_srcdir)/regress/core/concave_hull_hard \
 	$(top_srcdir)/regress/core/knn_recheck
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30700),1)
-	# GEOS-3.7 adds:
-	# ST_FrechetDistance
-	TESTS += \
-		$(top_srcdir)/regress/core/frechet
-endif
-ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30800),1)
-	# GEOS-3.8 adds stable pointonsurface implementation
-	TESTS += \
-		$(top_srcdir)/regress/core/geos38
-endif
 ifeq ($(shell expr "$(POSTGIS_GEOS_VERSION)" ">=" 30900),1)
 	# GEOS-3.9 adds stable maximuminscribedcircle implementation
 	TESTS += \
Summary of changes:
 NEWS                          |   8 +-
 configure.ac                  |   6 +-
 liblwgeom/lwgeom_geos.c       | 317 +---------------------
 liblwgeom/lwgeom_geos.h       |   5 -
 liblwgeom/lwgeom_geos_clean.c | 613 +-----------------------------------------
 postgis/lwgeom_geos.c         |  11 -
 postgis/lwgeom_window.c       |  12 -
 regress/core/tests.mk.in      |  15 +-
 8 files changed, 15 insertions(+), 972 deletions(-)
hooks/post-receive
