[SCM] PostGIS branch master updated. 3.4.0rc1-752-g14464b4f5
Fri Nov 10 15:22:16 PST 2023
the project "PostGIS".
       via  14464b4f5b29975f5a26d5b64c43f1f015a60184 (commit)
      from  66be3a66a2d4a4435c1acbce50a67d8629fc38e5 (commit)
revisions in full, below.
commit 14464b4f5b29975f5a26d5b64c43f1f015a60184
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Fri Nov 10 13:57:52 2023 -0800
    Detect MacOS and add rpath entries when linking to proj and geos. Works around change in rpath discovery in XCode15+
diff --git a/configure.ac b/configure.ac
index cd47d79be..cd136395f 100644
--- a/configure.ac
+++ b/configure.ac
@@ -809,6 +809,23 @@ fi
 dnl Extract the linker and include flags
 GEOS_LDFLAGS=`$GEOSCONFIG --clibs`
 GEOS_CPPFLAGS=`$GEOSCONFIG --cflags`
+# MacOS with XCode > 15 now requires rpath entries for
+# libraries like GEOS/Proj that might be flexibly installed
+# with movability expected
+case $host_os in
+    darwin*)
+				GEOS_RPATH=`echo $GEOS_LDFLAGS | $PERL -nle 'print "$1" if /\-L ?(\S+) /'`
+				AC_MSG_RESULT([checking for GEOS_RPATH under MacOS... $GEOS_RPATH])
+				if test "x$GEOS_RPATH" != "x"; then
+				  # Add the rpath setting to the LDFLAGS
+					GEOS_LDFLAGS="$GEOS_LDFLAGS -Wl,-rpath,$GEOS_RPATH"
+				fi
+esac
 AC_SUBST([GEOS_LDFLAGS])
 AC_SUBST([GEOS_CPPFLAGS])
@@ -954,7 +971,7 @@ elif test ! -z "$PKG_CONFIG"; then
 			PROJ_CPPFLAGS="$PROJ_CFLAGS"
 			PROJ_LDFLAGS="$PROJ_LIBS"
-			POSTGIS_PROJ_VERSION=`$PKG_CONFIG proj --modversion | sed 's/\([[0-9]]\).*\([[0-9]]\).*\([[0-9]]\)/\1\2/'`
+			POSTGIS_PROJ_VERSION=`$PKG_CONFIG proj --modversion | $PERL -nle 'print "$1$2" if /(\d).*(\d).*(\d)/'`
 			PROJ_LDFLAGS="-lproj"
@@ -965,6 +982,23 @@ else
 fi
+case $host_os in
+    darwin*)
+				PROJ_RPATH=`echo $PROJ_LDFLAGS | $PERL -nle 'print "$1" if /\-L ?(\S+) /'`
+				AC_MSG_RESULT([checking for PROJ_RPATH under MacOS... $PROJ_RPATH])
+					if test "x$PROJ_RPATH" != "x"; then
+					PROJ_LDFLAGS="$PROJ_LDFLAGS -Wl,-rpath,$PROJ_RPATH"
+				fi
+esac
 dnl Check that we can find the proj_api.h header file
 CPPFLAGS_SAVE="$CPPFLAGS"
 CPPFLAGS="$PROJ_CPPFLAGS"
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index a382e2f3a..83fc75baf 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -22,7 +22,7 @@ LIBTOOL = @LIBTOOL@
 CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
 CUNIT_CPPFLAGS = -I$(srcdir)/.. -I$(builddir)/.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
 CFLAGS=$(CUNIT_CPPFLAGS) @CFLAGS@
-LDFLAGS = @GEOS_LDFLAGS@ $(CUNIT_LDFLAGS)
+LDFLAGS = @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ $(CUNIT_LDFLAGS)
 VPATH = $(srcdir)
diff --git a/loader/Makefile.in b/loader/Makefile.in
index 86f274556..c17fbce6b 100644
--- a/loader/Makefile.in
+++ b/loader/Makefile.in
@@ -29,7 +29,7 @@ CFLAGS= -I$(top_srcdir)/liblwgeom -I$(top_builddir)/liblwgeom @CPPFLAGS@ @CFLAGS
 SHELL = @SHELL@
 LIBTOOL = @LIBTOOL@
-LDFLAGS = @LDFLAGS@
