[PostGIS] #5547: postgis 3.4 not using gist index when concatinating string in st_geomfromtext
PostGIS trac at osgeo.org
Mon Nov 13 09:25:12 PST 2023
st_geomfromtext
  Reporter:  tomwlane  |      Owner:  pramsey
      Type:  defect    |     Status:  new
  Priority:  medium    |  Milestone:  PostGIS 3.4.1
 Component:  postgis   |    Version:  3.4.x
Resolution:            |   Keywords:
Comment (by strk):
 Tom, do you see the {{{ procs from ... need upgrade }}} messages ? It
 means you want to run {{{ SELECT postgis_extensions_upgrade(); }}} -
 basically your upgrade procedure wasn't completed.
 Please wrap your code snippets between `{{{` and `}}}` so they are
 rendered by Trac in monospace and newlines are respected, thanks.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5547#comment:4>
