[PostGIS] #5521: make clean does not drop the sql/ dirs
PostGIS trac at osgeo.org
Mon Nov 13 07:12:59 PST 2023
  Reporter:  strk        |      Owner:  strk
      Type:  defect      |     Status:  closed
  Priority:  medium      |  Milestone:  PostGIS 3.4.1
 Component:  build       |    Version:  3.4.x
Resolution:  worksforme  |   Keywords:
Changes (by strk):
 * status:  new => closed
 * resolution:   => worksforme
Comment:
 I cannot reproduce: the only sql/ dirs left after `make distclean` for me
 are those under topology/ and libpgcommon/ and are both non-empty and
 contain source files.
 This is in stable-3.4 and master branches
 I'll close and in case it gets back I'll reopen or file a new one
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5521#comment:1>
