[SCM] PostGIS branch master updated. 3.4.0rc1-751-g66be3a66a
Fri Nov 10 02:39:41 PST 2023
the project "PostGIS".
       via  66be3a66a2d4a4435c1acbce50a67d8629fc38e5 (commit)
      from  89fb963850b2492fe1e9d7eed1ca81b86f23e6da (commit)
revisions in full, below.
commit 66be3a66a2d4a4435c1acbce50a67d8629fc38e5
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Fri Nov 10 09:55:49 2023 +0000
    Translated PostGIS Manual using Weblate (Chinese (Simplified))
    Currently translated at 100.0% (5614 of 5614 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/zh_Hans/
diff --git a/doc/po/zh_Hans/postgis-manual.po b/doc/po/zh_Hans/postgis-manual.po
index d729914fd..50186dd72 100644
--- a/doc/po/zh_Hans/postgis-manual.po
+++ b/doc/po/zh_Hans/postgis-manual.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-11-02 18:50+0000\n"
-"PO-Revision-Date: 2023-11-03 10:23+0000\n"
+"PO-Revision-Date: 2023-11-10 10:39+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/postgis-manual/zh_Hans/>\n"
@@ -37594,9 +37594,9 @@ msgid ""
 "that a simple <varname>EPSG:CODE</varname> string does not uniquely identify "
 "a coordinate operation: the same EPSG code can be used for a CRS definition."
 msgstr ""
-"<varname>urn:ogc:def:坐标操作:权限::代码</varname>。 请注意,简单的 "
-"<varname>EPSG:CODE</varname> 字符串不能唯一标识坐标操作:相同的 EPSG 代码可用"
-"于 CRS 定义。"
+"<varname>urn:ogc:def:coordinateOperation:AUTHORITY::CODE</varname>。 请注意,"
+"简单的 <varname>EPSG:CODE</varname> 字符串不能唯一标识坐标操作:相同的 EPSG "
+"代码可用于 CRS 定义。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/zh_Hans/postgis-manual.po | 8 ++++----
 1 file changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