+LDFLAGS = @LDFLAGS@ @PROJ_LDFLAGS@ @GEOS_LDFLAGS@
 # Filenames with extension as determined by the OS
 POSTGIS-CLI=postgis
diff --git a/raster/loader/Makefile.in b/raster/loader/Makefile.in
index 250dac361..a08bbc355 100644
--- a/raster/loader/Makefile.in
+++ b/raster/loader/Makefile.in
@@ -47,6 +47,7 @@ LIBGDAL_CFLAGS=@LIBGDAL_CFLAGS@
 LIBGDAL_LDFLAGS=@LIBGDAL_LDFLAGS@
 LIBGDAL_DEPLIBS_LDFLAGS=@LIBGDAL_DEPLIBS_LDFLAGS@
 PROJ_CFLAGS=@PROJ_CPPFLAGS@
+PROJ_LDFLAGS=@PROJ_LDFLAGS@
 GEOS_CFLAGS=@GEOS_CPPFLAGS@
 GEOS_LDFLAGS=@GEOS_LDFLAGS@
@@ -77,6 +78,7 @@ LDFLAGS = \
 	$(LIBGDAL_LDFLAGS) \
 	$(LIBGDAL_DEPLIBS_LDFLAGS) \
 	$(GEOS_LDFLAGS) \
+	$(PROJ_LDFLAGS) \
 	$(GETTEXT_LDFLAGS) \
 	$(ICONV_LDFLAGS)
diff --git a/regress/core/regress_buffer_params.sql b/regress/core/regress_buffer_params.sql
index cb239341d..083a16999 100644
--- a/regress/core/regress_buffer_params.sql
+++ b/regress/core/regress_buffer_params.sql
@@ -6,7 +6,7 @@
 -- Ouput is snapped to grid to account for small floating numbers
 -- differences between architectures
 SELECT 'point quadsegs=2', ST_AsText( ST_SnapToGrid(st_buffer('POINT(0 0)', 1, 'quad_segs=2'), 0.0001), 4);
-SELECT 'line quadsegs=2', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 3);
+SELECT 'line quadsegs=2', ST_AsText( ST_SnapToGrid(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2'), 0.0001), 3);
 SELECT 'line quadsegs=2 endcap=flat', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=flat'), 5);
 SELECT 'line quadsegs=2 endcap=butt', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=butt'), 5);
 SELECT 'line quadsegs=2 endcap=square', ST_AsText(st_buffer('LINESTRING(0 0, 10 0)', 2, 'quad_segs=2 endcap=square'), 5);
diff --git a/regress/core/regress_buffer_params_expected b/regress/core/regress_buffer_params_expected
index d32aa2507..36b5d3724 100644
--- a/regress/core/regress_buffer_params_expected
+++ b/regress/core/regress_buffer_params_expected
@@ -1,5 +1,5 @@
 point quadsegs=2|POLYGON((1 0,0.7071 -0.7071,0 -1,-0.7071 -0.7071,-1 0,-0.7071 0.7071,0 1,0.7071 0.7071,1 0))
-line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 2.449e-16,-1.414 1.414,0 2,10 2))
+line quadsegs=2|POLYGON((10 2,11.414 1.414,12 0,11.414 -1.414,10 -2,0 -2,-1.414 -1.414,-2 0,-1.414 1.414,0 2,10 2))
 line quadsegs=2 endcap=flat|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 line quadsegs=2 endcap=butt|POLYGON((10 2,10 -2,0 -2,0 2,10 2))
 line quadsegs=2 endcap=square|POLYGON((10 2,12 2,12 -2,0 -2,-2 -2,-2 2,10 2))
Summary of changes:
 configure.ac                                | 36 ++++++++++++++++++++++++++++-
 liblwgeom/cunit/Makefile.in                 |  2 +-
 loader/Makefile.in                          |  2 +-
 raster/loader/Makefile.in                   |  2 ++
 regress/core/regress_buffer_params.sql      |  2 +-
 regress/core/regress_buffer_params_expected |  2 +-
 6 files changed, 41 insertions(+), 5 deletions(-)
hooks/post-receive
